I tried out the 1.4.7beta of MakeMKV, on a Windows Vista 32bit system, against a Bluray ("Black Hawk Down", thai is).
First of all, the app doesn't recognize my BluRay-burner (external one, connected by USB) -I understand that there is an AHCI problem, but am surprised to see it applying to USB-connected external drives as well:
Debug log started at Sun Oct 04 11:58:35 2009 , written by MakeMKV v1.4.7 beta win(x86-release)
001014:000000:0000 MakeMKV v1.4.7 beta win(x86-release) started
001013:000000:0000 Debug logging enabled, log will be saved as C:\Users\kr/MakeMKV_log.txt
001012:000000:0020 FAILURE: Code 3221225488 at 5x;g5XS1jQ]t ':213130927
001012:000000:0020 FAILURE: Code 3221225488 at [e:E$k?4N(2|+E"X:121263061
001012:000000:0020 FAILURE: Code 0 at [e:E$k?4N(2|+E"X:121262762
001012:000000:0020 FAILURE: Code 0 at Fc}`.}P?~e@>GHz1HPF)M~l-H~:29393516
005042:000000:0000 The program can't find any usable optical drives. The BETA version requires administrative privileges for drive access.Code: Select all
003006:000000:0000 Opening files on harddrive at C:/Video/57760311_BLACK_HAWK_DOWN/
003310:000000:0000 AACS directory not present, assuming unencrypted disc
003313:000000:0000 File 00009.mpls was added as title #0
003020:000000:0000 Title #00023.mpls has length of 60 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003313:000000:0000 File 00025.mpls was added as title #1
003314:000000:0000 Title 00035.mpls is equal to title 00009.mpls and was skipped
003313:000000:0000 File 00042.mpls was added as title #2
003313:000000:0000 File 00002.m2ts was added as title #3
003313:000000:0000 File 00003.m2ts was added as title #4
003313:000000:0000 File 00004.m2ts was added as title #5
003313:000000:0000 File 00005.m2ts was added as title #6
003313:000000:0000 File 00006.m2ts was added as title #7
003020:000000:0000 Title #00009.m2ts has length of 14 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003020:000000:0000 Title #00010.m2ts has length of 12 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003020:000000:0000 Title #00011.m2ts has length of 6 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003020:000000:0000 Title #00012.m2ts has length of 6 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003020:000000:0000 Title #00013.m2ts has length of 6 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003020:000000:0000 Title #00014.m2ts has length of 6 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003020:000000:0000 Title #00015.m2ts has length of 6 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003020:000000:0000 Title #00016.m2ts has length of 6 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003020:000000:0000 Title #00017.m2ts has length of 6 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003020:000000:0000 Title #00018.m2ts has length of 6 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003020:000000:0000 Title #00019.m2ts has length of 6 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003020:000000:0000 Title #00020.m2ts has length of 12 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003020:000000:0000 Title #00021.m2ts has length of 6 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003020:000000:0000 Title #00022.m2ts has length of 60 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003020:000000:0000 Title #00027.m2ts has length of 6 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003020:000000:0000 Title #00028.m2ts has length of 6 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003020:000000:0000 Title #00029.m2ts has length of 6 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003020:000000:0000 Title #00030.m2ts has length of 6 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003020:000000:0000 Title #00031.m2ts has length of 6 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003020:000000:0000 Title #00032.m2ts has length of 6 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003020:000000:0000 Title #00033.m2ts has length of 6 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003020:000000:0000 Title #00034.m2ts has length of 6 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003020:000000:0000 Title #00035.m2ts has length of 6 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003020:000000:0000 Title #00036.m2ts has length of 6 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003020:000000:0000 Title #00037.m2ts has length of 6 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003020:000000:0000 Title #00040.m2ts has length of 17 seconds which is less than minimum title length of 120 seconds and was therefore skipped
005011:000000:0000 Operation sucessfully completedThe 8th one however is the main movie with 35,5GB and 15 chapters. This one ends with a "TimecodeDelay >= int16(0x8000) && TimecodeDelay <= int16(0x7FFF)" -anyone a clue on that?
005014:000000:0000 Saving 1 titles into directory C:/Video/UNNAMED_DISC
001011:000000:0020 LIBMKV_TRACE: Exception: MKV_ASSERT: TimecodeDelay >= int16(0x8000) && TimecodeDelay <= int16(0x7FFF)
005003:000000:0000 Failed to save title 0 to file C:/Video/UNNAMED_DISC/title00.mkv
005004:000000:0000 0 titles saved, 1 failed
005037:000000:0204 Copy complete. 0 titles saved, 1 failed.
