star wars clone wars season 1 - extras only - no episodes
nate500
#1 Post by nate500 » Tue Dec 15, 2015 8:12 pm
Hello -
I have seen a few other posts related to other seasons of Clone wars but not this issue with Season 1. I recently purchased Seasons 1-5, as well as the lost missions, everything except season 1 seemed to go fine (I read something online related to audio issues in season 5 I haven't watched that far ahead yet to see if I noticed anything or even if getting a replacement disc(s) is still possible.
With season 1, all 3 discs behave the same, they seem to rip ok, but none of the episodes are there - (seems like) all of the extras are there, there are no videos longer than a few minutes out of 60+ tracks. I have tried with makemkv as well as anydvd HD
I do get these errors on disc 1 for example:
Error 'Scsi error - ILLEGAL REQUEST:ILLEGAL MODE FOR THIS TRACK' occurred while reading 'DVD+R-DL hp CDDVDW TS-H653R 0E00' at offset '524288'
Error 'Scsi error - ILLEGAL REQUEST:ILLEGAL MODE FOR THIS TRACK' occurred while reading 'DVD+R-DL hp CDDVDW TS-H653R 0E00' at offset '1048576'
Error 'Scsi error - ILLEGAL REQUEST:ILLEGAL MODE FOR THIS TRACK' occurred while reading 'DVD+R-DL hp CDDVDW TS-H653R 0E00' at offset '32768'
Docs suggest this might be a bad disc though it can still read the disc (disc looks fine and plays perfectly on a standalone blu ray player)
I get the *exact* same errors on Season 2 disc 1 (same offset and everything) those discs ripped episodes without an issue. So I don't think it is a fatal error. I haven't checked if all of the discs from all of the seasons show that error or not, but season 1 is the only one I have issues with.
I am using Handbrake 0.10.2.7286 64-bit along with MakeMkv 1.9.7 on windows 7 64-bit with a "LG Blu-ray Disc Rewriter External eSATA 12x Super Multi Blue LightScribe BE12LU30"
I've had rips fail completely before because of various reasons but have never had this where it rips a bunch of stuff but the main contents appear to be missing.
thanks
Re: star wars clone wars season 1 - extras only - no episode
#2 Post by Woodstock » Wed Dec 16, 2015 2:16 am
Is this the DVD or Bluray version?
My first suggestion would be to follow the instructions in the FAQ linked in my signature, and send the relevant files to support@makemkv.com for review. There might be information in the debug log that will point to why MakeMKV isn't detecting the episodes.
nate500
#3 Post by nate500 » Wed Dec 16, 2015 2:37 am
this is blu ray. I have season 1 DVD ripped from a couple of years ago (forgot which app I did it with but I assume it was handbrake).
I'll check the logs
thanks
Yugatha
#4 Post by Yugatha » Sat Dec 19, 2015 12:01 am
Might be a stupid question, but are you using a BluRay drive to rip it? You've said they are bluray discs, but the log shows what is most likely a DVD drive.
#5 Post by mike admin » Sun Dec 20, 2015 1:39 pm
This is a physical disc error, meaning your drive can't read the data from the disc. Usually it means a scratched disc, but could be a failing drive. /faq/item/7/catid/6
Nonamin
#6 Post by Nonamin » Sun Feb 28, 2016 6:42 pm
I've got a similar issue - if I try to back up the discs I get no error messages, but the output is just the features / director talking etc. Weirdly if I make MKVs, I do get the episodes, so not a problem reading data from the disc or with the drive? Did anyone solve this?
Edit: Just thought of something, opening the files as a disc in VLC or MPC still doesn't work, but if I browse to the bdmv folder, then playlist, then open 00000.mpls in MPC I do get one massive title which so far appears to have episodes in. Not sure why but hey, if it works!
h2ofun
#7 Post by h2ofun » Fri Mar 11, 2016 10:31 pm
I see this a lot, mainly on BR discs. Sometimes it is a scratched disc. Sometimes it is the reader. Is a real pain.
