I got makemkv-oss-1.9.8.tar.gz, but its comilation failed;
Makefile:59: recipe for target 'out/libmakemkv.so.1.full' failed
make: *** [out/libmakemkv.so.1.full] Error 1
make: *** Waiting for unfinished jobs.....
Any hint?
Thanks,
makemkv-oss 1.9.8 for linux, compile failed
Re: makemkv-oss 1.9.8 for linux, compile failed
The make output by itself won't help much in diagnosing what's going on. You should really post the full output, so that people can see everything that's going on, including all the gcc/ld/as output.
> The make output by itself won't help much in diagnosing what's going on. You should really > post the full output, so that people can see everything that's going on, including all the
> gcc/ld/as output.
I see.
Anyway, makemkv-oss-1.9.8.tar.gz requires the very old files; libavcodec.so.54, libavutil.so.51?
It seemes to me.
> gcc/ld/as output.
I see.
It seemes to me.
- make.log
- (4.43 KiB) Downloaded 1003 times
- Contact:
This is a bug. Here is a workaround - http://www.makemkv.com/forum2/viewtopic.php?f=3&t=10893
I'm using CentOS 7 with latest updates and also get compilation errors when I try to compile makemkv-oss version 1.9.8 (the previous version 1.9.7 worked without any problems).
Here is the output of the "make" process:
mkdir -p out
gcc -g -O2 -D_linux_ -D_GNU_SOURCE -D__STDC_CONSTANT_MACROS -D__STDC_LIMIT_MACROS -D_REENTRANT -shared -Wl,-z,defs -oout/libmakemkv.so.1.full -Ilibebml/inc -DEBML_NO_READ -DEBML_STRICT_API -DEBML_DEBUG -Ilibmatroska/inc \
-Ilibmakemkv/inc -Isstring/inc -Imakemkvgui/inc -Ilibabi/inc -Ilibffabi/inc -DDCA_LOG -DDCA_FFMALLOC \
libebml/src/EbmlBinary.cpp libebml/src/EbmlContexts.cpp libebml/src/EbmlCrc32.cpp libebml/src/EbmlDate.cpp libebml/src/EbmlDummy.cpp libebml/src/EbmlElement.cpp libebml/src/EbmlFloat.cpp libebml/src/EbmlHead.cpp libebml/src/EbmlMaster.cpp libebml/src/EbmlSInteger.cpp libebml/src/EbmlString.cpp libebml/src/EbmlSubHead.cpp libebml/src/EbmlUInteger.cpp libebml/src/EbmlUnicodeString.cpp libebml/src/EbmlVersion.cpp libebml/src/EbmlVoid.cpp libebml/src/IOCallback.cpp libebml/src/MemIOCallback.cpp libmatroska/src/FileKax.cpp libmatroska/src/KaxAttached.cpp libmatroska/src/KaxAttachments.cpp libmatroska/src/KaxBlock.cpp libmatroska/src/KaxBlockData.cpp libmatroska/src/KaxCluster.cpp libmatroska/src/KaxContexts.cpp libmatroska/src/KaxCues.cpp libmatroska/src/KaxCuesData.cpp libmatroska/src/KaxInfoData.cpp libmatroska/src/KaxSeekHead.cpp libmatroska/src/KaxSegment.cpp libmatroska/src/KaxTracks.cpp libmatroska/src/KaxVersion.cpp libmatroska/src/KaxSemantic.cpp libmakemkv/src/ebmlwrite.cpp libmakemkv/src/libmkv.cpp libmakemkv/src/version.cpp libmakemkv/src/world.cpp libmakemkv/src/stdstring.cpp sstring/src/sstring.cpp \
libabi/src/ossl_aes.c libabi/src/ossl_sha.c libabi/src/ossl_ec.c libabi/src/zlib.c libabi/src/xpat.c libabi/src/libm.c libabi/src/httplinux.cpp makemkvgui/src/api_linux.cpp libabi/src/sys_linux.c makemkvgui/src/spawn_posix.cpp libffabi/src/ffabi.c libffabi/src/mlp.c libffabi/src/log.c libffabi/src/audio_convert.c libffabi/src/audio_mix.c libffabi/src/audio_mix_matrix.c libffabi/src/dcadec/bitstream.cpp libffabi/src/dcadec/core_decoder.cpp libffabi/src/dcadec/dca_context.cpp libffabi/src/dcadec/dmix_tables.cpp libffabi/src/dcadec/exss_parser.cpp libffabi/src/dcadec/idct_fixed.cpp libffabi/src/dcadec/interpolator.cpp libffabi/src/dcadec/interpolator_fixed.cpp libffabi/src/dcadec/interpolator_float.cpp libffabi/src/dcadec/ta.cpp libffabi/src/dcadec/xll_decoder.cpp libffabi/src/dcadec/idct_float.cpp \
-DHAVE_BUILDINFO_H -Itmp -I/usr/local/include \
-fPIC -Xlinker -dy -Xlinker --version-script=libmakemkv/src/libmakemkv.vers \
-Xlinker -soname=libmakemkv.so.1 -lc -lstdc++ -lcrypto -lz -lexpat -pthread -L/usr/local/lib -lavcodec -lXv -lXext -lva-x11 -lva -lxcb-shm -lxcb-xfixes -lxcb-render -lxcb-shape -lxcb -lX11 -lcdio_paranoia -lcdio_cdda -lcdio -lasound -lSDL -lpthread -lxvidcore -lx265 -lx264 -lvpx -lvorbisenc -lvorbis -ltwolame -ltheoraenc -ltheoradec -logg -lopus -lopencore-amrwb -lopencore-amrnb -lmp3lame -lfdk-aac -lbluray -lass -laacplus -llzma -lbz2 -lz -lswresample -lavutil -lm -lm -lrt
libmakemkv/src/libmkv.cpp: In Elementfunktion »void MyMkvTrackInfo::RenderStat(libmatroska::KaxTags&, unsigned int, uint64_t, const char*)«:
libmakemkv/src/libmkv.cpp:379:53: Fehler: expected »)« before »PRIu64«
sprintf_s(buffer,sizeof(buffer),"%" PRIu64,values);
libmakemkv/src/libmkv.cpp:387:49: Fehler: expected »)« before »PRIu64«
sprintf_s(buffer,sizeof(buffer),"%" PRIu64,stat_bytes);
make: *** [out/libmakemkv.so.1.full] Fehler 1
mkdir -p out
I have a very similar error while trying to compile for amd64 on debian wheezy
nas1:~# cd /export/vol1_old/tmp/makemkv-oss-1.9.8
nas1:/export/vol1_old/tmp/makemkv-oss-1.9.8# ./configure
checking build system type... x86_64-unknown-linux-gnu
checking host system type... x86_64-unknown-linux-gnu
checking target system type... x86_64-unknown-linux-gnu
checking for gcc... gcc
checking whether the C compiler works... yes
checking for C compiler default output file name... a.out
checking for suffix of executables...
checking whether we are cross compiling... no
checking for suffix of object files... o
checking whether we are using the GNU C compiler... yes
checking whether gcc accepts -g... yes
checking for gcc option to accept ISO C89... none needed
checking for g++... g++
checking whether we are using the GNU C++ compiler... yes
checking whether g++ accepts -g... yes
checking for -objcopy... no
checking for objcopy... objcopy
checking for -ld... no
checking for ld... ld
checking for a BSD-compatible install... /usr/bin/install -c
checking how to run the C preprocessor... gcc -E
checking for grep that handles long lines and -e... /bin/grep
checking for egrep... /bin/grep -E
checking for ANSI C header files... yes
checking for sys/types.h... yes
checking for sys/stat.h... yes
checking for stdlib.h... yes
checking for string.h... yes
checking for memory.h... yes
checking for strings.h... yes
checking for inttypes.h... yes
checking for stdint.h... yes
checking for unistd.h... yes
checking zlib.h usability... yes
checking zlib.h presence... yes
checking for zlib.h... yes
checking for compress2 in -lz... yes
checking openssl/opensslconf.h usability... yes
checking openssl/opensslconf.h presence... yes
checking for openssl/opensslconf.h... yes
checking for AES_encrypt in -lcrypto... yes
checking expat.h usability... yes
checking expat.h presence... yes
checking for expat.h... yes
checking for XML_ParserCreate in -lexpat... yes
checking for pkg-config... /usr/bin/pkg-config
checking pkg-config is at least version 0.9.0... yes
checking for ffmpeg... yes
checking whether LIBAVCODEC_VERSION_MAJOR is declared... yes
checking LIBAVCODEC_VERSION_MAJOR... 54
checking for AVFrame.nb_samples... yes
checking whether AV_SAMPLE_FMT_U8P is declared... yes
checking for avcodec_encode_audio2... yes
checking for AVCodecContext.refcounted_frames... no
checking whether avcodec_free_frame is declared... yes
checking whether av_frame_free is declared... no
checking for av_log_format_line... yes
checking for enum AVCodecID... yes
checking whether AV_CODEC_ID_NONE is declared... yes
checking whether av_frame_get_channels is declared... yes
checking whether av_frame_get_sample_rate is declared... yes
checking whether av_frame_set_channel_layout is declared... yes
checking for AVCodecParserContext.duration... yes
checking whether AV_CH_TOP_BACK_CENTER is declared... no
checking for qt5... no
checking for qt4... yes
configure: creating ./config.status
config.status: creating Makefile
config.status: creating libffabi/src/ffabicfg.h
nas1:/export/vol1_old/tmp/makemkv-oss-1.9.8# make
mkdir -p out
gcc -g -O2 -D_linux_ -D_GNU_SOURCE -D__STDC_CONSTANT_MACROS -D__STDC_LIMIT_MACROS -D_REENTRANT -shared -Wl,-z,defs -oout/libdriveio.so.0.full -Ilibdriveio/inc libdriveio/src/infolist.cpp libdriveio/src/scsihlp.cpp libdriveio/src/srlist.cpp libdriveio/src/stdquery.cpp libdriveio/src/tipclient.cpp libdriveio/src/tipcommon.cpp libdriveio/src/tipserver.cpp libdriveio/src/drives/pioneer.cpp libdriveio/src/drives/xboxhddvd.cpp \
-fPIC -Xlinker -dy -Xlinker --version-script=libdriveio/src/libdriveio.vers \
-Xlinker -soname=libdriveio.so.0 -lc -lstdc++
objcopy --strip-all --strip-debug --strip-unneeded --discard-all out/libdriveio.so.0.full out/libdriveio.so.0
mkdir -p tmp
echo "#define BUILDINFO_ARCH_NAME \"x86_64-linux-gnu\"" >> tmp/gen_buildinfo.h
echo "#define BUILDINFO_BUILD_DATE \"Mi 6. Jan 13:36:40 CET 2016\"" >> tmp/gen_buildinfo.h
mkdir -p out
-DHAVE_BUILDINFO_H -Itmp \
-Xlinker -soname=libmakemkv.so.1 -lc -lstdc++ -lcrypto -lz -lexpat -lavcodec -lavutil -lm -lrt
libmakemkv/src/libmkv.cpp: In member function \u2018void MyMkvTrackInfo::RenderStat(libmatroska::KaxTags&, unsigned int, uint64_t, const char*)\u2019:
libmakemkv/src/libmkv.cpp:379:53: error: expected \u2018)\u2019 before \u2018PRIu64\u2019
libmakemkv/src/libmkv.cpp:387:49: error: expected \u2018)\u2019 before \u2018PRIu64\u2019
Any help is very much appreciated.
Thanks in advance.
mkdir -p out
mkdir -p tmp
mkdir -p out
Thanks in advance.
Tensoval, did you try the work-around Mike linked to?
Woodstock wrote:Tensoval, did you try the work-around Mike linked to?
now i did and it worked - thanx
