Cannot naviagate to/select folders for a source
I currently have all of my movies ripped to my WHS. I downloaded and installed makemkv to try and convert folders to mkv. When I try and navigate and select the folder it will not even recognize it. So I am dead in the water. Anyone else with this problem? Any problems using this on WHS?
Re: Cannot naviagate to/select folders for a source
1. How did you rip the movies to your WHS (Windows Home Server).
2. What are you really trying to accomplish here ?
Are you trying to just convert your existing library of movies to MKV from (VOB/TS/M2TS/etc) ?
Or have you ripped them into a ISO or other simple full DVD backup ?
setarip_old
@sfoster4
Hi!
MakeMKV (and, as far as I know, any other program that can create .MKV files) can create .MKV files ONLY from individual files - whether the individual files are in folders or not...
Hi!
- Contact:
This is not exactly true. MakeMKV opens "folders". What kind of source are you trying to open, DVD or blu-ray? For DVD you need to select VIDEO_TS.ifo file inside VIDEO_TS folder.setarip_old wrote:MakeMKV (and, as far as I know, any other program that can create .MKV files) can create .MKV files ONLY from individual files - whether the individual files are in folders or not...
jamerican1
I just tried to open a source folder (BluRay) that I had ripped with another program and could not get anything to open from the Stream or Playlist folders. All the .mpls and .m2ts icons were grayed out/unselectable. Will the program read only from an Optical drive
setarip_old
@jamerican1
Hi!
Click on either "index.bdmv" or "MovieObject.bdmv"
Hi!
jamerican1
@setarip_old
Thanks a lot. It works! This has definitely made up my mind to buy the license.
setarip_old
My pleasure ;>}Thanks a lot. It works!
