Errors on HDDVD Rips
veliferum
Post by veliferum »
I think your program is very promising despite the bugs, keep up the good work !
Tried to convert two full HD-DVD rips (MakeMKV 1.2).
Both give errors, files are already decrypted with AnyDVDHD.
First One is Van Helsing second one Total Recall.
FAILURE: Code 3 at >f0]:TW#V uho<iN'4rT{qyWO:121261727
FAILURE: Code 0 at WM@A\qsfc!A\QG=&:121263659
FAILURE: Code 0 at C/p"_xH;45<Z<:213130122
Re: Errors on HDDVD Rips
Post by mike admin »
This was fixed in build 692. Please download new version and try it.
veliferum
Post by veliferum »
Second Try with build 692:
Van Helsing (Shows Title Screen with 24 titles)
Main 2 (10gb & 9gb) Movie EVO files are missing.
AACS directory not present, assuming unencrypted disc
VC-1 video stream without TFCNTR information is not supported, sorry. Few HD-DVDs use it anyway.
Failed to decode audio/video data for title #0 - invalid mux or internal error, title skipped.
Failed to decode audio/video data for title #1 - invalid mux or internal error, title skipped.
Failed to decode audio/video data for title #16 - invalid mux or internal error, title skipped.
Failed to decode audio/video data for title #20 - invalid mux or internal error, title skipped.
Failed to decode audio/video data for title #28 - invalid mux or internal error, title skipped.
Failed to decode audio/video data for title #29 - invalid mux or internal error, title skipped.
Failed to decode audio/video data for title #30 - invalid mux or internal error, title skipped.
Failed to decode audio/video data for title #31 - invalid mux or internal error, title skipped.
Failed to decode audio/video data for title #32 - invalid mux or internal error, title skipped.
Failed to decode audio/video data for title #33 - invalid mux or internal error, title skipped.
Failed to decode audio/video data for title #34 - invalid mux or internal error, title skipped.
Failed to decode audio/video data for title #35 - invalid mux or internal error, title skipped.
Failed to decode audio/video data for title #36 - invalid mux or internal error, title skipped.
Failed to decode audio/video data for title #37 - invalid mux or internal error, title skipped.
Failed to decode audio/video data for title #38 - invalid mux or internal error, title skipped.
Failed to decode audio/video data for title #39 - invalid mux or internal error, title skipped.
Failed to decode audio/video data for title #40 - invalid mux or internal error, title skipped.
Failed to decode audio/video data for title #41 - invalid mux or internal error, title skipped.
Failed to decode audio/video data for title #42 - invalid mux or internal error, title skipped.
Failed to decode audio/video data for title #43 - invalid mux or internal error, title skipped.
Failed to decode audio/video data for title #44 - invalid mux or internal error, title skipped.
Failed to decode audio/video data for title #45 - invalid mux or internal error, title skipped.
Failed to decode audio/video data for title #46 - invalid mux or internal error, title skipped.
Failed to decode audio/video data for title #47 - invalid mux or internal error, title skipped.
Failed to decode audio/video data for title #48 - invalid mux or internal error, title skipped.
Failed to decode audio/video data for title #49 - invalid mux or internal error, title skipped.
Failed to decode audio/video data for title #50 - invalid mux or internal error, title skipped.
Failed to decode audio/video data for title #51 - invalid mux or internal error, title skipped.
Failed to decode audio/video data for title #52 - invalid mux or internal error, title skipped.
Failed to decode audio/video data for title #53 - invalid mux or internal error, title skipped.
Failed to decode audio/video data for title #54 - invalid mux or internal error, title skipped.
Failed to decode audio/video data for title #55 - invalid mux or internal error, title skipped.
Failed to decode audio/video data for title #56 - invalid mux or internal error, title skipped.
FAILURE: Code 0 at ?5dvDo/TJ<>%g@o9K~:213132606
Operation sucessfully completed
Total Recall:
Failed to decode audio/video data for title #2 - invalid mux or internal error, title skipped.
Failed to decode audio/video data for title #3 - invalid mux or internal error, title skipped.
Failed to decode audio/video data for title #4 - invalid mux or internal error, title skipped.
Failed to decode audio/video data for title #5 - invalid mux or internal error, title skipped.
Failed to decode audio/video data for title #6 - invalid mux or internal error, title skipped.
Failed to decode audio/video data for title #7 - invalid mux or internal error, title skipped.
Failed to decode audio/video data for title #8 - invalid mux or internal error, title skipped.
FAILURE: Code 650 at wo<N&I n>"na2SpeP-+fe:29393861
FAILURE: Code 2000 at wo<N&I n>"na2SpeP-+fe:29393861
FAILURE: Code 858 at wo<N&I n>"na2SpeP-+fe:29393861
FAILURE: Code 1096 at wo<N&I n>"na2SpeP-+fe:29393861
FAILURE: Code 850 at wo<N&I n>"na2SpeP-+fe:29393861
FAILURE: Code 1592 at wo<N&I n>"na2SpeP-+fe:29393861
FAILURE: Code 2017 at wo<N&I n>"na2SpeP-+fe:29393861
FAILURE: Code 291 at wo<N&I n>"na2SpeP-+fe:29393861
Sorry, we have limited support of HDDVD. We don't support VC-1 without TFCNTR on HDDVD and this would not change in the nearest future.
Krobar
Post by Krobar »
mike admin wrote:Sorry, we have limited support of HDDVD. We don't support VC-1 without TFCNTR on HDDVD and this would not change in the nearest future.
Hi Mike,
I have about 200 HDDVDs I want to rip, it seems a large number of them give the TFCNTR error. Is better HDDVD support still planned for later? I know its a dead format but that does make ripping discs even more important for those of us with HDDVDs.
I can't give you any answer unfortunately - the fate of HD-DVD suport is not yet decided. :(
Thx-1138
Post by Thx-1138 »
HD-DVD support has my STRONG vote. I have about 50 discs to migrate to my media server as well and had hoped makeMKV was my answer.
trondmm
Post by trondmm »
I'd also love HD DVD support.
I've ripped a few HD DVDs with eac3to, bdsup2sub and mkvmerge, but it's a major pain in the ass, and there are a lot of manual steps to be made. So if a tool like MakeMKV could make it as simple to rip HD DVDs as it makes BD-ripping, it would be fantastic.
Apparently ClownBD should actually be a one-click HD DVD (and BD of course)-ripper, which uses eac3to, bdsup2sub and mkvmerge (or is it tsMuxer?) in the background, but I've not been able to get it to work properly.
icedtrip
Post by icedtrip »
I'd like to throw another vote into the mix for HD-DVD. As a previous commenter said, HD-DVD is a dead format, but that makes it more important to us that still have HD-DVDs to get onto a hard drive, especially since the BD equivalent typically has no improvements over the HD-DVD versions. With the WB red2blu program, we can get the BD version for next to nothing, but Universal, Paramount, and others have not followed suit, and this late in the game, I don't see it happening.
Of course, I'm trying to avoid the windows side of ripping, and would like a simple MKV file to show at the end of the process.
Would renting my HD-DVD collection on BD for ripping be wrong? 90%+ of the time, the studios just used the HD-DVD raw content to make the BD...just sayin...
It is very likely that hd-dvd support will get fixed soon. Still it's not a firm promise.
desol11
Post by desol11 »
Hopefully soon deal sealer for me, I would pay for HDDVD support
paulhenry26
Post by paulhenry26 »
Hi There,
i'm new here after recently buying the program and i would like to add my vote for a HDDVD fix, i am trying to convert some at the moment without much success
desol11
Post by desol11 »
Any updates about hdvdd support yet.
setarip_old
Post by setarip_old »
@desol11
No - If there was an update, it would appear in either the "News and Announcements" and/or this very thread that you've posted to ;>}
setarip_old
Re: Inexpensive HD-DVDs
I may be the last person to discover this but:
http://hddvdboxsets.com/hddvd1-38754801 ... D_DVD.html
Offers (via "Amazon sellers") legitimate, commercial HD-DVDs starting at a penny each
