Ripping error
wl.boer
Ripping error
#1 Post by wl.boer » Wed Dec 16, 2015 6:14 am
This is the very first time having a problem ripping a DVD in MakeMkv, I have ripped hundreds including Bluray's. The DVD in question is one of the James Bond Box set. The Disc plays alright in VLC, MPC, Windows DVD Player and the standalone DVD Player. Is there a solution?
Not to technical if possible please, I am a senior citizen trying to keep up with the ever changing world of computers. :shock:
Title #1 has length of 9 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #2 has length of 87 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #4 was added (34 cell(s), 1:54:02)
Title #5 has length of 16 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #7 has length of 34 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #8 has length of 31 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #9 has length of 76 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Saving 1 titles into directory C:/Downloads
The source file '/VIDEO_TS/VTS_03_1.VOB' is corrupt or invalid at offset 69345280, attempting to work around
DEBUG: Code 0 at 0%`_ie(YzVNMox6:t 4:121262992
DEBUG: Code 2920 at dTY}Ut\3Z+1[99lR]yBK&:29397403
The source file '/VIDEO_TS/VTS_03_1.VOB' is corrupt or invalid at offset 69347328, attempting to work around
The source file '/VIDEO_TS/VTS_03_1.VOB' is corrupt or invalid at offset 69355520, attempting to work around
The source file '/VIDEO_TS/VTS_03_1.VOB' is corrupt or invalid at offset 69472256, attempting to work around
The source file '/VIDEO_TS/VTS_03_1.VOB' is corrupt or invalid at offset 69482496, attempting to work around
DEBUG: Code 22720 at GY@CNuI|Nl;96U@'3lN:29394114
DEBUG: Code 0 at Y|IF&],tF&yI9BW_ayAs:213130559
DEBUG: Code 33868 at Y|IF&],tF&yI9BW_ayAs:29393286
DEBUG: Code 0 at dTY}Ut\3Z+1[99lR]yBK&:29398967
LIBMKV_TRACE: Exception: Error in p->FetchFrames(1,false)
Failed to save title 0 to file C:/Downloads/title00.mkv
0 titles saved, 1 failed
Re: Ripping error
#2 Post by Woodstock » Wed Dec 16, 2015 7:47 am
The drive appears to be having some issues reading the disk, and returns invalid information instead of an actual error code. Have you tried cleaning the disk yet?
wl.boer
Re: Ripping error
#3 Post by wl.boer » Wed Dec 16, 2015 8:07 am
The disk is brand new and as I mentioned it plays ok in various media players. I have also used Ideal DVD copy to extract the main movie on disk.
That worked ok and the file is playable but when I tried to convert it from vob to mkv the same errors come up. I have thrown it at mkvtoolnix but a read error comes up.
