THE_LEGEND_OF_THE_NEVERBEAST
iMactouch
Post by iMactouch »
Hi!
I am getting these problems with 1.9.7 and the Blu-Ray: THE_LEGEND_OF_THE_NEVERBEAST
Fehler 'SCSI-Fehler - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' trat auf während des Auslesens von '/BDMV/STREAM/00337.m2ts' bei Offset '61440'
DEBUG: Code 0 at xi*]rgmXa`EFp##6y\l:29398070
DEBUG: Code 0 at 9(x(.-2A?|Cs;F[whtg7:121265108
Backup fehlgeschlagen
I also had this problem with other Blu-Rays (not with all) and the version 1.9.7.
Is this a new protection?
I am using a Pioneer BD-RW BDR-XD05 which is attached directly to my Mac mini 2012 and USB 3.0. I also tried it with the extra USB connection if there is to less voltage, but no change.
Thank you in advance!
Re: THE_LEGEND_OF_THE_NEVERBEAST
It is likely some defect in or on the disk. The drive says it can not read part of it. The first thing to try is cleaning the disk, in case it is just a fingerprint causing the problem.
iMactouch
Post by iMactouch »
This is the result of the main file rip:
Fehler 'SCSI-Fehler - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' trat auf während des Auslesens von '/BDMV/STREAM/00340.m2ts' bei Offset '6667235328'
DEBUG: Code 0 at VL'VrJz@G6>mQN0z#s9":121263038
DEBUG: Code 0 at !5#0q]?KmM3*0rA RPM):121262302
DEBUG: Code 0 at VL'VrJz@G6>mQN0z#s9":213130559
DEBUG: Code 3255486 at VL'VrJz@G6>mQN0z#s9":29393286
DEBUG: Code 0 at "Bi_IjpT/Uy'`]]QUTb5i:29398967
DEBUG: Code 0 at CX_B5TRcJS!jy!]4vlS:29396414
DEBUG: Code 0 at Qg}hc%Ll08wd).t+;%6k:29403222
DEBUG: Code 0 at =[fgwBA8UK:kbsqq}:213131893
DEBUG: Code 0 at =[fgwBA8UK:kbsqq}:121263406
DEBUG: Code 0 at =[fgwBA8UK:kbsqq}:29393907
The Blu-Ray is new and without any fingerprint or scratch. I don't think of a defect. I can watch the film without any problem in a normal Blu-Ray player. Only ripping is not possible.
iMactouch
Post by iMactouch »
I tested it on a PC with another BD-drive (BD-RE MATSHITA BD-MLT SW-5584 1.02):
At scanning the disc I am getting this:
Fehler 'SCSI-Fehler - MEDIUM ERROR:NO SEEK COMPLETE' trat auf während des Auslesens von '/BDMV/STREAM/00338.m2ts' bei Offset '0'
at ripping I get this:
Fehler 'SCSI-Fehler - HARDWARE ERROR:0990' trat auf während des Auslesens von '/BDMV/STREAM/00338.m2ts' bei Offset '0'
Fehler 'SCSI-Fehler - HARDWARE ERROR:TRACK FOLLOWING ERROR' trat auf während des Auslesens von '/BDMV/STREAM/00336.m2ts' bei Offset '351664128'
iMactouch
Post by iMactouch »
I did a test again:
Fehler 'SCSI-Fehler - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' trat auf während des Auslesens von '/BDMV/STREAM/00340.m2ts' bei Offset '6613499904'
DEBUG: Code 3229248 at VL'VrJz@G6>mQN0z#s9":29393286
Maybe someone can read the debug codes.
