cocoon
Post
by cocoon » Fri Apr 02, 2010 4:32 pm
When running /usr/bin/makemkv with root user I'm getting the follow message:
Application Failed to initialize
QGtkStyle was unable to detect the current GTK+ theme.
Qt: Session management error: None of the authentication protocols specified are supported
(process:5067): Gtk-CRITICAL **: gtk_widget_style_get: assertion `GTK_IS_WIDGET (widget)' failed
Is there any configuration missing ? I'm runing Fedora 12.
Tks
cocoon
Post
by cocoon » Fri Apr 02, 2010 11:14 pm
I got the same error with normal user.
Your right. I'm running the buggy version 4.6.2.
Seems I have to wait a little bit.
Thanks !
skittle
Post
by skittle » Sat Apr 03, 2010 4:28 am
cool, post back if if starts to work with 4.6.3!
Jugin
Post
by Jugin » Wed Aug 31, 2011 11:56 am
Congratulations!! working now
Hope that there will be no such problems anymore))
Jugin on Fri Jun 15, 2012 10:33 am, edited 1 time in total.
swan11
Post
by swan11 » Sat Nov 26, 2011 10:37 am
I think your issue can easily be solved once you update it to the most recent version. Also, the version which you are using which is the 4.6.2 had been known to have some bugs. The 4.6.4 is a safe bet or you could try the most recent versions which should be bug free.
“Read Today, Lead Tomorrow”
