This application version is too old.
Bersquack
Hi everybody.
I have been having the following message each time I try to use Make MKV: This application version is too old. Please doenload the latest version...
The thing is that I have 1.5.2 Beta installed, so I do not know why it is locking me out. I also uninstalled and reinstalled and I still have the same problem.
Couls something be wrong with my registries?
Thanks.
Thanks.
NomadCF
Re: This application version is too old.
Any chance your system clock is way off ?
If you think it's registry issue, you could do the fallowing (at your own risk):
1. Fully backup your registry (and whole machine, if possible)
2. uninstall makemkv
3. run regedit
4. Look for all "MakeMKV" KEYs and delete them (Keys are top checkbox in the find box in regedit.)
Danger
OR you could follow this link http://www.makemkv.com/forum2/viewtopic.php?f=5&t=1053 and just plug in the registration code:
run MakeMKV
-> Help -> Register -> new code from above link.
run MakeMKV
Highlag
This application is too old....
Well when application starts I receive this popup, sugesting to download new version on this website, but I already have "latest" version. When I click OK application exits. What can I do to start it?
setarip_old
Re: This application is too old....
Have you inadvertently changed the system date on your PC?
Highlag
Not that I'm avare of that. Had no reason to do that.
- Contact:
Please use the temporary beta key at http://www.makemkv.com/forum2/viewtopic.php?f=5&t=1053 , it will reset the expiration date.
Highlag
Not sure how can I input key if I cant get to program window/toolbar.
setarip_old
Uninstall the version that's presently on your system and then download and install a fresh one from the makemkv.com website...
syztemlord
Application too old problem
I'm running 1.5.6 which has been working fine for a week now but I tried it today and I'm getting the "Application is too old" message. I've tried uninstalling and reinstalling a freash copy but I still get the same message. Any ideas?
syztemlord
Re: Application too old problem
Ok, just fixed it. I put the system date back to the first of this month and opened the program, which was ok. I then put in the beta key and put the date back as today. All is good!
DonkeyKong
deleted registry entries, uninstall reinstall
nothing helped
can't start programm
using win7 64 bit
do I have to buy now ?
nothing helped
using win7 64 bit
tmarnik
I have the same problem. It just started happening this morning.
Version 1.5.6 Windows 7 64-bit
Downloading and re-installing per the message does not fix it.
matster
Hi - I'm getting the same message as well. Again, it just started this morning. Tried uninstalling / reinstalling etc, but still can't get it to work !
yrred
I'm having the same problem, Windows 7 32 bit they may be putting a new version out.
