Saving stops abruptly at 143.9M
Zaralyth
#1 Post by Zaralyth » Sat Nov 21, 2015 8:52 am
Saving a single title from a fairly recent Blu Ray, saving pauses
abrupy at 149.3M, "remaining" time counts up to infinity.
[EDIT]
As per request I've posted a debug log.
Debug log started at Sat Nov 21 17:54:42 2015 , written by MakeMKV v1.9.7 win(x64-release)
Using 1048320KB for read cache.
001005:0000 MakeMKV v1.9.7 win(x64-release) started
001004:0000 Debug logging enabled, log will be saved as C:\Users\Zaralyth/MakeMKV_log.txt
DEBUG: Code 2147483648 at '(&byawYai[o+:&o:121265315
DAFD=PAAAADAAAAEABDQUEAQEBAQ==
DCE=pPfEYI66gsLZYYzpHu3SpcvRGX/nCkkm+BLkTbTJsd5jkf9A8oCy4JfseIs68bN7JM/cTBWjaHNOs9lcoqwSUuByk3O78eJRm3Vgne82Mk4ovN1QCzgrXZ0H2WfutJkIjoeZE8E2lhVynBgzjK3Qdchvk53FAxRbzg==
DISCID=07C1665BD7A4EF89325FED187F7871AF333A1787
003307:0000 File 00001.mpls was added as title #0
003307:0000 File 00002.mpls was added as title #1
003307:0000 File 00004.m2ts was added as title #2
003307:0000 File 00005.m2ts was added as title #3
003307:0000 File 00006.m2ts was added as title #4
003307:0000 File 00007.m2ts was added as title #5
003307:0000 File 00008.m2ts was added as title #6
003307:0000 File 00009.m2ts was added as title #7
003307:0000 File 00010.m2ts was added as title #8
003307:0000 File 00011.m2ts was added as title #9
003307:0000 File 00012.m2ts was added as title #10
003307:0000 File 00014.m2ts was added as title #11
003307:0000 File 00015.m2ts was added as title #12
005014:0000 Saving 1 titles into directory C:/Users/Zaralyth/Desktop
001003:0020 DEBUG: Code 1201 at dTY}Ut\3Z+1[99lR]yBK&:29393631
... (this message repeats another 4000 times until I ended the process)
001003:0020 DEBUG: Code 5027 at @$Q+:`RP".C'YHv#:29397840
001003:0020 DEBUG: Code 2 at @$Q+:`RP".C'YHv#:121263751
001003:0020 DEBUG: Code 117506160 at IGk^,-\RY\YcL,kZ:121274584
001003:0020 DEBUG: Code 0 at =yzS;G;(L8eK`@3y!%:121262325
004007:0010 AV synchronization issues were found in file 'C:/Users/Zaralyth/Desktop/title01.mkv' (title #2)
004008:0010 AV sync issue in stream 2 at 0:04:14.752 with duration of 2450.145ms : audio gap - 76.567 missing frame(s)
005003:0000 Failed to save title 1 to file C:/Users/Zaralyth/Desktop/title01.mkv
005004:0080 0 titles saved, 1 failed
Application exited at Sat Nov 21 18:11:40 2015
I should also note that chapter 1 has a time of 0:00:00.
The Blu Ray plays fine on a standard Blu Ray player, without issues.
Re: Saving stops abruptly at 143.9M
#2 Post by Woodstock » Sat Nov 21, 2015 2:41 pm
If you have not already, enable debug logging (information on that is in the link in my signature). That will give more information on "weirdness" that MakeMKV sees while reading a disk, including navigational errors.
Zaralyth
#3 Post by Zaralyth » Sat Nov 21, 2015 5:18 pm
[redacted]
Zaralyth
#4 Post by Zaralyth » Sat Nov 21, 2015 6:09 pm
After enablind debug the program now goes in and out of not responding.
I'll post a new debug code after it does this for a while, it's sending a bunch
into the log.
EDIT -> I've updated the OP to reflect the new debug log.
#5 Post by mike admin » Mon Nov 23, 2015 7:14 am
Please do the following for this title - /onlinehelp/testdump.html
