Direct support for transcoding ?
PerryNien
#1 Post by PerryNien » Wed Feb 18, 2009 2:40 pm
Will "makemkv" support transcoding directly ?
Re: Direct support for transcoding ?
#2 Post by mike admin » Thu Feb 19, 2009 8:16 am
Hi Perry,
MakeMKV is a format converter, "transcoder". It converts the video from disc into MKV files, preserving most information but not changing it in any way.
May be I'm not getting your question right...?
Thank you
PerryNien
#3 Post by PerryNien » Fri Feb 20, 2009 6:52 am
Hi Mike,
Since the file size of BD is huge, some people would like to re-encode the video with lower bit-rate
due to disk space issue. If "makemke"can support video H.264 re-encode (or VC1 -> H.264 transcode")
in the transformation process, it will be great.
#4 Post by mike admin » Thu Feb 26, 2009 8:36 am
re-encoding takes a lot of time so it is not possible to re-encode video at drive read rate. There are many freeware tools to re-encode video.
