MediaInfo comes of age.
ndjamena
#1 Post by ndjamena » Sat Nov 21, 2015 2:57 pm
The next version of MediaInfo, coming out in about ten days, will be able to detect both DTS:X and ATMOS, plus it will show DTS ES Matrix and Discrete in any tracks that contain them (including DTS-MA tracks.)
It will also properly process MKVMerge's Track Statistics Tags, finally hiding them from view and using them to display correct and accurate information about the contents of the files that contain them.
There are also quite a few tweaks on the Matroska side, including better frame rate detection.
This is the latest non-official MediaInfo dll for anyone who'd like to try it.
http://www.mediafire.com/download/5y4o9 ... iaInfo.zip
ndjamena
Re: MediaInfo comes of age.
#2 Post by ndjamena » Sat Nov 21, 2015 3:15 pm
General
Unique ID                                : 220444523237679225261748144594294187700 (0xA5D812226FC7A527A17ED8EF521CA6B4)
Complete name                            : F:\Zilla.mkv
Format version                           : Version 4 / Version 2
File size                                : 40.4 GiB
Duration                                 : 2h 18mn
Overall bit rate                         : 41.7 Mbps
Movie name                               : Zilla
Encoded date                             : UTC 2015-11-17 10:17:26
Writing application                      : mkvmerge v8.5.1 ('Crosses') 64bit
Writing library                          : libebml v1.3.3 + libmatroska v1.4.4
Video
Format                                   : AVC
Format/Info                              : Advanced Video Codec
Format profile                           : High@L4.1
Format settings, CABAC                   : Yes
Format settings, ReFrames                : 2 frames
Format settings, GOP                     : M=1, N=10
Codec ID                                 : V_MPEG4/ISO/AVC
Duration                                 : 2h 18mn
Bit rate                                 : 34.7 Mbps
Width                                    : 1 920 pixels
Height                                   : 1 080 pixels
Frame rate                               : 23.976 fps
Chroma subsampling                       : 4:2:0
Bit depth                                : 8 bits
Scan type                                : Progressive
Bits/(Pixel*Frame)                       : 0.698
Stream size                              : 33.6 GiB (83%)
Audio #1
Format                                   : DTS
Format profile                           : MA / Core
Mode                                     : 16
Format settings, Endianness              : Big
Duration                                 : 2h 18mn
Bit rate mode                            : Variable / Constant
Bit rate                                 : 3 840 Kbps / 1 509 Kbps
Channel positions                        : Front: L C R, Side: L R, LFE
Sampling rate                            : 48.0 KHz
Frame rate                               : 93.750 fps (512 spf)
Compression mode                         : Lossless / Lossy
Stream size                              : 3.66 GiB (9%)
Audio #2
Format                                   : FLAC
Format/Info                              : Free Lossless Audio Codec
Codec ID                                 : A_FLAC
Duration                                 : 2h 18mn
Bit rate                                 : 3 202 Kbps
Frame rate                               : 11.719 fps (4096 spf)
Detected bit depth                       : 20 bits
Stream size                              : 3.10 GiB (8%)
Writing library                          : libFLAC 1.2.1 (UTC 2007-09-17)
Text #1
Format                                   : PGS
Muxing mode                              : zlib
Codec ID                                 : S_HDMV/PGS
Codec ID/Info                            : Picture based subtitle format used on BDs/HD-DVDs
Duration                                 : 2h 1mn
Bit rate                                 : 11.4 Kbps
Count of elements                        : 2084
Stream size                              : 9.90 MiB (0%)
Text #2
Format                                   : PGS
Muxing mode                              : zlib
Duration                                 : 1h 23mn
Bit rate                                 : 198 bps
Count of elements                        : 36
Stream size                              : 121 KiB (0%)
Text #3
Format                                   : PGS
Muxing mode                              : zlib
Duration                                 : 2h 9mn
Bit rate                                 : 7 053 bps
Count of elements                        : 2460
Stream size                              : 6.52 MiB (0%)
Menu
00:00:00.000                             : en:Start
00:07:48.092                             : en:Collision Course
00:17:25.502                             : en:Worm Guy
00:25:28.026                             : en:"Gojira"
00:36:53.461                             : en:Inside a Footprint
00:41:47.880                             : en:Insurance Claim
00:48:19.479                             : en:Caught on Something
01:01:35.900                             : en:"I Got a Bite"
01:11:05.803                             : en:New Kid in Town
01:21:38.685                             : en:23Rd St. Station
01:30:26.087                             : en:Drawing Him Out
01:39:13.989                             : en:Fire at Will: One
01:50:23.867                             : en:Copter Chase
01:52:28.658                             : en:"He's Pregnant"
02:00:36.771                             : en:Shaken, Not Stirred
02:05:56.882                             : en:Section Five
Subtitle track one has 2084 elements in it, subtitle two has only 36, which means it can only be forced subtitles, the last subtitle has 2460 elements, which is more than the first, so the first must be the regular subtitles and the last must be SDH.
Note that all the tracks have bitrates and durations, and they're accurate to the bytes and milliseconds, even DTS-MA has a bitrate.
For anyone who uses EAC3To to process their audio, you'll notice a "Detected bit depth" field underneath the "Bit depth" field. That's eac3to's "VALID_BITS" tag showing through from the FLAC header. It tells you the actual precision of the audio track, rather than the encoded bitrate, which in this case is 20 bits instead of 24.
ndjamena
#3 Post by ndjamena » Sat Nov 21, 2015 3:17 pm
DTS:X
General
Complete name                            : D:\Ex Machina (10secs).m2ts
Format                                   : BDAV
Format/Info                              : Blu-ray Video
File size                                : 8.21 MiB
Duration                                 : 9s 927ms
Overall bit rate                         : 6 731 Kbps
Maximum Overall bit rate                 : 35.5 Mbps
Video
Format                                   : AVC
Format settings, ReFrames                : 4 frames
Codec ID                                 : 27
Duration                                 : 10s 10ms
Maximum bit rate                         : 36.0 Mbps
Bit depth                                : 8 bits
Audio
Format                                   : DTS
Format profile                           : X / MA / Core
Mode                                     : 16
Muxing mode                              : Stream extension
Codec ID                                 : 134
Duration                                 : 9s 920ms
Bit rate mode                            : Variable / Variable / Constant
Bit rate                                 : Unknown / Unknown / 1 509 Kbps
Channel(s)                               : Object Based / 8 channels / 6 channels
Channel positions                        : Object Based / Front: L C R, Side: L R, Back: L R, LFE / Front: L C R, Side: L R, LFE
Sampling rate                            :  / 48.0 KHz / 48.0 KHz
Bit depth                                :  / 24 bits / 24 bits
Compression mode                         :  / Lossless / Lossy
ndjamena
#4 Post by ndjamena » Sat Nov 21, 2015 3:27 pm
Atmos.
General
Unique ID                                : 190120769036665247675313917609807804740 (0x8F07ED9F6AD174F488F96D1567617944)
Complete name                            : D:\Teenage Mutant Ninja Turtles.mkv
File size                                : 23.6 GiB
Duration                                 : 1h 41mn
Overall bit rate                         : 33.3 Mbps
Movie name                               : Teenage Mutant Ninja Turtles
Encoded date                             : UTC 2015-11-21 15:20:07
Video
Format                                   : AVC
Duration                                 : 1h 41mn
Bit rate                                 : 27.7 Mbps
Maximum bit rate                         : 31.0 Mbps
Bit depth                                : 8 bits
Bits/(Pixel*Frame)                       : 0.558
Stream size                              : 19.6 GiB (83%)
Audio
Format                                   : Atmos / TrueHD
Duration                                 : 1h 41mn
Bit rate                                 : 5 544 Kbps
Maximum bit rate                         : 8 853 Kbps
Frame rate                               : 1 200.000 fps (40 spf)
Stream size                              : 3.92 GiB (17%)
Text #1
Format                                   : PGS
Muxing mode                              : zlib
Duration                                 : 1h 32mn
Bit rate                                 : 11.8 Kbps
Count of elements                        : 2604
Stream size                              : 7.85 MiB (0%)
Text #2
Format                                   : PGS
Muxing mode                              : zlib
Duration                                 : 35mn 13s
Bit rate                                 : 107 bps
Count of elements                        : 18
Stream size                              : 27.8 KiB (0%)
Text #3
Format                                   : PGS
Muxing mode                              : zlib
Duration                                 : 1h 33mn
Bit rate                                 : 15.5 Kbps
Count of elements                        : 3438
Stream size                              : 10.3 MiB (0%)
Menu
00:00:00.000                             : en:Chapter 01
00:02:42.287                             : en:Chapter 02
00:06:00.485                             : en:Chapter 03
00:11:51.544                             : en:Chapter 04
00:16:01.835                             : en:Chapter 05
00:22:02.946                             : en:Chapter 06
00:28:22.784                             : en:Chapter 07
00:34:01.831                             : en:Chapter 08
00:38:04.031                             : en:Chapter 09
00:42:10.110                             : en:Chapter 10
00:48:36.413                             : en:Chapter 11
00:55:46.092                             : en:Chapter 12
01:00:44.265                             : en:Chapter 13
01:07:46.604                             : en:Chapter 14
01:15:30.359                             : en:Chapter 15
01:24:10.795                             : en:Chapter 16
01:30:17.036                             : en:Chapter 17
01:34:13.564                             : en:Chapter 18
ndjamena
#5 Post by ndjamena » Sat Nov 21, 2015 4:57 pm
6.1 DTS-MA, finally showing it's DTS ES Discrete core!
General
Unique ID                                : 202884606062461444060063986062377675549 (0x98A2275FE6C691C99162B09C0C88EB1D)
Complete name                            : D:\Blade Trinity.mkv
File size                                : 29.0 GiB
Duration                                 : 2h 2mn
Overall bit rate                         : 34.0 Mbps
Movie name                               : Blade Trinity
Encoded date                             : UTC 2015-11-21 16:31:30
Video
Format                                   : AVC
Duration                                 : 2h 2mn
Bit rate                                 : 29.7 Mbps
Bit depth                                : 8 bits
Bits/(Pixel*Frame)                       : 0.598
Stream size                              : 25.4 GiB (87%)
Audio
Format                                   : DTS
Format profile                           : MA / ES Discrete / Core
Mode                                     : 16
Duration                                 : 2h 2mn
Bit rate mode                            : Variable / Constant / Constant
Bit rate                                 : 4 259 Kbps / 1 509 Kbps / 1 509 Kbps
Channel(s)                               : 7 channels / 7 channels / 6 channels
Channel positions                        : Front: L C R, Side: L R, Back: C, LFE / Front: L C R, Side: L R, Back: C, LFE / Front: L C R, Side: L R, LFE
Compression mode                         : Lossless / Lossy / Lossy
Stream size                              : 3.64 GiB (13%)
Title                                    : Surround 6.1
Text
Format                                   : PGS
Muxing mode                              : zlib
Duration                                 : 1h 53mn
Bit rate                                 : 10.9 Kbps
Count of elements                        : 2326
Stream size                              : 8.79 MiB (0%)
Menu
00:00:00.000                             : en:Syrian Desert
00:06:47.031                             : en:Main Titles/Human
00:12:58.986                             : en:New Junter
00:17:16.035                             : en:Losing the War
00:18:48.127                             : en:Abigail
00:22:48.283                             : en:Shoot to Kill
00:27:05.457                             : en:Dr Vance
00:34:22.894                             : en:A Rescue
00:41:07.631                             : en:The Nightstalkers
00:45:40.863                             : en:Dracula
00:50:55.635                             : en:Daystar
00:54:10.538                             : en:Hunting
00:58:07.984                             : en:It's Drake
01:08:05.122                             : en:The Final Solution
01:17:54.670                             : en:Use It
01:21:59.623                             : en:Target Practice
01:28:32.015                             : en:Friends Are Coming
01:33:30.062                             : en:The Fat Lady Sings
01:41:31.460                             : en:Drake vs Blade
01:46:13.116                             : en:Thirst Always Wins
01:50:44.846                             : en:The War Never Ends
01:53:51.658                             : en:End Credits
ndjamena
#6 Post by ndjamena » Sat Nov 21, 2015 5:07 pm
Quite a few Pixar movies have DTS ES Matrixed DTS-MA... They're basically 6.1, not the 5.1 listed on the cover.
General
Unique ID                                : 180854070374912088644515272107481127235 (0x880F3A1AB3A4282EA345F5680FA45943)
Complete name                            : D:\The Incredibles.mkv
File size                                : 22.4 GiB
Duration                                 : 1h 55mn
Overall bit rate                         : 27.8 Mbps
Movie name                               : The Incredibles
Encoded date                             : UTC 2015-11-21 16:59:23
Video
Format                                   : AVC
Duration                                 : 1h 55mn
Bit rate                                 : 24.0 Mbps
Maximum bit rate                         : 34.0 Mbps
Bit depth                                : 8 bits
Bits/(Pixel*Frame)                       : 0.482
Stream size                              : 19.3 GiB (86%)
Color primaries                          : BT.709
Transfer characteristics                 : BT.709
Matrix coefficients                      : BT.709
Audio
Format                                   : DTS
Format profile                           : MA / ES Matrix / Core
Mode                                     : 16
Duration                                 : 1h 55mn
Bit rate                                 : 3 840 Kbps / 1 509 Kbps / 1 509 Kbps
Stream size                              : 3.09 GiB (14%)
Text #1
Format                                   : PGS
Muxing mode                              : zlib
Duration                                 : 1h 47mn
Bit rate                                 : 10.4 Kbps
Count of elements                        : 2406
Stream size                              : 7.99 MiB (0%)
Text #2
Format                                   : PGS
Muxing mode                              : zlib
Duration                                 : 1h 47mn
Bit rate                                 : 11.7 Kbps
Count of elements                        : 2682
Stream size                              : 9.04 MiB (0%)
Text #3
Format                                   : PGS
Muxing mode                              : zlib
Duration                                 : 1h 47mn
Bit rate                                 : 22 bps
Count of elements                        : 56
Stream size                              : 17.4 KiB (0%)
Text #4
Format                                   : PGS
Muxing mode                              : zlib
Duration                                 : 1h 50mn
Bit rate                                 : 5 829 bps
Stream size                              : 4.59 MiB (0%)
Menu
00:00:00.000                             : en:Golden Age
00:09:14.554                             : en:Weddings and Lawsuits
00:11:32.566                             : en:15 Years and 50 Pounds
00:13:31.352                             : en:After School
00:17:08.527                             : en:Family Dinner
00:20:44.910                             : en:2 Ex-Supers
00:26:53.528                             : en:A Super Defeated
00:30:42.215                             : en:Help Wanted
00:34:54.592                             : en:Nomanisan
00:41:27.234                             : en:New and Improved
00:46:01.675                             : en:Helen Suspects
00:48:54.514                             : en:Helen and E
00:50:02.124                             : en:An Important Meeting
00:54:01.780                             : en:E's Lab
00:57:09.551                             : en:Secrets Revealed
01:00:35.798                             : en:Suiting Up
01:05:04.859                             : en:Missile Lock
01:10:53.707                             : en:Out to Sea
01:12:57.915                             : en:Good Guys / Bad Guys
01:16:27.583                             : en:Elastigirl Returns
01:19:19.212                             : en:Caves and Rockets
01:21:13.910                             : en:Lost and Found
01:23:59.659                             : en:100 Mile Dash
01:27:05.637                             : en:Reunited
01:30:29.841                             : en:Bob's Confession
01:32:47.395                             : en:Frozone and Honey
01:33:33.024                             : en:Omnidroid Attacks
01:34:30.414                             : en:Road Trip
01:37:03.150                             : en:The Incredibles vs. the Omnidroid
01:41:58.070                             : en:Past vs. Future
01:45:39.875                             : en:Happy Endings
01:47:33.363                             : en:End Credits
