American Ultra US Playlist
ncarusojr
Post by ncarusojr » Thu Nov 26, 2015 1:16 am
Does anyone have the correct playlist for the American Ultra version that comes in the red envelope. Thanks for any help
penguinsaregood
Re: American Ultra US Playlist
Post by penguinsaregood » Thu Nov 26, 2015 8:48 pm
Purchased from Amazon
UPC: 0 31398 23179 0
Title information
Name: American Ultra (English)
Source file name: 00441.mpls
Duration: 1:35:41
Chapters count: 16
Segment count: 15
Segment map: 502,504,501,511,509,510,515,503,512,514,508,505,513,507,506
File name: American_Ultra_t111.mkv
ncarusojr
Post by ncarusojr » Fri Nov 27, 2015 1:06 pm
Not the right version. 441.mpls starts with 510. Matter of fact all of the netf---- playlists start with 510. I check through all the playlists that come up and none start with 502. I thought I could just matchup the playlist that way. But sadly no. Thanks
ekael86
Post by ekael86 » Fri Nov 27, 2015 11:16 pm
I believe this is correct as I have just gone through it and tried to piece it together correctly. Don't trust me 100% on this though.
Source File Name: 00592.mpls
Segment map: 510, 505, 518, 503, 515, 504, 507, 513, 501, 511, 519, 516, 514, 509, 512, 520,517, 506, 508, 502
Benjamin99
Post by Benjamin99 » Sat Nov 28, 2015 1:51 am
ekael86 wrote:I believe this is correct as I have just gone through it and tried to piece it together correctly. Don't trust me 100% on this though.
My copy skips from 00590.mpls to 00593.mpls.
penguinsaregood wrote:Purchased from Amazon
Title information
Duration: 1:35:41
Chapters count: 16
Segment count: 15
This one doesn't match the 00441.mpls I have at all either.
Mr.SuntoryTime
Post by Mr.SuntoryTime » Sat Nov 28, 2015 2:05 am
Title information
Duration: 1:35:41
Chapters count: 16
Segment count: 15
Ya, this wont work for me either. have a disk from the crimson kiosk fyi. trying 00502 will advise
xbmcuser
Post by xbmcuser » Sat Nov 28, 2015 5:21 pm
Source file name: 00593.mpls
Duration: 1:35:41
Chapters count: 16
Segment count: 20
Segment map: 510,505,518,503,515,504,507,513,501,511,519,516,514,509,512,520,517,506,508,502
Researching this it seems the best/fastest way to find the correct segment map is to first backup the entire disc, which should be of normal size. Then knowing you need to work with a certain subset of segments your job is to now figure out their correct order, which the superset can be found here: BDMV/STREAM. You should be able to find each segment's starting point and length by referencing the movie.
Mondays
Post by Mondays » Wed Dec 16, 2015 3:47 pm
AnyDVD confirms 00593.mpls on netflix disk
