Version 1.9.5 crashes after installing
Re: Version 1.9.5 crashes after installing
#16 Post by Woodstock » Mon Nov 23, 2015 1:57 pm
The latest updates to Windows 7 included "back ported" changes from Windows 10, which have brought several of Win10's problems with them. Did you run Windows update after the install?
Frog44
#17 Post by Frog44 » Tue Nov 24, 2015 11:15 am
Hello, at the moment, i've install all major update.
I execute successfully MakeMKV v1.9.7, as following the explanation in the thread http://www.makemkv.com/forum2/viewtopic ... 337#p40899
set APROXY_FORCE_32BIT=1
"C:\Program Files (x86)\MakeMKV\makemkv.exe"
So now it works with MakeMKV x64 but the x64 is still crashed
