Process of resolving errors about "no FUTs were obtained"
eugene
Post by eugene »
Sorry for stupid question perhaps... :oops:
How can I know that the problem with my non-convertible Blu-Ray disk (errors about no FUTs were obtained) has been solved (or not solved still)? Only starting conversion again and again? (I have sent "dump" earlier.)
Re: Process of resolving errors about "no FUTs were obtained
Unless you ask Mike to let you know, it's just a case of trying the rip again. As long as you have authorized MakeMKV to check for updates (Preferences->General), once the SVQ has been created, it will automatically load as needed.
eugene
Post by eugene »
Woodstock, thank you.
I just tried to convert my problem disk again. In data folder of MakeMKV was appeared new svq-file and... о miracle! All process was finished correctly. Super! :D
My great thanks to Mike. :)
