starwars epesiode 3 error
stevey1983
#1 Post by stevey1983 » Tue Dec 08, 2015 8:35 pm
Getting this error when trying to copy blueray of starwars epesiode 3, any idea what the problem is?
thanks
MakeMKV v1.9.7 win(x64-release) started
Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading 'BD-RE TSSTcorp BDDVDW SE-506BB TS00' at offset '24743376896'
Evaluation version, 29 day(s) out of 30 remaining
Loaded 74 SVQ file(s)
Processing BD+ code, please be patient - this may take up to few minutes
Processing BD+ code using generic SVQ from builtin/00000.svq
BD+ code processed, got 1 FUT(s) for 1 clip(s)
Title #00720.mpls has length of 35 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/BDMV/STREAM/00020.m2ts' at offset '0'
Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/BDMV/STREAM/00020.m2ts' at offset '61440'
Failed to decode audio/video data for title #0 - invalid mux or internal error, title skipped.
Title #00020.mpls was skipped
File 00800.mpls (angle 1) was added as title #0
File 00800.mpls (angle 2) was added as title #1
File 00800.mpls (angle 3) was added as title #2
File 00800.mpls (angle 4) was added as title #3
File 00800.mpls (angle 5) was added as title #4
File 00800.mpls (angle 6) was added as title #5
File 00800.mpls (angle 7) was added as title #6
File 00800.mpls (angle 8) was added as title #7
Title 00850.mpls is equal to title 00800.mpls and was skipped
Failed to add angle #2 for title #850
Failed to add angle #3 for title #850
Failed to add angle #4 for title #850
Failed to add angle #5 for title #850
Failed to add angle #6 for title #850
Failed to add angle #7 for title #850
Failed to add angle #8 for title #850
Title #00011.m2ts has length of 23 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00122.m2ts has length of 11 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00123.m2ts has length of 15 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00720.m2ts has length of 17 seconds which is less than minimum title length of 120 seconds and was therefore skipped
File 00300.m2ts was added as title #8
File 00301.m2ts was added as title #9
Title #00302.m2ts has length of 44 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00020.m2ts has length of 70 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00021.m2ts has length of 62 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Saving 1 titles into directory C:/Video/Revenge_of_the_Sith1
Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/BDMV/STREAM/00301.m2ts' at offset '718848'
Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/BDMV/STREAM/00300.m2ts' at offset '129024'
Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/BDMV/STREAM/00300.m2ts' at offset '522240'
Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/BDMV/STREAM/00301.m2ts' at offset '325632'
Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/BDMV/STREAM/00301.m2ts' at offset '258048'
Error 'Scsi error - MEDIUM ERROR:NO SEEK COMPLETE' occurred while reading '/BDMV/STREAM/00300.m2ts' at offset '1112064'
Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/BDMV/STREAM/00300.m2ts' at offset '1308672'
Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/BDMV/STREAM/00300.m2ts' at offset '1505280'
Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/BDMV/STREAM/00300.m2ts' at offset '3796992'
Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/BDMV/STREAM/00300.m2ts' at offset '4190208'
Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/BDMV/STREAM/00301.m2ts' at offset '129024'
Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/BDMV/STREAM/00300.m2ts' at offset '22806528'
Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/BDMV/STREAM/00300.m2ts' at offset '40040448'
Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/BDMV/STREAM/00300.m2ts' at offset '40237056'
Failed to save title 0 to file C:/Video/Revenge_of_the_Sith1/Revenge_of_the_Sith_t00.mkv
0 titles saved, 1 failed
Re: starwars epesiode 3 error
#2 Post by Woodstock » Tue Dec 08, 2015 10:33 pm
Yes, your drive says it can't read several parts of the disk. Most likely causes are dirty or scratches, followed by a bad pressing at the manufacturing plant.
If cleaning doesn't help, and it's a new disk, consider getting it replaced.
stevey1983
#3 Post by stevey1983 » Wed Dec 09, 2015 6:17 am
Thank you. Ive had them awhile and there is no scratches on them and they look clean. I will try giving them a clean incase its something i can't see on them. Think its too late now to get them changed.
Thanks for your help
stevey1983
#4 Post by stevey1983 » Thu Dec 10, 2015 1:21 pm
I have given it a wash and now its working fine. Thanks for your help
