Annoying anydvd promt disable or remove in future please
Tsunamijhoe
Post by Tsunamijhoe »
Is there any way to suppress the extremely annoying anydvd promt? If not,could you please either make it possible to disable the promt,or remove it completely in future versions..
Thank you
MichaelAnders
Re: Annoying anydvd promt disable or remove in future please
Post by MichaelAnders »
Wow, I wanted to know a solution to that as well and here I found the same question... unanswered since 2015 :?:
I tried Makemkv decrpytion: fails for me for several disks. Anydvd always worked.
Adding a simple checkbox when the popup is displayed with an "ignore forever" or a new setting in the UI would be great.
I code... such a change is a few lines of to add and would really be great.
