Problematic HD-DVDs
planet1
Re: Problematic HD-DVDs
Post by planet1 »
Toshiba SD-H802A (FW: TS07)
1) U2 Rattle and Hum
2) Paramount
3) AVC (main title only)
4) DDplus 5.1 EX & DTS 6.1
5) Ripping fails on the main title (feature*.evo), the rest ist created successfully.
Video: MPEG4 Video (H264) 1920x1080 29.97fps [V: h264 high L4.1, yuv420p, 1920x1080]
Audio: DTS 48000Hz 7ch 1536kbps [A: dts-es, 48000 Hz, 6.1, 1536 kb/s]
Audio: DD+ 48000Hz 6ch 1536kbps [A: eac3, 48000 Hz, 5.1, 1536 kb/s]
MakeMKV v1.9.7 win(x64-release) started
Saving 7 titles into directory E:/Video/U2_RATTLE_AND_HUM
AV synchronization issues were found in file 'E:/Video/U2_RATTLE_AND_HUM/Main_Movie_t00.mkv' (title #1)
AV sync issue in stream 0 at 4744532:51:10.846 : video frame timecode differs by +632.604s
Failed to save title 0 to file E:/Video/U2_RATTLE_AND_HUM/Main_Movie_t00.mkv
AV synchronization issues were found in file 'E:/Video/U2_RATTLE_AND_HUM/Trailer_t01.mkv' (title #2)
AV sync issue in stream 1 at 0:00:00.013 with duration of 64ms : 2 early frame(s) dropped at start
AV synchronization issues were found in file 'E:/Video/U2_RATTLE_AND_HUM/Sizzle_Reel_t02.mkv' (title #3)
AV sync issue in stream 1 at 0:00:00.003 with duration of 53.333ms : 10 early frame(s) dropped at start
AV synchronization issues were found in file 'E:/Video/U2_RATTLE_AND_HUM/PARAMOUNTLOGO_t03.mkv' (title #4)
AV synchronization issues were found in file 'E:/Video/U2_RATTLE_AND_HUM/Main_Menu_t05.mkv' (title #6)
AV sync issue in stream 1 at 0:00:00.001 with duration of 85.333ms : 16 early frame(s) dropped at start
AV synchronization issues were found in file 'E:/Video/U2_RATTLE_AND_HUM/Warning_Cards_t06.mkv' (title #7)
AV sync issue in stream 1 at 0:00:00.012 with duration of 96ms : 3 early frame(s) dropped at start
6 titles saved, 1 failed
The disc was successfully ripped via DumpHD but that took ages. Interestingly even the decrypted files (disc structure) brought the exact same error in MakeMKV, so the problem could be related to a faulty video parser.
Faulty video parser where?
MakeMKV doesn't decode the video, it just compares time stamps between the video and audio streams.
nateson
Post by nateson »
1: Mutiny On The Bounty
2:Warner Bros
3:VC-1
4:DDP 5.1 surround
5:wont rip main feature, disc is in like new condition
6:Error 'Scsi error - MEDIUM ERROR:RANDOM POSITIONING ERROR' occurred while reading '/HVDVD_TS/PEVOB_1.EVO' at offset '686882816'
Muzer
Post by Muzer »
cozzmo wrote:1) The Fast and the Furious
2) Universal
3) Unknown
4) DDplus
5) Fails to open the disc
6) Debug Log:
DEBUG: Code 89 at ehvMHF8Z~[4 .:213131824
DEBUG: Code 0 at ehvMHF8Z~[4 .:121261773
I'm getting a similar thing with the same title on the latest version (not sure if duplicate reports are useful or not):
DEBUG: Code 89 at hnon#,D7+.{R7:213132261
DEBUG: Code 0 at hnon#,D7+.{R7:121261773
820am
Post by 820am »
yeah, something in the 1.10.1 is broke.
rolled back to 1.9.7 and it's working great
DaveSimon
Post by DaveSimon »
820am wrote:yeah, something in the 1.10.1 is broke.
Yeah, definitely seems to be something wrong with 1.10.1 in regards to HD-DVD (and/or the 360 HD-DVD drive). I was trying to make an mkv of a new HD-DVD I'd bought and it couldn't get past the initial scan after clicking the big "Open HD-DVD disc" button.
So I inserted a disc I'd used recently and it did the same so I knew there was a problem. But the last time I made an mkv was on w7 I think, whereas I'm now on w10 (w10 home, ver. 1511, os build: 10586.545). So thought it may just be my HD-DVD drive (not exactly a new bit of hardware).
But then I came on the forum and read the above post by 820am, so I found an older version in my download folder (v1.9.10) and tried that.
I swapped to a free USB 2.0 slot on my motherboard (the USB 3.0 port disconnecting itself), but after that I've had no problems. I managed to make an mkv of the new disc, it's extras and another previously used disc just to be sure.
Post by mike admin »
1.10.5 should fix these...
turnkit
Post by turnkit »
Two bonus titles in Red Dragon won't rip:
Saving 2 titles into directory /Volumes/MoviesWD/d HD Movies HD DVD/Red Dragon (2002) - missing bonus bad t15 t19/Scenes
AV synchronization issues were found in file '/Volumes/MoviesWD/d HD Movies HD DVD/Red Dragon (2002) - missing bonus bad t15 t19/Scenes/Extended_Scenes_t15.mkv' (title #16)
AV sync issue in stream 1 at 0:00:00 with duration of 8ms : encountered overlapping frame, audio skew is +8ms
AV sync issue in stream 2 at 0:00:00 with duration of 8ms : encountered overlapping frame, audio skew is +8ms
LIBMKV_TRACE: Exception: MKV_ASSERT: TimecodeDelay >= int16(0x8000) && TimecodeDelay <= int16(0x7FFF)
Failed to save title 15 to file /Volumes/MoviesWD/d HD Movies HD DVD/Red Dragon (2002) - missing bonus bad t15 t19/Scenes/Extended_Scenes_t15.mkv
AV synchronization issues were found in file '/Volumes/MoviesWD/d HD Movies HD DVD/Red Dragon (2002) - missing bonus bad t15 t19/Scenes/Alternate_Scenes_t19.mkv' (title #20)
AV sync issue in stream 1 at 0:00:00 with duration of 28ms : encountered overlapping frame, audio skew is +28ms
AV sync issue in stream 2 at 0:00:00 with duration of 28ms : encountered overlapping frame, audio skew is +28ms
Failed to save title 19 to file /Volumes/MoviesWD/d HD Movies HD DVD/Red Dragon (2002) - missing bonus bad t15 t19/Scenes/Alternate_Scenes_t19.mkv
0 titles saved, 2 failed
turnkit
Post by turnkit »
Does this error indicate a bug or a bad disc?: "LIBMKV_TRACE: Exception: MKV_ASSERT..."
DBG ASSERT: ,}W$VGL`2(F#]8E04:{_-8j at 4@F[kc#UA/>W6!@z:29395954
DBG ASSERT: ,}W$VGL`2(F#]8E04:{_-8j at nm<^QIS|WwJyX^@Zc:29396368
AV sync issue in stream 0 at 4744532:51:12.898 : video frame timecode differs by +632.604s
Failed to save title 0 to file /Volumes/MoviesWD/zzzz MakeMKV Rips/$ Server Processing_imac1/Lucky Slevin - bad main and some bonus/Main_Movie_t00.mkv
0 titles saved, 1 failed
turnkit
Post by turnkit »
Bonus content in Evan Almighty also fails in this same way.
Bad disc or bug to be fixed?
AV synchronization issues were found in file '/Volumes/MoviesWD/zzzz MakeMKV Rips/$ Server Processing_imac1/Evan Almighty (2007) - four bonus failed t27 28 30 32 all animal roundup/Animal_Round_Up_t27.mkv' (title #28)
AV sync issue in stream 1 at 0:00:00 with duration of 40.266ms : encountered overlapping frame, audio skew is +40.266ms
Failed to save title 27 to file /Volumes/MoviesWD/zzzz MakeMKV Rips/$ Server Processing_imac1/Evan Almighty (2007) - four bonus failed t27 28 30 32 all animal roundup/Animal_Round_Up_t27.mkv
AV synchronization issues were found in file '/Volumes/MoviesWD/zzzz MakeMKV Rips/$ Server Processing_imac1/Evan Almighty (2007) - four bonus failed t27 28 30 32 all animal roundup/Animal_Round_Up_t28.mkv' (title #29)
AV sync issue in stream 1 at 0:00:00 with duration of 44.3ms : encountered overlapping frame, audio skew is +44.3ms
Failed to save title 28 to file /Volumes/MoviesWD/zzzz MakeMKV Rips/$ Server Processing_imac1/Evan Almighty (2007) - four bonus failed t27 28 30 32 all animal roundup/Animal_Round_Up_t28.mkv
AV synchronization issues were found in file '/Volumes/MoviesWD/zzzz MakeMKV Rips/$ Server Processing_imac1/Evan Almighty (2007) - four bonus failed t27 28 30 32 all animal roundup/Animal_Round_Up_t29.mkv' (title #30)
AV sync issue in stream 1 at 0:00:00 with duration of 47.433ms : encountered overlapping frame, audio skew is +47.433ms
AV synchronization issues were found in file '/Volumes/MoviesWD/zzzz MakeMKV Rips/$ Server Processing_imac1/Evan Almighty (2007) - four bonus failed t27 28 30 32 all animal roundup/Animal_Round_Up_t30.mkv' (title #31)
AV sync issue in stream 1 at 0:00:00 with duration of 55.033ms : encountered overlapping frame, audio skew is +55.033ms
Failed to save title 30 to file /Volumes/MoviesWD/zzzz MakeMKV Rips/$ Server Processing_imac1/Evan Almighty (2007) - four bonus failed t27 28 30 32 all animal roundup/Animal_Round_Up_t30.mkv
AV synchronization issues were found in file '/Volumes/MoviesWD/zzzz MakeMKV Rips/$ Server Processing_imac1/Evan Almighty (2007) - four bonus failed t27 28 30 32 all animal roundup/Animal_Round_Up_t31.mkv' (title #32)
AV sync issue in stream 1 at 0:00:00 with duration of 44.266ms : encountered overlapping frame, audio skew is +44.266ms
AV synchronization issues were found in file '/Volumes/MoviesWD/zzzz MakeMKV Rips/$ Server Processing_imac1/Evan Almighty (2007) - four bonus failed t27 28 30 32 all animal roundup/Animal_Round_Up_t32.mkv' (title #33)
AV sync issue in stream 1 at 0:00:00 with duration of 40.366ms : encountered overlapping frame, audio skew is +40.366ms
Failed to save title 32 to file /Volumes/MoviesWD/zzzz MakeMKV Rips/$ Server Processing_imac1/Evan Almighty (2007) - four bonus failed t27 28 30 32 all animal roundup/Animal_Round_Up_t32.mkv
AV synchronization issues were found in file '/Volumes/MoviesWD/zzzz MakeMKV Rips/$ Server Processing_imac1/Evan Almighty (2007) - four bonus failed t27 28 30 32 all animal roundup/Animal_Round_Up_t33.mkv' (title #34)
turnkit
Post by turnkit »
The last two bonus titles of Friday Night Lights won't rip either.
DEBUG: Code 0 at @>8pB*(HjZu@`iQEl:29393953
Saving 2 titles into directory /Volumes/MoviesWD/d HD Movies HD DVD/Friday Night Lights (2004)/Scenes
AV synchronization issues were found in file '/Volumes/MoviesWD/d HD Movies HD DVD/Friday Night Lights (2004)/Scenes/PANTHER2_t23.mkv' (title #24)
AV sync issue in stream 1 at 0:00:00 with duration of 24.4ms : encountered overlapping frame, audio skew is +24.4ms
Failed to save title 23 to file /Volumes/MoviesWD/d HD Movies HD DVD/Friday Night Lights (2004)/Scenes/PANTHER2_t23.mkv
AV synchronization issues were found in file '/Volumes/MoviesWD/d HD Movies HD DVD/Friday Night Lights (2004)/Scenes/PANTHER3_t24.mkv' (title #25)
AV sync issue in stream 1 at 0:00:00 with duration of 2.3ms : encountered overlapping frame, audio skew is +2.3ms
Failed to save title 24 to file /Volumes/MoviesWD/d HD Movies HD DVD/Friday Night Lights (2004)/Scenes/PANTHER3_t24.mkv
turnkit
Post by turnkit »
I emailed this but in case this is better -- I think many, many HD-DVD titles are currently not able to be processed and might be fixed with some different identification algorithm:
Is there a way to change some of this post's fonts to a fixed width font? I could make it read a lot more easily.
I think the main issue is that MakeMKV is looking for HVA00001.VTI pattern but some discs only have files like HV011T01.EVO so MakeMKV only recognizes the discs as data discs not HD DVD Video discs and refuses to back them up or rip them.
See: https://imgur.com/a/2M8ud for screenshot showing MakeMKV 1.10.7 showing this Underworld HD DVD as a DATA DISC.
Recently I've imported several HD DVDs from Europe --"DFW - Dutch Filmworks" labeled -- several (but not all) of which when inserted in MakeMKV show up as "Type: Data" so they can't be backed up.
Since the MakeMKV Open Files... dialog filter for "Hd-dvd files" (sic) show:
DISCID.DAT
HVA00001.VTI
MKBROM.AACS
discatt.dat
and the discs which won't backup are missing, as far as I can tell, files with any of those patterns,
do you think a too restrictive file filter could be the reason I can process these discs?
Below are the files on two DFW discs - one that won't backup and, for comparison, one that will.
If the solution is as simple as changing the file filter, I would be glad to test a tweaked version of MakeMKV on my Mac OS system! (I am also in correspondence with another fellow ripping his large HD DVD collection using Windows and he has mentioned this "DATA" disc issue as a problem for him also for several of his discs.)
- turnkit
p.s. on an example of one the discs that did backup okay from this same distributor (see second directory listing below) I was surprised to see the message, "AACS directory not present, assuming unencrypted disc." Perhaps many of these discs are authored with very minimal sophistication.
UNDERWORLD
- WON'T BACKUP - Seen as a data disc.
total 12
dr-xr-xr-x 3 turnkit staff 88 Oct 29 2007 .
drwxr-xr-x@ 8 root wheel 306 Oct 31 13:54 ..
dr-xr-xr-x 2 turnkit staff 3212 Oct 29 2007 HVDVD_TS
./HVDVD_TS:
total 52247676
dr-xr-xr-x 2 turnkit staff 3212 Oct 29 2007 .
dr-xr-xr-x 3 turnkit staff 88 Oct 29 2007 ..
-r-xr-xr-x 1 turnkit staff 20480 Oct 29 2007 HV000I01.BUP
-r-xr-xr-x 1 turnkit staff 20480 Oct 29 2007 HV000I01.IFO
-r-xr-xr-x 1 turnkit staff 239810560 Oct 29 2007 HV000M02.EVO
-r-xr-xr-x 1 turnkit staff 38912 Oct 29 2007 HV001I01.BUP
-r-xr-xr-x 1 turnkit staff 38912 Oct 29 2007 HV001I01.IFO
-r-xr-xr-x 1 turnkit staff 1072920576 Oct 29 2007 HV001T01.EVO
-r-xr-xr-x 1 turnkit staff 1073068032 Oct 29 2007 HV001T02.EVO
-r-xr-xr-x 1 turnkit staff 120127488 Oct 29 2007 HV001T03.EVO
-r-xr-xr-x 1 turnkit staff 14336 Oct 29 2007 HV002I01.BUP
-r-xr-xr-x 1 turnkit staff 14336 Oct 29 2007 HV002I01.IFO
-r-xr-xr-x 1 turnkit staff 153769984 Oct 29 2007 HV002T01.EVO
-r-xr-xr-x 1 turnkit staff 20480 Oct 29 2007 HV003I01.BUP
-r-xr-xr-x 1 turnkit staff 20480 Oct 29 2007 HV003I01.IFO
-r-xr-xr-x 1 turnkit staff 1046515712 Oct 29 2007 HV003T01.EVO
-r-xr-xr-x 1 turnkit staff 18432 Oct 29 2007 HV004I01.BUP
-r-xr-xr-x 1 turnkit staff 18432 Oct 29 2007 HV004I01.IFO
-r-xr-xr-x 1 turnkit staff 722944 Oct 29 2007 HV004M01.EVO
-r-xr-xr-x 1 turnkit staff 303050752 Oct 29 2007 HV004T01.EVO
-r-xr-xr-x 1 turnkit staff 20480 Oct 29 2007 HV005I01.BUP
-r-xr-xr-x 1 turnkit staff 20480 Oct 29 2007 HV005I01.IFO
-r-xr-xr-x 1 turnkit staff 770048 Oct 29 2007 HV005M01.EVO
-r-xr-xr-x 1 turnkit staff 659519488 Oct 29 2007 HV005T01.EVO
-r-xr-xr-x 1 turnkit staff 14336 Oct 29 2007 HV006I01.BUP
-r-xr-xr-x 1 turnkit staff 14336 Oct 29 2007 HV006I01.IFO
-r-xr-xr-x 1 turnkit staff 85983232 Oct 29 2007 HV006T01.EVO
-r-xr-xr-x 1 turnkit staff 14336 Oct 29 2007 HV007I01.BUP
-r-xr-xr-x 1 turnkit staff 14336 Oct 29 2007 HV007I01.IFO
-r-xr-xr-x 1 turnkit staff 219742208 Oct 29 2007 HV007T01.EVO
-r-xr-xr-x 1 turnkit staff 43008 Oct 29 2007 HV008I01.BUP
-r-xr-xr-x 1 turnkit staff 43008 Oct 29 2007 HV008I01.IFO
-r-xr-xr-x 1 turnkit staff 731136 Oct 29 2007 HV008M01.EVO
-r-xr-xr-x 1 turnkit staff 1073137664 Oct 29 2007 HV008T01.EVO
-r-xr-xr-x 1 turnkit staff 1073352704 Oct 29 2007 HV008T02.EVO
-r-xr-xr-x 1 turnkit staff 72558592 Oct 29 2007 HV008T03.EVO
-r-xr-xr-x 1 turnkit staff 14336 Oct 29 2007 HV009I01.BUP
-r-xr-xr-x 1 turnkit staff 14336 Oct 29 2007 HV009I01.IFO
-r-xr-xr-x 1 turnkit staff 306298880 Oct 29 2007 HV009T01.EVO
-r-xr-xr-x 1 turnkit staff 14336 Oct 29 2007 HV010I01.BUP
-r-xr-xr-x 1 turnkit staff 14336 Oct 29 2007 HV010I01.IFO
-r-xr-xr-x 1 turnkit staff 121073664 Oct 29 2007 HV010T01.EVO
-r-xr-xr-x 1 turnkit staff 79872 Oct 29 2007 HV011I01.BUP
-r-xr-xr-x 1 turnkit staff 79872 Oct 29 2007 HV011I01.IFO
-r-xr-xr-x 1 turnkit staff 1482752 Oct 29 2007 HV011M01.EVO
-r-xr-xr-x 1 turnkit staff 1073661952 Oct 29 2007 HV011T01.EVO
-r-xr-xr-x 1 turnkit staff 1072879616 Oct 29 2007 HV011T02.EVO
-r-xr-xr-x 1 turnkit staff 1072967680 Oct 29 2007 HV011T03.EVO
-r-xr-xr-x 1 turnkit staff 1072836608 Oct 29 2007 HV011T04.EVO
-r-xr-xr-x 1 turnkit staff 1072971776 Oct 29 2007 HV011T05.EVO
-r-xr-xr-x 1 turnkit staff 1072250880 Oct 29 2007 HV011T06.EVO
-r-xr-xr-x 1 turnkit staff 1072742400 Oct 29 2007 HV011T07.EVO
-r-xr-xr-x 1 turnkit staff 1072982016 Oct 29 2007 HV011T08.EVO
-r-xr-xr-x 1 turnkit staff 1072594944 Oct 29 2007 HV011T09.EVO
-r-xr-xr-x 1 turnkit staff 1072939008 Oct 29 2007 HV011T10.EVO
-r-xr-xr-x 1 turnkit staff 1073156096 Oct 29 2007 HV011T11.EVO
-r-xr-xr-x 1 turnkit staff 1072490496 Oct 29 2007 HV011T12.EVO
-r-xr-xr-x 1 turnkit staff 1073537024 Oct 29 2007 HV011T13.EVO
-r-xr-xr-x 1 turnkit staff 1073586176 Oct 29 2007 HV011T14.EVO
-r-xr-xr-x 1 turnkit staff 1073047552 Oct 29 2007 HV011T15.EVO
-r-xr-xr-x 1 turnkit staff 1072601088 Oct 29 2007 HV011T16.EVO
-r-xr-xr-x 1 turnkit staff 1073020928 Oct 29 2007 HV011T17.EVO
-r-xr-xr-x 1 turnkit staff 885274624 Oct 29 2007 HV011T18.EVO
HOME OF THE BRAVE
- BACKED UP OKAY - Seen as HD-DVD.
total 16
dr-xr-xr-x 4 turnkit staff 136 Jan 9 2008 .
drwxr-xr-x@ 8 root wheel 306 Oct 31 14:06 ..
dr-xr-xr-x 2 turnkit staff 724 Jan 9 2008 ADV_OBJ
dr-xr-xr-x 2 turnkit staff 2760 Jan 9 2008 HVDVD_TS
./ADV_OBJ:
total 3636
dr-xr-xr-x 2 turnkit staff 724 Jan 9 2008 .
dr-xr-xr-x 4 turnkit staff 136 Jan 9 2008 ..
-r-xr-xr-x 1 turnkit staff 128 Dec 12 2007 DISCID.DAT
-r-xr-xr-x 1 turnkit staff 26816 Jan 9 2008 VPLST000.XPL
-r-xr-xr-x 1 turnkit staff 350 Nov 29 2007 extras.xmf
-r-xr-xr-x 1 turnkit staff 55756 Apr 12 1994 font.ttf
-r-xr-xr-x 1 turnkit staff 10406 Nov 29 2007 menu-special.xmu
-r-xr-xr-x 1 turnkit staff 26295 Nov 30 2007 menu.xmu
-r-xr-xr-x 1 turnkit staff 1430376 Nov 28 2007 popupMenu.aca
-r-xr-xr-x 1 turnkit staff 560 Nov 28 2007 popupMenu.xmf
-r-xr-xr-x 1 turnkit staff 3476 Dec 1 2007 script-extras.js
-r-xr-xr-x 1 turnkit staff 14478 Dec 3 2007 script-special.js
-r-xr-xr-x 1 turnkit staff 27844 Dec 3 2007 script.js
-r-xr-xr-x 1 turnkit staff 242138 Nov 28 2007 specialMenu.aca
-r-xr-xr-x 1 turnkit staff 591 Nov 29 2007 specialMenu.xmf
./HVDVD_TS:
total 55567496
dr-xr-xr-x 2 turnkit staff 2760 Jan 9 2008 .
-r-xr-xr-x 1 turnkit staff 6144 Dec 12 2007 EVO-B-Roll.BUP
-r-xr-xr-x 1 turnkit staff 691312640 Dec 12 2007 EVO-B-Roll.EVO
-r-xr-xr-x 1 turnkit staff 6144 Dec 12 2007 EVO-B-Roll.MAP
-r-xr-xr-x 1 turnkit staff 18432 Dec 12 2007 EVOB-Bombmaker.BUP
-r-xr-xr-x 1 turnkit staff 3071162368 Dec 12 2007 EVOB-Bombmaker.EVO
-r-xr-xr-x 1 turnkit staff 18432 Dec 12 2007 EVOB-Bombmaker.MAP
-r-xr-xr-x 1 turnkit staff 2048 Dec 12 2007 EVOB-BreinBaf.BUP
-r-xr-xr-x 1 turnkit staff 61396992 Dec 12 2007 EVOB-BreinBaf.EVO
-r-xr-xr-x 1 turnkit staff 2048 Dec 12 2007 EVOB-BreinBaf.MAP
-r-xr-xr-x 1 turnkit staff 22528 Dec 12 2007 EVOB-Butcher.BUP
-r-xr-xr-x 1 turnkit staff 3575470080 Dec 12 2007 EVOB-Butcher.EVO
-r-xr-xr-x 1 turnkit staff 22528 Dec 12 2007 EVOB-Butcher.MAP
-r-xr-xr-x 1 turnkit staff 2048 Dec 12 2007 EVOB-DFW.BUP
-r-xr-xr-x 1 turnkit staff 2041856 Dec 12 2007 EVOB-DFW.EVO
-r-xr-xr-x 1 turnkit staff 2048 Dec 12 2007 EVOB-DFW.MAP
-r-xr-xr-x 1 turnkit staff 43008 Dec 12 2007 EVOB-Feature-0.BUP
-r-xr-xr-x 1 turnkit staff 14717468672 Dec 12 2007 EVOB-Feature-0.EVO
-r-xr-xr-x 1 turnkit staff 43008 Dec 12 2007 EVOB-Feature-0.MAP
-r-xr-xr-x 1 turnkit staff 8192 Dec 12 2007 EVOB-Feature-1.BUP
-r-xr-xr-x 1 turnkit staff 1830615040 Dec 12 2007 EVOB-Feature-1.EVO
-r-xr-xr-x 1 turnkit staff 8192 Dec 12 2007 EVOB-Feature-1.MAP
-r-xr-xr-x 1 turnkit staff 2048 Dec 12 2007 EVOB-Kijkw.BUP
-r-xr-xr-x 1 turnkit staff 4794368 Dec 12 2007 EVOB-Kijkw.EVO
-r-xr-xr-x 1 turnkit staff 2048 Dec 12 2007 EVOB-Kijkw.MAP
-r-xr-xr-x 1 turnkit staff 18432 Dec 12 2007 EVOB-Schwarzkopf.BUP
-r-xr-xr-x 1 turnkit staff 3189721088 Dec 12 2007 EVOB-Schwarzkopf.EVO
-r-xr-xr-x 1 turnkit staff 18432 Dec 12 2007 EVOB-Schwarzkopf.MAP
-r-xr-xr-x 1 turnkit staff 4096 Dec 12 2007 EVOB-Special-menu.BUP
-r-xr-xr-x 1 turnkit staff 398626816 Dec 12 2007 EVOB-Special-menu.EVO
-r-xr-xr-x 1 turnkit staff 4096 Dec 12 2007 EVOB-Special-menu.MAP
-r-xr-xr-x 1 turnkit staff 2048 Dec 12 2007 EVOB-Tr-1408.BUP
-r-xr-xr-x 1 turnkit staff 190658560 Dec 12 2007 EVOB-Tr-1408.EVO
-r-xr-xr-x 1 turnkit staff 2048 Dec 12 2007 EVOB-Tr-1408.MAP
-r-xr-xr-x 1 turnkit staff 2048 Dec 12 2007 EVOB-Tr-Home-Brave.BUP
-r-xr-xr-x 1 turnkit staff 190492672 Dec 12 2007 EVOB-Tr-Home-Brave.EVO
-r-xr-xr-x 1 turnkit staff 2048 Dec 12 2007 EVOB-Tr-Home-Brave.MAP
-r-xr-xr-x 1 turnkit staff 2048 Dec 12 2007 EVOB-Tr-Hunting.BUP
-r-xr-xr-x 1 turnkit staff 153292800 Dec 12 2007 EVOB-Tr-Hunting.EVO
-r-xr-xr-x 1 turnkit staff 2048 Dec 12 2007 EVOB-Tr-Hunting.MAP
-r-xr-xr-x 1 turnkit staff 2048 Dec 12 2007 EVOB-Tr-Mist.BUP
-r-xr-xr-x 1 turnkit staff 189163520 Dec 12 2007 EVOB-Tr-Mist.EVO
-r-xr-xr-x 1 turnkit staff 2048 Dec 12 2007 EVOB-Tr-Mist.MAP
-r-xr-xr-x 1 turnkit staff 2048 Dec 12 2007 EVOB-Tr-Rambo4.BUP
-r-xr-xr-x 1 turnkit staff 184031232 Dec 12 2007 EVOB-Tr-Rambo4.EVO
-r-xr-xr-x 1 turnkit staff 2048 Dec 12 2007 EVOB-Tr-Rambo4.MAP
-r-xr-xr-x 1 turnkit staff 14336 Dec 12 2007 HVA00001.BUP
-r-xr-xr-x 1 turnkit staff 14336 Jan 9 2008 HVA00001.VTI
turnkit
Post by turnkit »
madpoet wrote:Been a while since I hit problem disk!
1) Charlie and the Chocolate Factory
2) WB
3) Not sure
4) TrueHD
5) Fails to open disk
6)
DEBUG: Code 0 at :)_9A/U}b6J3s:213132560
DEBUG: Code 23 at :)_9A/U}b6J3s:121263820
DEBUG: Code 0 at :)_9A/U}b6J3s:121261773
Charlie and the Chocolate Factory HD DVD also get "Failed to open disc"
MakeMKV v1.12.2 darwin(x64-release) started
Debug logging enabled, log will be saved as /Volumes/SSD/user/MakeMKV_log.txt
Optical drive "HD-DVD-R-DL TOSHIBA DVD/HDW SD-L902A TO35d" opened in OS access mode.
Optical drive "HD-DVD-ROM HL-DT-ST BDDVDRW GGC-H20L 1.03d" opened in OS access mode.
DEBUG: Code 0 at dv|;M,gFtH!\S:121264671
DEBUG: Code 23 at dv|;M,gFtH!\S:29395908
DEBUG: Code 0 at dv|;M,gFtH!\S:29393585
LogicalSpock
Post by LogicalSpock »
1) Chicago and Earth, Wind & Fire Live at The Greek Theatre
2) image
3) Not sure
4) DD Plus 5.1 / DD Plus 2.0
5) Does not recognize disc at all (Type: No disc)
6)
File manager reads the disc fine:
Root directories:
AACS
AACS_BAK
HDDVD_TS
Under HDDVD_TS:
HV000I01.BUP 14KB
HV000I01.IFO 14KB
HV000M02.EVO 1,376KB
HV001I01.BUP 104KB
HV001I01.IFO 104KB
HV001M01.EVO 720KB
** then 25 EVO files HV001T01.EVO to HV001T25.EVO (1 GB in length each)
HV001T26.EVO 43,238 KB
HV002I01.BUP 16 KB
HV002I01.IFO 16KB
HV002T01.EVO 778,596 KB
HV003I01.BUP 14 KB
HV003I01.IFO 14 KB
HV003T01.EVO 56,168 KB
I can copy any of the above 25 1GB EVO files to my hard drive, but MakeMKV does not recognize any of them if I browse to the storage folder. I can open the copied EVO file with VLC which shows as a 6:xx minute video and shows as playing, but it's a black screen with no sound.
I just purchased MakeMKV to convert my old HD-DVD collection. I've successfully converted 11 movies prior to this snafu. This disc is not a movie, but rather a live concert with a different EVO file structure compared to the movies. The main feature seems to consist of 26 EVO equal length 1 GB files so that may be part of the problem. Plays fine via the Xbox HD-DVD player on my XBox 360.
ranger671
Post by ranger671 »
I have a number of HD-DVD's that I would like to salvage. If you don't mind, what drive are you using to read these discs into your system and how are you making the connection(sata, usb, etc.)?
