hash table, checksums… How to verify ripped data after rip?
mattmkv
Post by mattmkv »
Hello!
I am seeing the following in the logs really often:
Loaded content hash table, will verify integrity of M2TS files
What does that mean? Is there a file containing checksums for every M2TS file of the Blu-ray disc?
Where can I find it? I want to verify my M2TS files after a rip.
Re: hash table, checksums… How to verify ripped data after r
Actually, if MakeMKV doesn't say the rip failed, the checksums passed.
There is documentation on the web that describes the hash table, though.
mattmkv
Post by mattmkv »
I got two rips, but they differ minimal. Same disc, same blu-ray drive, same hard disk (NTFS).
first rip (sha256sum):
2217abcb8f012d9a44ce71dfe75c522c7705cd80fab98f96231fab49b88b4dbd  JURASSICWORLD_UPB1/BDMV/STREAM/00800.m2ts
second rip (sha256sum):
04978d37ef953227c64194902893c78b4c1617d580a15996c48f5f7d618a8f6c  JURASSICWORLD_UPB1/BDMV/STREAM/00800.m2ts
first rip:
Debug log started at Mon Dec 14 19:08:36 2015 , written by MakeMKV v1.9.7 linux(x64-release)
001005:0000 MakeMKV v1.9.7 linux(x64-release) started
001004:0000 Debug logging enabled, log will be saved as /home/mint/MakeMKV_log.txt
005072:0000 Backing up disc into folder "/media/mint/BOOTCAMP/linux/Videos/backup/JURASSICWORLD_UPB1"
005050:0000 Evaluation version, 30 day(s) out of 30 remaining
DEBUG: Code 2147483648 at PR?DHGHxB~:D~K5M:121265315
DAFD=PAAAADAAAAEABDQkEHwECAQ==
DCE=vqr+ueFJVjPfXZWZk9H1yxQJirg0SuYBYz/SPArFHBQcaPjqMSO3IlQ4os3DGTDNOc+97ZvtkQjXCQjNTVQxoIGOCdRcJL8lc/VEpEqUWi+CXXbUzab2o0GShh/6SWS7fLpzr3Aibt+ZYHIg8jPJpkKdLKaunkzEkw==
DCE=4DTHfhlfFM7sHbYKyXSq7e5lSv59azcY0MzUggrH4ug8iM7DNtaSxkbqQ09K1Pte2MCJCoFgKp+j4q/3uDtTrJiYi3Q10q9fqYOLBb3JQaYhHW5hSQXT2EkaFNe5hsnxRb/jIkN0IQXGLAgPBy/GhOuIVCHvXG09pA==
005070:0080 Backup done
005081:0104 Backup done.
Application exited at Mon Dec 14 20:52:23 2015
second rip:
Debug log started at Wed Dec 16 20:35:57 2015 , written by MakeMKV v1.9.7 win(x64-release)
001005:0000 MakeMKV v1.9.7 win(x64-release) started
001004:0000 Debug logging enabled, log will be saved as C:\Users\User1/MakeMKV_log.txt
005072:0000 Backing up disc into folder "C:/2jurassic/backup/JURASSICWORLD_UPB1"
DEBUG: Code 2147483648 at '(&byawYai[o+:&o:121265315
DCE=WnOYymAFKhNjAE5yE3D39cioQ0X/emqNB4OhSs/OhCAAYTGXDhdu10Jz+qOkQ4kOoFrxjq3c7xRvJYjnSz1F8JAwc6zK0meZGwTflHth/gT9AI6n2kwmWJZ3kwxYXD1n6djIaGobuVQdi4tEyO5FFZW2EMaVyaar5g==
DCE=UgIsEuoVQzJdHpaQSEjYmABjROxKF544elABRnTOFx/ArKxhABeCLg6+CgxquqWpUoCC4zeK/+vSKQ3BQVHpobrK2wUSPiopCaD10sEyutUXbnyQ/a4UAihQqzeleDeJoR4tjfL6JVeJ7jMVR731Pe4WY8MG+322GQ==
Application exited at Wed Dec 16 21:52:21 2015
I am note sure. Maybe data rot or something? :?
mattmkv
Post by mattmkv »
I compared the file 00800.m2ts with another decrypted rip (source: raw image created by ddrescue) and my second rip seems to be fine.
A globally checksum database for m2ts-files would be awesome. :mrgreen:
Maybe something like AccurateRip (audio) for Blu-ray discs.
Post by mike admin »
mattmkv wrote:I compared the file 00800.m2ts with another decrypted rip (source: raw image created by ddrescue) and my second rip seems to be fine.
This is not right, you should get two absolutely identical M2TS files[/quote]
mattmkv wrote: A globally checksum database for m2ts-files would be awesome. :mrgreen:
Each blu-ray disc contains hashes of all M2TS files. This feature is part of AACS protection, not for integrity. Yet it can be used to verify M2TS integrity. Files are hashed in blocks of 96K, so depending on file size up to 90K at file end may be not hashed. MakeMKV checks these hashes in all modes, both backup and MKV. If you get no error messages then it means that all hashes were validated.
baronluigi
Post by baronluigi »
Each blu-ray disc contains hashes of all M2TS files. This feature is part of AACS protection, not for integrity. Yet it can be used to verify M2TS integrity. Files are hashed in blocks of 96K, so depending on file size up to 90K at file end may be not hashed. MakeMKV checks these hashes in all modes, both backup and MKV. If you get no error messages then it means that all hashes were validated.[/quote]
What I usually do is to rip the file twice and make a SFV file of each rip.
rkjnsn
Post by rkjnsn »
mike admin wrote:
Mon Jan 18, 2016 10:33 am
For anyone else who runs into this, files are actually hashed in blocks of 96 sectors of 2048 bytes, so blocks of 192 KiB, not 96 KiB. It also looks like the offset of the error reported by MakeMKV is actually somewhere toward the end of the failed block, not the beginning of it. So if MakeMKV reports
Hash check failed for file 01068.m2ts at offset 1083697152, file is corrupt.
It means that the failed block is the 192 KiB block starting at the offset: floor(1083697152 / 196608) * 196608 = 1083506688
