I have been using makemkv for several months and have had very few issues over the last 5 months when copying blu rays to my hard drive. Today I tried converting a previously copied blu ray that was created with Anydvd hd and saved to one of my interanl hd's. I selected the index.bdmv, then selected the tracks I wanted, then selected a different hd to save to. After about 20 sec. I go a "Fatal error occured, program will now exit." I had noticed that in the makemkv window it kept repeating "Program reads data faster than it can write to disk, consider upgrading your hard drive if you see many of these messages." I don't think it is an issue with my drives because they are both newer 2tb drives and these are the same drive I have been using. Just to be sure I tried saving to one of my raids with no luck. I noticed that it said that it can't find any usable optical drives even though I still have the same drive I have been using over the last few months. I could have sworn that I had done this all once before with no problems, but I have tried several different movies and I always get the same message and fatal error. Here is the debug log:
Debug log started at Fri Apr 2 00:30:30 2010 , written by MakeMKV v1.5.0 beta darwin(x86-release)
001005:0000 MakeMKV v1.5.0 beta darwin(x86-release) started
001004:0000 Debug logging enabled, log will be saved as /Users/8Corebackup/MakeMKV_log.txt
001003:0020 DEBUG: Code 4294967295 at l"4&J6V?;Vc[q4J4V]Y75J)Ip%[:29399128
002007:0000 Cannot obtain exclusive access for optical drive "HL-DT-ST BDDVDRW GGC-H20L 1.05" - disc reading will likely fail. You may want to eject and reload the disc while makemkv is running.
001003:0020 DEBUG: Code 3758097093 at l"4&J6V?;Vc[q4J4V]Y75J)Ip%[:29394160
001003:0020 DEBUG: Code 4026532549 at #IGfG>HeLm Zv(:121262877
001003:0020 DEBUG: Code 4026532549 at .CWc5L-m*LZ(@ug&:121262900
001003:0020 DEBUG: Code 0 at .CWc5L-m*LZ(@ug&:121262670
001003:0020 DEBUG: Code 0 at X!=-.,og12Q+w&0:29394229
005042:0000 The program can't find any usable optical drives.
003006:0000 Opening files on harddrive at /Volumes/HTPC_Blu-Ray1/Blu-Ray Movies/Golden Compass/GOLDEN_COMPASS_D1/
003305:0000 AACS directory not present, assuming unencrypted disc
005050:0000 Evaluation version, 7 day(s) out of 30 remaining
001002:0020 LIBMKV_TRACE: No CC5 in 00009
003307:0000 File 00011.mpls was added as title #0
003307:0000 File 00012.mpls was added as title #1
003025:0000 Title #00000.m2ts has length of 6 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00001.m2ts has length of 22 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00002.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00004.m2ts has length of 73 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00005.m2ts has length of 76 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00006.m2ts has length of 76 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00014.m2ts has length of 6 seconds which is less than minimum title length of 120 seconds and was therefore skipped
005011:0000 Operation sucessfully completed
005014:0000 Saving 1 titles into directory /Volumes/HTPC_Blu-Ray1/Blu-Ray Movies/Golden Compass
005001:0308 File /Volumes/HTPC_Blu-Ray1/Blu-Ray Movies/Golden Compass/title00.mkv already exist. Do you want to overwrite it?
002008:0020 Program reads data faster than it can write to disk, consider upgrading your hard drive if you see many of these messages.
tp=PdfOD2ssZrcZENh23lYymXUJ2r6aMFFBydu/tvYizLCf7WTndstgORZx3mMoNnSR5lJa1/SSyP8JU2G9+Pc2kiEcQERljvcyZxIFqzoiASjJje5ZtyNRMfn2nMwIxayyd6Ta+Neu9Swi72yRgckIumJ9aoiyGzqURuxiv2NXtnI1lhLPDdN97MZcYtx/TZ0Xrd2ngojVPSRzPXf2p95sIO7L7ihuITfSRgazGDWdnmjYvhKmIXvWuH4sQ/N0=
001003:0020 DEBUG: Code 0 at O)B~j_UshRg5?#>-V30Q:213130973
tp=Pyst2jnXzg9rLGa3GRDYdt5WMpl1Cdq+mjBRQcnbv7b2Isywn+1k53bLYDkWcd5jKDZ0keZSWtf0ksj/CVNhvfj3NpIhHEBEZY73MmcSBas6IgEoyY3uWbcjUTH59pzMCMWssnek2vjXrvUsIu9skYHJCLpifWqIshs6lEbsYr9jV7ZyNZYSzw3TfezGXGLcf02dF63dp4KI1T0kcz139qfebCDuy+4obiE30kYGsxg1nZ5o2L4SpiF71rh+LEPzd
ts2=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
001003:0020 DEBUG: Code 0 at au1"RGSW>!ymFXRSP>pJ:29394413
001003:0020 DEBUG: Code 1731170 at au1"RGSW>!ymFXRSP>pJ:213129639
001003:0020 DEBUG: Code 0 at 5p6![=6NJQyrdHoQ!%-eF:121264993
Fatal error?
- Contact:
Re: Fatal error?
Before going any further, please download and try latest version, 1.5.2
Re: Fatal error?
i Just upgraded to 1.5.2 and I had the same issue. Has anyone else been able to convert lo copied blu rays from your Anydvd HD to .mkv's?
Thanks,
Steve
Thanks,
Steve
- Contact:
Re: Fatal error?
Your log file shows that M2TS file is corrupted. For this particular disc there is nothing you can do - AnyDVD decrypted it incorrectly. Normally MakeMKV can open decrypted Blu-ray discs regardless of what program was used to decrypt.
