MakeMKV only works with AnyDVD?
danielponte
Post by danielponte »
Hi guys,
I've been trying to use MakeMKV on my Macbook (both on Snow Leopard and Windows 7) but all I get are error messages when I use the "open" option.. so I just found out that it only works (for me) when I have AnyDVD loaded.. is this normal? I don't think so, because it even gives me a warning message that it should be able to decrypt on it's own without AnyDVD.. weird.. I tried to "open" a couple titles I just received from Amazon.com, here are the logs:
Debug log started at Sun Apr 4 06:42:27 2010 , written by MakeMKV v1.5.2 beta darwin(x86-release)
Using 458880KB for read cache.
001005:0000 MakeMKV v1.5.2 beta darwin(x86-release) started
001004:0000 Debug logging enabled, log will be saved as /Users/daniel/MakeMKV_log.txt
005050:0000 Evaluation version, 30 day(s) out of 30 remaining
002004:0000 Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occured while issuing SCSI command A30..00200740100720..0BA58F3D7E46C910B8ADA430DCA4FA3281D to device 'IoKit:IOBDServices:4f809aae844180ab:Optiarc BD ROM BC-5500S4 1.Va'
001003:0020 DEBUG: Code 0 at t5&P$CB+K c+vdY9'U?S:213130789
001003:0020 DEBUG: Code 0 at )Sw|7@%@Eju!+?U1<p:121262302
001003:0020 DEBUG: Code 0 at )Sw|7@%@Eju!+?U1<p:121261727
002004:0000 Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occured while issuing SCSI command A30..00200740100720..01D45A54468E907BC2F4CC7F417BA71DE9F to device 'IoKit:IOBDServices:4f809aae844180ab:Optiarc BD ROM BC-5500S4 1.Va'
001003:0020 DEBUG: Code 1 at )Sw|7@%@Eju!+?U1<p:121261727
002004:0000 Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occured while issuing SCSI command A30..00200740100720..09A7597CE17166BD186BEBEEF9A23C0D857 to device 'IoKit:IOBDServices:4f809aae844180ab:Optiarc BD ROM BC-5500S4 1.Va'
001003:0020 DEBUG: Code 2 at )Sw|7@%@Eju!+?U1<p:121261727
002004:0000 Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occured while issuing SCSI command A30..00200740100720..013AF8B923AA5410894D3B8DE20C22CA5 to device 'IoKit:IOBDServices:4f809aae844180ab:Optiarc BD ROM BC-5500S4 1.Va'
001003:0020 DEBUG: Code 3 at )Sw|7@%@Eju!+?U1<p:121261727
002004:0000 Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occured while issuing SCSI command A30..00200740100720..0097C11F8B234B16F235B1D25BED432A550 to device 'IoKit:IOBDServices:4f809aae844180ab:Optiarc BD ROM BC-5500S4 1.Va'
001003:0020 DEBUG: Code 4 at )Sw|7@%@Eju!+?U1<p:121261727
002004:0000 Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occured while issuing SCSI command A30..00200740100720..01D59C54D6606DDEDD5CA5C8833FA3D0F0A to device 'IoKit:IOBDServices:4f809aae844180ab:Optiarc BD ROM BC-5500S4 1.Va'
002004:0000 Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT ESTABLISHED' occured while issuing SCSI command AD010..080002400 to device 'IoKit:IOBDServices:4f809aae844180ab:Optiarc BD ROM BC-5500S4 1.Va'
001003:0020 DEBUG: Code 0 at t5&P$CB+K c+vdY9'U?S:121262026
001003:0020 DEBUG: Code 0 at )Sw|7@%@Eju!+?U1<p:213130835
002004:0000 Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occured while issuing SCSI command A30..00200740100720..08838C9E4E8B51F2E863F741012F84FB389 to device 'IoKit:IOBDServices:4f809aae844180ab:Optiarc BD ROM BC-5500S4 1.Va'
002004:0000 Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occured while issuing SCSI command A30..00200740100720..03513603BD684369578C60E2DE7DDBAE163 to device 'IoKit:IOBDServices:4f809aae844180ab:Optiarc BD ROM BC-5500S4 1.Va'
002004:0000 Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occured while issuing SCSI command A30..00200740100720..027C1004473AC1CCEC9781FF740783693AB to device 'IoKit:IOBDServices:4f809aae844180ab:Optiarc BD ROM BC-5500S4 1.Va'
002004:0000 Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occured while issuing SCSI command A30..00200740100720..0C081C077B0A79C217705094A8B82925B74 to device 'IoKit:IOBDServices:4f809aae844180ab:Optiarc BD ROM BC-5500S4 1.Va'
003306:0000 Can't read AACS VID from disc - most likely current AACS host certificate is revoked by your drive
003303:0000 The volume key is unknown for this disc - video can't be decrypted
001003:0020 DEBUG: Code 0 at #M$w^=lTANnkMXW+xc`:29395402
001003:0020 DEBUG: Code 0 at #M$w^=lTANnkMXW+xc`:213133296
Here I ejected the disc and inserted another one...............
002004:0000 Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occured while issuing SCSI command A30..00200740100720..05A6C791FCF781A66508D412EE2CE3EA973 to device 'IoKit:IOBDServices:4f809aae844180ab:Optiarc BD ROM BC-5500S4 1.Va'
002004:0000 Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occured while issuing SCSI command A30..00200740100720..056767F2B55EF7B7BD59BB436D2F0446A66 to device 'IoKit:IOBDServices:4f809aae844180ab:Optiarc BD ROM BC-5500S4 1.Va'
002004:0000 Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occured while issuing SCSI command A30..00200740100720..0A3E35E5DBD683464D67AD5BE7910466B1D to device 'IoKit:IOBDServices:4f809aae844180ab:Optiarc BD ROM BC-5500S4 1.Va'
002004:0000 Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occured while issuing SCSI command A30..00200740100720..00E28E27CAC49B1D68B45A8FE1B23C8A5DC to device 'IoKit:IOBDServices:4f809aae844180ab:Optiarc BD ROM BC-5500S4 1.Va'
002004:0000 Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occured while issuing SCSI command A30..00200740100720..0F76159199E32C41876B131EF18A4677332 to device 'IoKit:IOBDServices:4f809aae844180ab:Optiarc BD ROM BC-5500S4 1.Va'
002004:0000 Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occured while issuing SCSI command A30..00200740100720..00C7CA1261EE9BEF4D58C3734E3DEB87075 to device 'IoKit:IOBDServices:4f809aae844180ab:Optiarc BD ROM BC-5500S4 1.Va'
002004:0000 Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occured while issuing SCSI command A30..00200740100720..081D54858E19B2AE16325B1E6A74CCAC68F to device 'IoKit:IOBDServices:4f809aae844180ab:Optiarc BD ROM BC-5500S4 1.Va'
002004:0000 Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occured while issuing SCSI command A30..00200740100720..0D43B1D099A9067A69E7C710D349AB5346F to device 'IoKit:IOBDServices:4f809aae844180ab:Optiarc BD ROM BC-5500S4 1.Va'
002004:0000 Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occured while issuing SCSI command A30..00200740100720..0F1A91BDBCD43F508A6EC0D4722FD18BDCA to device 'IoKit:IOBDServices:4f809aae844180ab:Optiarc BD ROM BC-5500S4 1.Va'
002004:0000 Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occured while issuing SCSI command A30..00200740100720..0A16C4E139916862EF6DA2642E3B65C2985 to device 'IoKit:IOBDServices:4f809aae844180ab:Optiarc BD ROM BC-5500S4 1.Va'
Application exited at Sun Apr 4 06:45:54 2010
My system is a new MacBook Pro unibody, using a OptiArc BD-S55004 on a external USB enclosure.
Windows 7 64-bit was used, as well as Mac OS Snow Leopard.
Any help is appreciated :) Thanks!
danielponte
Re: MakeMKV only works with AnyDVD?
Just tried another title.. this time on Windows, got pretty much the same thing :( Unfortunately these are the only three titles I have, they are all concerts, just got them from Amazon.com. LOG for this last one:
Debug log started at Sun Apr 04 07:37:59 2010 , written by MakeMKV v1.5.2 beta win(x64-release)
Using 451584KB for read cache.
001005:0000 MakeMKV v1.5.2 beta win(x64-release) started
001004:0000 Debug logging enabled, log will be saved as C:\Users\Daniel/MakeMKV_log.txt
005050:0000 Evaluation version, 29 day(s) out of 30 remaining
002004:0000 Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occured while issuing SCSI command A30..00200740100720..076FB1F330791B319E51044FE8049EFA360 to device 'SPTI:\Device\CdRom1'
001003:0020 DEBUG: Code 0 at i5t\Q!^{45,>I_pL{osB:213130789
001003:0020 DEBUG: Code 0 at @MKj0:<?bj&6^eQ+V>:121262302
001003:0020 DEBUG: Code 0 at @MKj0:<?bj&6^eQ+V>:121261727
002004:0000 Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occured while issuing SCSI command A30..00200740100720..091A4036DA386D8645607E3755BFF950964 to device 'SPTI:\Device\CdRom1'
001003:0020 DEBUG: Code 1 at @MKj0:<?bj&6^eQ+V>:121261727
002004:0000 Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occured while issuing SCSI command A30..00200740100720..0D197C6135A944C681D3EDF99F75CC200EA to device 'SPTI:\Device\CdRom1'
001003:0020 DEBUG: Code 2 at @MKj0:<?bj&6^eQ+V>:121261727
002004:0000 Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occured while issuing SCSI command A30..00200740100720..0C3CB2F0AF6D11487C7C47B2F45E1FDEB7C to device 'SPTI:\Device\CdRom1'
001003:0020 DEBUG: Code 3 at @MKj0:<?bj&6^eQ+V>:121261727
002004:0000 Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occured while issuing SCSI command A30..00200740100720..0274DA975D728C3AF3D431708EDEDF25A82 to device 'SPTI:\Device\CdRom1'
001003:0020 DEBUG: Code 4 at @MKj0:<?bj&6^eQ+V>:121261727
002004:0000 Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occured while issuing SCSI command A30..00200740100720..0AC0B6F2B3059D8DADF34FE39A803FD1AF5 to device 'SPTI:\Device\CdRom1'
002004:0000 Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT ESTABLISHED' occured while issuing SCSI command AD010..080002400 to device 'SPTI:\Device\CdRom1'
001003:0020 DEBUG: Code 0 at i5t\Q!^{45,>I_pL{osB:121262026
001003:0020 DEBUG: Code 0 at @MKj0:<?bj&6^eQ+V>:213130835
002004:0000 Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occured while issuing SCSI command A30..00200740100720..0DB97D1D5A1B82229500C642115B2B2493C to device 'SPTI:\Device\CdRom1'
002004:0000 Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occured while issuing SCSI command A30..00200740100720..0AAE876B6B65CCEF08FCD76F1FDFD4AF5F0 to device 'SPTI:\Device\CdRom1'
002004:0000 Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occured while issuing SCSI command A30..00200740100720..0134654C9A707D35DA50E23ED7ED2F3C245 to device 'SPTI:\Device\CdRom1'
002004:0000 Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occured while issuing SCSI command A30..00200740100720..0031729148C455DF521D7D5D27EA63861E8 to device 'SPTI:\Device\CdRom1'
001003:0020 DEBUG: Code 0 at ;#;~~Tb@]<;?%~L)H7D:29395402
001003:0020 DEBUG: Code 0 at ;#;~~Tb@]<;?%~L)H7D:213133296
Application exited at Sun Apr 04 07:38:21 2010
Post by mike admin »
No, MakeMKV should be able to open any disc without any 3rd party software. Please do the following:
- upgrate to the latest 1.5.3 version
- on the first screen MakeMKV shows the "AACS version" for the disc, what is the version used on all 3 discs?
danielponte
Hello Mike,
Thanks for such good support. I updated to latest 1.5.3 and still get the same error, the AACS version displayed on the main screen is "AACS v7". Is there anything else I can do? :)
danielponte
Oh, I forgot to mention that I just found out that I'm can't even play these disks without AnyDVD... so weird, my BD-ROM is useless without AnyDVD, I tried with PowerDVD v10 Ultra, Nero 9 Reloaded, WinDVD BD, ArcSoft Theather... jesus, all of them tell me my drive is not able to play these disks (doesn't say anything region related).
Any idea? :(
dirio49
Post by dirio49 »
Is it a original or copy?
setarip_old
Post by setarip_old »
@danielponte
Sounds like you're trying to play
.ISOs created by AnyDVD which are lacking the required key(s) , unlike those created by using MakeMKV in combination with IMGBurn...
Have you read the following thread (posted at the Slysoft Forum)?:
http://forum.slysoft.com/showthread.php?t=37885
dirio49
Post by dirio49 »
I doubt it is an ISO.
danielponte
Hi guys,
No it's not an .ISO, I'm trying to play three original disks I got from Amazon.com, they are:
- Chris Botti at Boston
- Tony Bennett
- Diana Krall live in Rio
I purchased the drive on eBay from a seller in Hong Kong, could that be the issue? Some sort of drive restriction? I'm clueless, the drive seems to be working fine, since when I have AnyDVD loaded I can play all of them in all programs and I can open them fine in MakeMKV.. :(
I'm waiting for my PS3 to arrive this week, and I'll test these damn disks to see if they are somehow defective or what.. :(
All hits, tips, suggestions are appreciated..
dirio49
Post by dirio49 »
Do you any recently released blu-rays that you tried to play? I mean very recent
BTW.
Do you have the latest version of your players, software and hardware ?
maybe your drive has high certificate.
but where you bough it has nothing to do with regions for blue-ray atleast.
danielponte
Those three are the only blu-rays I have.. I bought them all at once, and yes, the softwares are all very updated. I really don't think it's a software problem, since I tried FOUR of them:
- ArcSoft Theather
- Nero 9 Reloaded
- WinDVD BD Edition
- PowerDVD 10 Ultra
There is a new firmware for my drive, but the updater doesn't let me update because I do not have a Sony laptop.. damn stupid program! I'm running out of options... :(
http://esupport.sony.com/US/perl/swu-do ... 2&os_id=45
setarip_old
@danielponte
I wonder if either "mike admin" or one of the BluRay ripping knowledgable folks (such as "kendoo", in the Doom9 "Decrypting" sub-forum) at the Doom9 Forum can tell you whether this is indicative of a drive whose "certificate has been revoked" - and, if so what, if anything can be done to resurrect it?
Also - Instead of selecting "Open", are you able to select the "Backup" icon - and get it to run successfully?
(I'm not near a machine with MakeMKV on it right now)
dirio49
Post by dirio49 »
The drives certificate is not revocked, it is the players or in this case makemkv. :)
you have any blue-rays that play?
do you have a blue-ray that says AACS v17 in makemkv ?
danielponte
No my friend, BACKUP gives the same error. I just googled and found 5 users having the same exact issue with this Sony Optiarc BC-5500S4 drive not being able to play disks (most of them found that it works with AnyDVD loaded). I'm sending all of them a private message to see if they got it fixed or found out something about it.
User: KevO
Link: http://forum.blu-ray.com/blu-ray-pcs-la ... 5500s.html
User: gasherburm
Link: http://www.avsforum.com/avs-vb/showthre ... st17723403
User: wot4man
Link: http://forums.whirlpool.net.au/forum-re ... ?t=1372842
User: Jason01
Link: http://www.arcsoft.jp/en/forum/forum_po ... 0521#20521
I'm about to FREAK OUT :( Damn drive! What really pissed me off too is that AnyDVD doesn't have a MacOS version... :(
danielponte
dirio49 wrote:The drives certificate is not revocked, it is the players or in this case makemkv. :)
Hi there Dirio!
No I do not have any blu-ray that plays, since I just bought it and acquired my first three titles and NONE of them play (except when I use AnyDVDHD, heh).
I'm digging a lot of sites/google and msg'in people who have the same drive to see if I can find a solution...
