The Mad Max Anthology
XxShortRoundxX
Post by XxShortRoundxX »
I can't copy any of the 4 discs on the new Mad Max anthology. Anyone else having this issue or does anyone know why?
Re: The Mad Max Anthology
See my signature for how to give us some hope of answering your question.
powrhaus
Post by powrhaus »
I just got the anthology today from Amazon.
The 1st disc (Mad Max) cannot be read properly. I got the errors below before I canceled the rip.
DEBUG: Code 4279336995 at 5Q45#y{(<sIV_|':121262877
DEBUG: Code 0 at ]K}<{g 5\^[xCzt/:29400163
Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/BDMV/STREAM/00075.m2ts' at offset '2923886592'
Error 'OS error - STATUS_DEVICE_DATA_ERROR' occurred while reading '\Device\CdRom0' at offset '2923886592'
DEBUG: Code 3221225628 at T*66mI"9R%2H!-6CI':213131502
Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/BDMV/STREAM/00075.m2ts' at offset '2924802048'
Error 'OS error - STATUS_DEVICE_DATA_ERROR' occurred while reading '\Device\CdRom0' at offset '2924802048'
Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/BDMV/STREAM/00075.m2ts' at offset '2925262848'
Error 'OS error - STATUS_DEVICE_DATA_ERROR' occurred while reading '\Device\CdRom0' at offset '2925262848'
Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/BDMV/STREAM/00075.m2ts' at offset '2925920256'
Error 'OS error - STATUS_DEVICE_DATA_ERROR' occurred while reading '\Device\CdRom0' at offset '2925920256'
DEBUG: Code 0 at >S"|IvW~[ZAN1!&z:29397610
Error 'Internal error - Operation was cancelled (140)' occurred while reading '/BDMV/STREAM/00075.m2ts' at offset '2925926400'
DEBUG: Code 0 at %K{3+D<I-p.W2g)K$P73:29395471
DEBUG: Code 0 at >u+x)D9+i6!-r0Fh7!4O:29394068
DEBUG: Code 0 at %K{3+D<I-p.W2g)K$P73:213131157
DEBUG: Code 0 at %K{3+D<I-p.W2g)K$P73:121262647
DEBUG: Code 1428675 at %K{3+D<I-p.W2g)K$P73:121261773
DEBUG: Code 0 at 5#w%HEc@g}P<=`%X^J>Av:213137068
Failed to save title 1 to file D:/Videos/Mad Max 4K.mkv
I ripped the 2nd one successfully (Mad Max Road Warrior) but I did get these errors when I started ripping the 2nd disc:
The third disc (Mad Max Beyond Thunderdome) got these errors while ripping, but the rip appears to be successful.
The fourth disc (Mad Max Fury Road) got these errors while ripping, but the rip was still successful.
As a side note: I unblocked the RU TLD from my firewall and I was still getting the HK download failed. I am able to successfully resolve the DNS name. Looking into this further, it seems one of the destinations has been flagged as malware by my firewall vendor (Palo Alto Networks). I even created a rule specifically allowing traffic to the two DNS names I can identify (hkdata.fairuse.org and hkdata.crabdance.com). Even after creating the rule, the firewall would not allow traffic to the IP address. I went to the Palo Alto support site and tested both DNS names, it's the hkdata.crabdance.com name that's coming back as malware. See Palo Alto response below when testing the site:
URL: hkdata.crabdance.com
Categories: Malware
Category: Malware
Description: Sites containing or known to host malicious content, executables, scripts, viruses, trojans, and code
I ended up modifying the URL handling of my firewall and was able to get the HK download errors to stop, but it is important to note that the hkdata.crabdance.com website is still flagged as malware. Whoever maintains the site can try and have it reclassified by Palo Alto Networks by going here:
https://urlfiltering.paloaltonetworks.com/
Once you've tested the site and it comes back as malware, you can click on the "Request Change" at the bottom.
powrhaus
Post by powrhaus »
Even though Disc 1 looked perfectly clean, I took a microfiber cloth and cleaned the disc again. I was able to rip it just like the other 3. So even with the odd debug errors on all the discs, they did eventually rip just fine.
Those two errors above were identical for all 4 of the anthology discs.
