Error Saving File
kevwatt1
Error Saving File
Post by kevwatt1 » Fri Nov 27, 2015 8:45 pm
Hi I am having an issue with several blu rays during the evaluation
An example log of the Godfather Part II
Can you help? I have tried multiple blu ray drives and the disc is immaculate.
Debug log started at Fri Nov 27 19:31:18 2015 , written by MakeMKV v1.9.7 win(x64-release)
001005:0000 MakeMKV v1.9.7 win(x64-release) started
001004:0000 Debug logging enabled, log will be saved as C:\Users\Scott/MakeMKV_log.txt
005053:0308 This functionality is shareware. You may evaluate it for 30 days after what you would need to purchase an activation key if you like the functionality. Do you want to start evaluation period now?
005050:0000 Evaluation version, 30 day(s) out of 30 remaining
DEBUG: Code 2147483648 at '(&byawYai[o+:&o:121265315
DAFD=PAAAADAAAAEABDQEEAQEEAQ==
DCE=+Cd6FseQnbxx/dpnntbXOemwICWj+Lgcvij+dqCWHh7USXDucb2Cy22XgRSlxZSofufN5qPwEQlqHp2YrUnt1p2X5j8+L+x6R8Jqq+u9XaJ17ZPmnrOgG0Kp471HudxTqRV9rSESZalfm+NlKnZWZ/YnZ6rKZIEItQ==
DISCID=C0E21AF4BA91969CC36F9CB6A662A38790C12A0C
003307:0000 File 00205.mpls was added as title #0
003025:0000 Title #00008.mpls has length of 29 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003307:0000 File 00214.mpls was added as title #1
003307:0000 File 00009.mpls was added as title #2
003025:0000 Title #00006.mpls has length of 50 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003307:0000 File 00100.mpls was added as title #3
001003:0020 DEBUG: Code 100860416 at P3n^?,M6"D@|*&j-:121269731
002003:0000 Error 'Scsi error - MEDIUM ERROR:NO SEEK COMPLETE' occurred while reading '/BDMV/STREAM/00016.m2ts' at offset '0'
001003:0020 DEBUG: Code 0 at >t^Ce?LiPjam);|}k^:29393677
001003:0020 DEBUG: Code 0 at b%40<?Q_Q+xef0)Z:121263314
001003:0020 DEBUG: Code 0 at MP1b5_?zwP&s#KC:121270927
001003:0020 DEBUG: Code 0 at NikNri_3ZEg&j"&(:213114206
003016:0000 Title #00200.mpls was skipped
003025:0000 Title #00003.mpls has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00019.m2ts has length of 9 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00002.m2ts has length of 23 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00010.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003307:0000 File 00017.m2ts was added as title #4
003025:0000 Title #00012.m2ts has length of 11 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00013.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00011.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00004.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00005.m2ts has length of 11 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00026.m2ts has length of 27 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00025.m2ts has length of 25 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00024.m2ts has length of 8 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00022.m2ts has length of 90 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00003.m2ts has length of 29 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00020.m2ts has length of 51 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003307:0000 File 00018.m2ts was added as title #5
003016:0000 Title #00016.m2ts was skipped
003307:0000 File 00001.m2ts was added as title #6
003025:0000 Title #00034.m2ts has length of 50 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00033.m2ts has length of 9 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00007.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00009.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00023.m2ts has length of 57 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00021.m2ts has length of 26 seconds which is less than minimum title length of 120 seconds and was therefore skipped
001003:0020 DEBUG: Code 233 at qeVDkhy1gYyycMiWr004z7VQ:0
001003:0020 DEBUG: Code 233 at EyFXzuywofWz8jquIwTpzv+R:0
001003:0020 DEBUG: Code 233 at Ucngl2GNdnr+OxYxfzqdYDBE:0
001003:0020 DEBUG: Code 233 at xireyzyuf1mpxnyxdLPr8fqE:0
001003:0020 DEBUG: Code 233 at cPzARdR7b/jha0xxx71tz6SH:0
001003:0020 DEBUG: Code 233 at 9MCcZ7v5xQfKMMJyMmKuvE85:0
001003:0020 DEBUG: Code 233 at J/xzg/F4X1kKieD8Nivn7taE:0
001003:0020 DEBUG: Code 233 at vCOtDK2LYyYiQCAQWZnkLBGo:0
001003:0020 DEBUG: Code 233 at sqqB/YVJxqLUf/o4tsE8uTfj:0
001003:0020 DEBUG: Code 233 at pZ19tSz3HGLoLg8dMLpeXIlq:0
005014:0000 Saving 1 titles into directory C:/Users/Scott/Desktop
001003:0020 DEBUG: Code 3221225628 at E9,Jpf8H0>A%06{IEzRs`=~/M:121263521
001003:0020 DEBUG: Code 3221225628 at !5I5t"benE0vuI-B:29393953
001003:0020 DEBUG: Code 0 at .<0mjkC1+1"Mk9s$R:29398438
002003:0000 Error 'Internal error - Operation was cancelled (112)' occurred while reading '/BDMV/STREAM/00014.m2ts' at offset '0'
001003:0020 DEBUG: Code 0 at R}R^X=e:}TnPR/)k|fqy:29396713
001003:0020 DEBUG: Code 0 at Y|IF&],tF&yI9BW_ayAs:121262049
001003:0020 DEBUG: Code 0 at Y|IF&],tF&yI9BW_ayAs:213130168
001003:0020 DEBUG: Code 0 at Y|IF&],tF&yI9BW_ayAs:29393286
001003:0020 DEBUG: Code 0 at zoS7Y}D(3k"u8XBA@{Y=:213139253
001003:0020 DEBUG: Code 0 at @$Q+:`RP".C'YHv#:213130720
001003:0020 DEBUG: Code 0 at dTY}Ut\3Z+1[99lR]yBK&:121266902
001003:0020 DEBUG: Code 0 at @$Q+:`RP".C'YHv#:29394137
001003:0020 DEBUG: Code 0 at Y|IF&],tF&yI9BW_ayAs:213130306
001003:0020 DEBUG: Code 0 at OjfmrkeXG#1I)*q8!g@tD:29393999
001003:0020 DEBUG: Code 0 at OjfmrkeXG#1I)*q8!g@tD:29394551
001003:0020 DEBUG: Code 117506160 at IGk^,-\RY\YcL,kZ:121274584
001003:0020 DEBUG: Code 0 at =yzS;G;(L8eK`@3y!%:121262325
005003:0000 Failed to save title 3 to file C:/Users/Scott/Desktop/Point_Break_t03.mkv
005004:0080 0 titles saved, 1 failed
001003:0020 DEBUG: Code 100864256 at P3n^?,M6"D@|*&j-:121269731
001003:0020 DEBUG: Code 100864256 at ^}@1t{|3_ima5dQlmn:213132100
001003:0020 DEBUG: Code 100864256 at ^}@1t{|3_ima5dQlmn:29393930
002003:0000 Error 'Scsi error - MEDIUM ERROR:UNRECOVERED READ ERROR' occurred while reading '/BDMV/STREAM/00003.m2ts' at offset '37206994944'
DCE=bscgLZ/d3wcTSwkW6drRetaHgGqaAtRKpzssZEvB3K3C+T5cHXpDj0wSKoqB3q0MSqCMPatjY4hrmvpUiyHlzCtl3KtWM2JPPNTxJsYeS5zdah3PrNCbeWbbSsXwUTDjpYUEGtMY3VtceLVD8RupNe3n/phurB9VGQ==
002004:0000 Error 'Scsi error - MEDIUM ERROR:NO SEEK COMPLETE' occurred while issuing SCSI command 280..001 to device 'SPTI:\Device\CdRom1'
DEBUG: Code 0 at {hkmYV_dv,0o,[hm0":213133825
001003:0020 DEBUG: Code 0 at {hkmYV_dv,0o,[hm0":121264464
001003:0020 DEBUG: Code 0 at {hkmYV_dv,0o,[hm0":121262647
DCE=j7eDSqNWaJqFCSH/6s4tyTqAKwIb90qqjotG+znl1yMu5qORffNf0v4QmeuGXty9a59AeqTvpY/AHHAP+o0qMcItkZYAc6wCtdRdhZoUBYKZoFJB/EvI8HjCsGvNzAmGM4xV+3mBAgjnLguWNENhp/NvRkKKkb9OPQ==
001003:0020 DEBUG: Code 100864256 at ^}@1t{|3_ima5dQlmn:29396575
002003:0000 Error 'Scsi error - MEDIUM ERROR:UNRECOVERED READ ERROR' occurred while reading '/AACS/Content001.cer' at offset '0'
001003:0020 DEBUG: Code 0 at +Eo-L?7<h0Yg59B:121262026
001003:0020 DEBUG: Code 0 at +Eo-L?7<h0Yg59B:29393608
001003:0020 DEBUG: Code 1 at +Eo-L?7<h0Yg59B:29395172
005084:0000 Failed to load content hash table, unable to verify integrity of M2TS files.
DISCID=C8084C65ED8AE6138EAD6C1DC781FCB4426291A3
003307:0000 File 00000.mpls was added as title #0
003025:0000 Title #00001.mpls has length of 64 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00029.mpls has length of 40 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00030.mpls has length of 40 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00002.m2ts has length of 14 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00000.m2ts has length of 34 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00001.m2ts has length of 29 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00004.m2ts has length of 29 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00006.m2ts has length of 11 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00007.m2ts has length of 29 seconds which is less than minimum title length of 120 seconds and was therefore skipped
002003:0000 Error 'Scsi error - MEDIUM ERROR:NO SEEK COMPLETE' occurred while reading '/BDMV/STREAM/00003.m2ts' at offset '24509546496'
001003:0020 DEBUG: Code 0 at Y|IF&],tF&yI9BW_ayAs:121263038
001003:0020 DEBUG: Code 0 at R}R^X=e:}TnPR/)k|fqy:121262302
001003:0020 DEBUG: Code 0 at Y|IF&],tF&yI9BW_ayAs:213130559
001003:0020 DEBUG: Code 11967552 at Y|IF&],tF&yI9BW_ayAs:29393286
001003:0020 DEBUG: Code 0 at dTY}Ut\3Z+1[99lR]yBK&:29398967
005003:0000 Failed to save title 0 to file C:/Users/Scott/Desktop/The_Godfather_Part_II_t00.mkv
Application exited at Fri Nov 27 20:40:48 2015
Re: Error Saving File
Post by Woodstock » Sat Nov 28, 2015 1:34 am
This is a troubling error message, and you are getting it a lot:
When told to seek to the beginning of a file, your drive can't find it.
This can be a disk issue (dirt, scratches, and some copy protection schemes that use fake titles can all do this), or it could be a drive issue.
Is it occurring on one specific disk, or several?
kevwatt1
Post by kevwatt1 » Tue Dec 01, 2015 5:27 pm
Sorry for the late reply, this is happening only on about 1 in 10 so far. I have two NEW external blu ray drives and it fails on both, also I don't see any marks on the disks.
kevwatt1
Post by kevwatt1 » Tue Dec 01, 2015 5:29 pm
Strange thing about the gosfather part 2 is that its part of a box set and parts 1 and 3 ripped ok, you would think they had the same copy protection?
Post by Woodstock » Tue Dec 01, 2015 7:38 pm
Frankly, it's just as likely that they have manufacturing errors. When I bought the Hercules TV series set a couple of years ago, one disk wasn't rippable. Got the set replaced, same disk was unrippable. Finally rented that one disk... and it was barely rippable, after I dug out a portable DVD drive to do it. All three disks had the same manufacturing defect to one degree or another, but one drive was able to "see through it" well enough to rip the missing episode.
kevwatt1
Post by kevwatt1 » Wed Dec 02, 2015 11:33 am
Thanks, can you or anyone recommend a drive that has 100% success rate?
Post by Woodstock » Wed Dec 02, 2015 1:36 pm
100% success with random disks is not a likely happening. I've had very good luck with LG drives, but others say LG suck. I also have a Samsung BD drive, and a Sony DVD.
Sometimes, the Sony is the only thing that can read a particular DVD, because it is "just" a DVD reader. BD drives can read DVDs most of the time, but not always. The difference in the laser color IS significant some times.
kevwatt1
Post by kevwatt1 » Thu Dec 03, 2015 2:58 pm
Our movie taste is maybe different :), but have you had success in ripping Jumper, Life of Pi, Star Trek Into Darkness, Street kings, Point Break, The Hunger Games or The Godfather Part II? (al Bluray)
Post by Woodstock » Thu Dec 03, 2015 4:57 pm
ST:Into Darkness ripped just fine as both 2D and 3D. Jumper and Life of Pi I got on DVD, so they don't count. No experience with the others...
