I've been trying to use MakeMKV on my Macbook (both on Snow Leopard and Windows 7) but all I get are error messages when I use the "open" option.. so I just found out that it only works (for me) when I have AnyDVD loaded.. is this normal? I don't think so, because it even gives me a warning message that it should be able to decrypt on it's own without AnyDVD.. weird.. I tried to "open" a couple titles I just received from Amazon.com, here are the logs:
Debug log started at Sun Apr 4 06:42:27 2010 , written by MakeMKV v1.5.2 beta darwin(x86-release)
Using 458880KB for read cache.
001005:0000 MakeMKV v1.5.2 beta darwin(x86-release) started
001004:0000 Debug logging enabled, log will be saved as /Users/daniel/MakeMKV_log.txt
005050:0000 Evaluation version, 30 day(s) out of 30 remaining
002004:0000 Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occured while issuing SCSI command A30..00200740100720..0BA58F3D7E46C910B8ADA430DCA4FA3281D to device 'IoKit:IOBDServices:4f809aae844180ab:Optiarc BD ROM BC-5500S4 1.Va'
001003:0020 DEBUG: Code 0 at t5&P$CB+K c+vdY9'U?S:213130789
001003:0020 DEBUG: Code 0 at )Sw|7@%@Eju!+?U1<p:121262302
001003:0020 DEBUG: Code 0 at )Sw|7@%@Eju!+?U1<p:121261727
002004:0000 Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occured while issuing SCSI command A30..00200740100720..01D45A54468E907BC2F4CC7F417BA71DE9F to device 'IoKit:IOBDServices:4f809aae844180ab:Optiarc BD ROM BC-5500S4 1.Va'
001003:0020 DEBUG: Code 1 at )Sw|7@%@Eju!+?U1<p:121261727
002004:0000 Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occured while issuing SCSI command A30..00200740100720..09A7597CE17166BD186BEBEEF9A23C0D857 to device 'IoKit:IOBDServices:4f809aae844180ab:Optiarc BD ROM BC-5500S4 1.Va'
001003:0020 DEBUG: Code 2 at )Sw|7@%@Eju!+?U1<p:121261727
002004:0000 Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occured while issuing SCSI command A30..00200740100720..013AF8B923AA5410894D3B8DE20C22CA5 to device 'IoKit:IOBDServices:4f809aae844180ab:Optiarc BD ROM BC-5500S4 1.Va'
001003:0020 DEBUG: Code 3 at )Sw|7@%@Eju!+?U1<p:121261727
002004:0000 Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occured while issuing SCSI command A30..00200740100720..0097C11F8B234B16F235B1D25BED432A550 to device 'IoKit:IOBDServices:4f809aae844180ab:Optiarc BD ROM BC-5500S4 1.Va'
001003:0020 DEBUG: Code 4 at )Sw|7@%@Eju!+?U1<p:121261727
002004:0000 Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occured while issuing SCSI command A30..00200740100720..01D59C54D6606DDEDD5CA5C8833FA3D0F0A to device 'IoKit:IOBDServices:4f809aae844180ab:Optiarc BD ROM BC-5500S4 1.Va'
002004:0000 Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT ESTABLISHED' occured while issuing SCSI command AD010..080002400 to device 'IoKit:IOBDServices:4f809aae844180ab:Optiarc BD ROM BC-5500S4 1.Va'
001003:0020 DEBUG: Code 0 at t5&P$CB+K c+vdY9'U?S:121262026
001003:0020 DEBUG: Code 0 at )Sw|7@%@Eju!+?U1<p:213130835
002004:0000 Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occured while issuing SCSI command A30..00200740100720..08838C9E4E8B51F2E863F741012F84FB389 to device 'IoKit:IOBDServices:4f809aae844180ab:Optiarc BD ROM BC-5500S4 1.Va'
002004:0000 Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occured while issuing SCSI command A30..00200740100720..03513603BD684369578C60E2DE7DDBAE163 to device 'IoKit:IOBDServices:4f809aae844180ab:Optiarc BD ROM BC-5500S4 1.Va'
002004:0000 Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occured while issuing SCSI command A30..00200740100720..027C1004473AC1CCEC9781FF740783693AB to device 'IoKit:IOBDServices:4f809aae844180ab:Optiarc BD ROM BC-5500S4 1.Va'
002004:0000 Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occured while issuing SCSI command A30..00200740100720..0C081C077B0A79C217705094A8B82925B74 to device 'IoKit:IOBDServices:4f809aae844180ab:Optiarc BD ROM BC-5500S4 1.Va'
003306:0000 Can't read AACS VID from disc - most likely current AACS host certificate is revoked by your drive
003303:0000 The volume key is unknown for this disc - video can't be decrypted
001003:0020 DEBUG: Code 0 at #M$w^=lTANnkMXW+xc`:29395402
001003:0020 DEBUG: Code 0 at #M$w^=lTANnkMXW+xc`:213133296
Here I ejected the disc and inserted another one...............
002004:0000 Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occured while issuing SCSI command A30..00200740100720..05A6C791FCF781A66508D412EE2CE3EA973 to device 'IoKit:IOBDServices:4f809aae844180ab:Optiarc BD ROM BC-5500S4 1.Va'
002004:0000 Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occured while issuing SCSI command A30..00200740100720..056767F2B55EF7B7BD59BB436D2F0446A66 to device 'IoKit:IOBDServices:4f809aae844180ab:Optiarc BD ROM BC-5500S4 1.Va'
002004:0000 Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occured while issuing SCSI command A30..00200740100720..0A3E35E5DBD683464D67AD5BE7910466B1D to device 'IoKit:IOBDServices:4f809aae844180ab:Optiarc BD ROM BC-5500S4 1.Va'
002004:0000 Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occured while issuing SCSI command A30..00200740100720..00E28E27CAC49B1D68B45A8FE1B23C8A5DC to device 'IoKit:IOBDServices:4f809aae844180ab:Optiarc BD ROM BC-5500S4 1.Va'
002004:0000 Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occured while issuing SCSI command A30..00200740100720..0F76159199E32C41876B131EF18A4677332 to device 'IoKit:IOBDServices:4f809aae844180ab:Optiarc BD ROM BC-5500S4 1.Va'
002004:0000 Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occured while issuing SCSI command A30..00200740100720..00C7CA1261EE9BEF4D58C3734E3DEB87075 to device 'IoKit:IOBDServices:4f809aae844180ab:Optiarc BD ROM BC-5500S4 1.Va'
002004:0000 Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occured while issuing SCSI command A30..00200740100720..081D54858E19B2AE16325B1E6A74CCAC68F to device 'IoKit:IOBDServices:4f809aae844180ab:Optiarc BD ROM BC-5500S4 1.Va'
002004:0000 Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occured while issuing SCSI command A30..00200740100720..0D43B1D099A9067A69E7C710D349AB5346F to device 'IoKit:IOBDServices:4f809aae844180ab:Optiarc BD ROM BC-5500S4 1.Va'
002004:0000 Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occured while issuing SCSI command A30..00200740100720..0F1A91BDBCD43F508A6EC0D4722FD18BDCA to device 'IoKit:IOBDServices:4f809aae844180ab:Optiarc BD ROM BC-5500S4 1.Va'
002004:0000 Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occured while issuing SCSI command A30..00200740100720..0A16C4E139916862EF6DA2642E3B65C2985 to device 'IoKit:IOBDServices:4f809aae844180ab:Optiarc BD ROM BC-5500S4 1.Va'
Application exited at Sun Apr 4 06:45:54 2010
My system is a new MacBook Pro unibody, using a OptiArc BD-S55004 on a external USB enclosure.
Windows 7 64-bit was used, as well as Mac OS Snow Leopard.
Any help is appreciated
![Smile :)](./images/smilies/icon_smile.gif)
