American Ultra US Playlist
ncarusojr
Does anyone have the correct playlist for the American Ultra version that comes in the red envelope. Thanks for any help
penguinsaregood
Re: American Ultra US Playlist
Purchased from Amazon
UPC: 0 31398 23179 0
Title information
Name: American Ultra (English)
Source file name: 00441.mpls
Duration: 1:35:41
Chapters count: 16
Segment count: 15
Segment map: 502,504,501,511,509,510,515,503,512,514,508,505,513,507,506
File name: American_Ultra_t111.mkv
Title information
Duration: 1:35:41
Chapters count: 16
Segment count: 15
ncarusojr
Not the right version. 441.mpls starts with 510. Matter of fact all of the netf---- playlists start with 510. I check through all the playlists that come up and none start with 502. I thought I could just matchup the playlist that way. But sadly no. Thanks
ekael86
I believe this is correct as I have just gone through it and tried to piece it together correctly. Don't trust me 100% on this though.
Source File Name: 00592.mpls
Segment map: 510, 505, 518, 503, 515, 504, 507, 513, 501, 511, 519, 516, 514, 509, 512, 520,517, 506, 508, 502
Benjamin99
My copy skips from 00590.mpls to 00593.mpls.ekael86 wrote:I believe this is correct as I have just gone through it and tried to piece it together correctly. Don't trust me 100% on this though.
This one doesn't match the 00441.mpls I have at all either.penguinsaregood wrote:Purchased from Amazon
Title information
Duration: 1:35:41
Chapters count: 16
Segment count: 15
Mr.SuntoryTime
Ya, this wont work for me either. have a disk from the crimson kiosk fyi. trying 00502 will adviseBenjamin99 wrote:My copy skips from 00590.mpls to 00593.mpls.ekael86 wrote:I believe this is correct as I have just gone through it and tried to piece it together correctly. Don't trust me 100% on this though.
Title information
Duration: 1:35:41
Chapters count: 16
Segment count: 15
xbmcuser
Source file name: 00593.mpls
Duration: 1:35:41
Chapters count: 16
Segment count: 20
Segment map: 510,505,518,503,515,504,507,513,501,511,519,516,514,509,512,520,517,506,508,502
Researching this it seems the best/fastest way to find the correct segment map is to first backup the entire disc, which should be of normal size. Then knowing you need to work with a certain subset of segments your job is to now figure out their correct order, which the superset can be found here: BDMV/STREAM. You should be able to find each segment's starting point and length by referencing the movie.
Duration: 1:35:41
Chapters count: 16
Segment count: 20
Mondays
AnyDVD confirms 00593.mpls on netflix disk
