0 titles saved, 1 failed
phnt0m
#1 Post by phnt0m » Wed Dec 02, 2015 1:18 am
I'm having trouble ripping a few movies. This log is for Insomnia, but the same thing happens with Finding Nemo. This is the first time I've encountered this error.
Debug log started at Wed Dec 02 00:24:28 2015 , written by MakeMKV v1.9.7 win(x64-release)
001005:0000 MakeMKV v1.9.7 win(x64-release) started
001004:0000 Debug logging enabled, log will be saved as C:\Users\Jimmy/MakeMKV_log.txt
DEBUG: Code 2147483648 at '(&byawYai[o+:&o:121265315
DAFD=PAAAADAAAAEABDQkEEwEBAQ==
DCE=dNDJndWVwunpClSMkIxwmmlhAvpjPFVjjhlZuc354sX06S68fCpKjBW0ZIWbP0INffeQepyoTU/oB9EO3dh3uP+GCY8s9sFGdoMQ3yr306tHr+yCz6UpW+DtdTJl6fuXEnuPSFwqFxOhAPm7T65pTbxvuZSSM9LhZg==
DCE=4w23mBpVPhoun2+lW/HTL3wo0PTtJ50d54V6toou0sBXnMocuktf64CqkdcWhNjQ1vEHGqhHuhzsc7snloPzrNKJGfz2v9RtyKNXedjicZib5ZUAmDkYK2s+Zs6fFOh7LCRZHVRvjGAYCB0fJ8Vr3lB8PW6S2Lp80A==
DISCID=1A3E1718F2F8803E8775696F140A6E5570BD3AB8
003307:0000 File 00055.mpls was added as title #0
003307:0000 File 00207.mpls was added as title #1
003307:0000 File 00208.mpls(3) was added as title #2
003309:0000 Title 00209.mpls(3) is equal to title 00208.mpls(3) and was skipped
003309:0000 Title 00210.mpls(3) is equal to title 00208.mpls(3) and was skipped
003309:0000 Title 00212.mpls(7) is equal to title 00208.mpls(3) and was skipped
003309:0000 Title 00211.mpls(2) is equal to title 00208.mpls(3) and was skipped
003309:0000 Title 00213.mpls(22) is equal to title 00208.mpls(3) and was skipped
003307:0000 File 00100.mpls was added as title #3
003307:0000 File 00119.mpls was added as title #4
003307:0000 File 00118.mpls was added as title #5
003307:0000 File 00120.mpls was added as title #6
003025:0000 Title #00000.m2ts has length of 12 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00003.m2ts has length of 11 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00004.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00005.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00010.m2ts has length of 23 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00092.m2ts has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003307:0000 File 00026.m2ts was added as title #7
003307:0000 File 00020.m2ts was added as title #8
003307:0000 File 00071.m2ts was added as title #9
003307:0000 File 00075.m2ts was added as title #10
003307:0000 File 00077.m2ts was added as title #11
003307:0000 File 00079.m2ts was added as title #12
003307:0000 File 00080.m2ts was added as title #13
005014:0000 Saving 1 titles into directory D:/DVDFab/Video
001003:0020 DEBUG: Code 3221225628 at E9,Jpf8H0>A%06{IEzRs`=~/M:121263521
001003:0020 DEBUG: Code 3221225628 at !5I5t"benE0vuI-B:29393953
001003:0020 DEBUG: Code 100864261 at P3n^?,M6"D@|*&j-:121269731
002003:0000 Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/BDMV/STREAM/00020.m2ts' at offset '15414521856'
002003:0000 Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/BDMV/STREAM/00020.m2ts' at offset '15416426496'
002003:0000 Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/BDMV/STREAM/00020.m2ts' at offset '15417735168'
002003:0000 Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/BDMV/STREAM/00020.m2ts' at offset '15417999360'
002003:0000 Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/BDMV/STREAM/00020.m2ts' at offset '15418257408'
002003:0000 Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/BDMV/STREAM/00020.m2ts' at offset '15419043840'
002003:0000 Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/BDMV/STREAM/00020.m2ts' at offset '15420684288'
002003:0000 Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/BDMV/STREAM/00020.m2ts' at offset '15421992960'
001003:0020 DEBUG: Code 0 at Y|IF&],tF&yI9BW_ayAs:121263038
001003:0020 DEBUG: Code 0 at R}R^X=e:}TnPR/)k|fqy:121262302
001003:0020 DEBUG: Code 0 at Y|IF&],tF&yI9BW_ayAs:213130559
001003:0020 DEBUG: Code 7530270 at Y|IF&],tF&yI9BW_ayAs:29393286
001003:0020 DEBUG: Code 0 at dTY}Ut\3Z+1[99lR]yBK&:29398967
005003:0000 Failed to save title 3 to file D:/DVDFab/Video/Insomnia_t03.mkv
005004:0080 0 titles saved, 1 failed
Application exited at Wed Dec 02 01:10:08 2015
Re: 0 titles saved, 1 failed
#2 Post by Woodstock » Wed Dec 02, 2015 1:32 pm
Mike will have to confirm with the debug codes, but the uncorrectable read errors are being reported by the drive itself, and the debug codes could be caused by errors the drive did NOT flag as errors.
phnt0m
#3 Post by phnt0m » Wed Dec 02, 2015 9:33 pm
Woodstock wrote:Mike will have to confirm with the debug codes, but the uncorrectable read errors are being reported by the drive itself, and the debug codes could be caused by errors the drive did NOT flag as errors.
I'm fairly new to this, so forgive my noob questions, but what does that mean? Errors with the discs? Faulty drive?
#4 Post by Woodstock » Wed Dec 02, 2015 10:30 pm
Simply put, errors in reading the disk.
Each sector of the disk has extra information in it to tell the hardware if it read the sector correctly. If that information is wrong, the drive is SUPPOSED to say, "I got an error". Usually it will try several times to get a correct read, before reporting an error (the "MEDIUM ERROR:L-EC UNCORRECTABLE ERROR" report).
Some drives are deciding to return what they got from the read, even if it is in error, and call it "good". When this happens, MakeMKV sees the data and says, "This isn't right... let's see what we can do to fix it up". This is where the debug messages come in, as MakeMKV tries different things to make the data work.
In your case, it seems the drive is returning both incorrect data and actual errors.
My first response to situations like this is cleaning the disk. Fingerprints can cause exactly what you are seeing, but minor scratches can, too. Spinning optical media is really a very fragile thing...
phnt0m
#5 Post by phnt0m » Thu Dec 03, 2015 2:43 am
Woodstock wrote:Simply put, errors in reading the disk.
Ah thank you for the explanation. I've cleaned the discs to no success. This happens with 3 different discs (2 are the same movie) every time I try to rip them.
#6 Post by Woodstock » Thu Dec 03, 2015 5:39 am
JUST those three disks, that is, are other disks ripping fine?
If other disks rip fine, then the problem is almost certainly with the disks that are failing.
Two copies of the same disk that have errors in the same area can be a manufacturing defect. If the errors occur in different areas, though, that is less likely.
phnt0m
#7 Post by phnt0m » Fri Dec 04, 2015 6:32 am
Woodstock wrote:JUST those three disks, that is, are other disks ripping fine?
I ripped a few other movies tonight, they're fine. I guess it must be the discs. It just threw me because it happened for the same movie on two different discs.
