MEDIUM ERROR:UNRECOVERED READ ERROR_Harry potter
TSM123456
Post by TSM123456 » Sat Dec 05, 2015 12:35 pm
Hello. Having problems reading 3 disks from the harry potter series bluray box set. The remaining 5 disks function fine. All three of three of these disks play fine using the same drive and the 'power dvd' software I use.
When I try to read the disks with MakeMKV I get the following error log:
MakeMKV v1.9.7 win(x64-release) started
Error 'Scsi error - MEDIUM ERROR:UNRECOVERED READ ERROR' occurred while issuing SCSI command AD010..080002400 to device 'SPTI:\Device\CdRom0'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' occurred while issuing SCSI command A30..00200740100720..02B537743E5ECC049C8DF12AC5615B20ED4 to device 'SPTI:\Device\CdRom0'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' occurred while issuing SCSI command A30..00200740100720..07585C48FD2AA17683A9CB5A0C09A68CBE5 to device 'SPTI:\Device\CdRom0'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' occurred while issuing SCSI command A30..00200740100720..0E2591AC455F7E3679122FDE81E0ECDADC8 to device 'SPTI:\Device\CdRom0'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' occurred while issuing SCSI command A30..00200740100720..0FEAEF0D6150243FCDEDC1BFCE1D1A84B05 to device 'SPTI:\Device\CdRom0'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' occurred while issuing SCSI command A30..00200740100720..06D2E1ACEC582CD5C2E5B477D368DBE457A to device 'SPTI:\Device\CdRom0'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' occurred while issuing SCSI command A30..00200740100720..001338FAB3BCD420F0A6EFD73FBA615DFA4 to device 'SPTI:\Device\CdRom0'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT ESTABLISHED' occurred while issuing SCSI command AD010..080002400 to device 'SPTI:\Device\CdRom0'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' occurred while issuing SCSI command A30..00200740100720..0E1F2CDA1C8E4BC965DD38EDCFD03D380D2 to device 'SPTI:\Device\CdRom0'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' occurred while issuing SCSI command A30..00200740100720..0C191197C39AC59077866A82D45BBD7D905 to device 'SPTI:\Device\CdRom0'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' occurred while issuing SCSI command A30..00200740100720..0C52E0AC3F6EA7B8BFE6B2CEB53B408121B to device 'SPTI:\Device\CdRom0'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' occurred while issuing SCSI command A30..00200740100720..05E318143D965CC06228E79DDDCEE6B8DB2 to device 'SPTI:\Device\CdRom0'
Highest AACS version is v51 , MKB saved as C:\Users\tom/.MakeMKV/MKB_v51_WOLF_HALL_D1.tgz
Drive info
Manufacturer: TSSTcorp
Product: DVDWBD SN-406AB
Revision: SB00
Bus encryption flags: 1E
Highest AACS version: 51
Can anyone advise me on what could be going wrong?
Re: MEDIUM ERROR:UNRECOVERED READ ERROR_Harry potter
Post by Woodstock » Sat Dec 05, 2015 4:20 pm
The errors are consistent with a problem reading the disk header... These errors occur early, at the part of the rip where MakeMKV is looking at the copy protection portion of the disk:
Failing to read the CP information, it can't calculate the proper AACS key information to send, which leads to:
Make sure these disks are clean in the area around the hub... no fingerprints, no scratches.
Why do they work in a player? The player (essentially) only has one key to try, and it either works or doesn't. It doesn't have to discover information about the disk before trying to decrypt it, so errors near the start of the disk aren't as critical.
TSM123456
Post by TSM123456 » Sun Dec 06, 2015 9:09 pm
OK. Thanks for the advice, it's made the problem clearer.
Unfortunately cleaning the disks doesn't appear to solve the problem, so I'll return them and ask for them to be replaced. If this doesn't solve it I may come back and ask for more help.
Thanks again.
TSM123456
Post by TSM123456 » Wed Dec 09, 2015 10:37 pm
Hello again. I've now received the replacement disks and unfortunately they suffer from the same problem. Could there be another underlying cause? Are there any tests I can run to check this?
Thanks again for your help.
Post by Woodstock » Thu Dec 10, 2015 2:11 am
If you do not run MakeMKV as an administrator, Windows may not give it permission to talk to the drive at the level it needs to be able to do the key creation. But that problem should manifest with all of the disks, not just three of them. And problems with the drive itself in this particular area will show up on all disks, not just a few.
Sorry, I've run out of ideas.
DuffB
Post by DuffB » Thu Dec 10, 2015 7:45 am
I had the same problem as well. I got this Bluray boxset off Amazon - http://www.amazon.com/gp/product/B006QR ... dp_summary
Every disc copied without issue except the Deathly Hallows Part 2 disc. It works in my bluray player, just that MakeMKV gets an error about 7Gb into the title. The disc was fresh out of the box set too. I'm hoping it's just a driver issue.
This error only pops twice on the log before the recording stops-
Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/BDMV/STREAM/00081.m2ts' at offset '129024000'
It's the first Bluray disc I've come across with any issue that it can't be read.
Post by Woodstock » Thu Dec 10, 2015 7:59 pm
That appears to be the UK version of the same disk set I have, released in 2011. So it should not be a copy protection/BD+ issue.
Not sure what to say. Personally, I'd still give it my "standard treatment" (spray with Pledge wax, rub in with a clean finger, wipe off with a soft cotton or microfiber cloth), in case there was a fingerprint or residue from the machinery that moves the disks around in the manufacturing process (happens a lot), but I've been told it's a "bad thing" to wax disks, because any excess can be picked up by the read head and cause later problems.
