Transporter Refueled
wildspirit97
No FUTs for Transporter Refueled. I Emailed the dump file. Anybody else buy this movie?
wildspirit97
Re: Transporter Refueled
It works now.
Thank you Mike.
Thank you Mike.
escobar6987
Thanks Mike? I can't get it to work, and it seems I had the same problem you originally had, but you were somehow able to fix it...?
Make sure you have "Allow contacting web server for updates" checked in Preferences->General. That allows MakeMKV to download SVQ files as needed.
