Saving stops abruptly at 143.9M
Zaralyth
Post by Zaralyth »
Saving a single title from a fairly recent Blu Ray, saving pauses
abrupy at 149.3M, "remaining" time counts up to infinity.
[EDIT]
As per request I've posted a debug log.
Debug log started at Sat Nov 21 17:54:42 2015 , written by MakeMKV v1.9.7 win(x64-release)
Using 1048320KB for read cache.
001005:0000 MakeMKV v1.9.7 win(x64-release) started
001004:0000 Debug logging enabled, log will be saved as C:\Users\Zaralyth/MakeMKV_log.txt
DEBUG: Code 2147483648 at '(&byawYai[o+:&o:121265315
DAFD=PAAAADAAAAEABDQUEAQEBAQ==
DCE=pPfEYI66gsLZYYzpHu3SpcvRGX/nCkkm+BLkTbTJsd5jkf9A8oCy4JfseIs68bN7JM/cTBWjaHNOs9lcoqwSUuByk3O78eJRm3Vgne82Mk4ovN1QCzgrXZ0H2WfutJkIjoeZE8E2lhVynBgzjK3Qdchvk53FAxRbzg==
DISCID=07C1665BD7A4EF89325FED187F7871AF333A1787
003307:0000 File 00001.mpls was added as title #0
003307:0000 File 00002.mpls was added as title #1
003307:0000 File 00004.m2ts was added as title #2
003307:0000 File 00005.m2ts was added as title #3
003307:0000 File 00006.m2ts was added as title #4
003307:0000 File 00007.m2ts was added as title #5
003307:0000 File 00008.m2ts was added as title #6
003307:0000 File 00009.m2ts was added as title #7
003307:0000 File 00010.m2ts was added as title #8
003307:0000 File 00011.m2ts was added as title #9
003307:0000 File 00012.m2ts was added as title #10
003307:0000 File 00014.m2ts was added as title #11
003307:0000 File 00015.m2ts was added as title #12
005014:0000 Saving 1 titles into directory C:/Users/Zaralyth/Desktop
001003:0020 DEBUG: Code 1201 at dTY}Ut\3Z+1[99lR]yBK&:29393631
... (this message repeats another 4000 times until I ended the process)
001003:0020 DEBUG: Code 5027 at @$Q+:`RP".C'YHv#:29397840
001003:0020 DEBUG: Code 2 at @$Q+:`RP".C'YHv#:121263751
001003:0020 DEBUG: Code 117506160 at IGk^,-\RY\YcL,kZ:121274584
001003:0020 DEBUG: Code 0 at =yzS;G;(L8eK`@3y!%:121262325
004007:0010 AV synchronization issues were found in file 'C:/Users/Zaralyth/Desktop/title01.mkv' (title #2)
004008:0010 AV sync issue in stream 2 at 0:04:14.752 with duration of 2450.145ms : audio gap - 76.567 missing frame(s)
005003:0000 Failed to save title 1 to file C:/Users/Zaralyth/Desktop/title01.mkv
005004:0080 0 titles saved, 1 failed
Application exited at Sat Nov 21 18:11:40 2015
I should also note that chapter 1 has a time of 0:00:00.
The Blu Ray plays fine on a standard Blu Ray player, without issues.
Re: Saving stops abruptly at 143.9M
If you have not already, enable debug logging (information on that is in the link in my signature). That will give more information on "weirdness" that MakeMKV sees while reading a disk, including navigational errors.
Zaralyth
Post by Zaralyth »
[redacted]
Zaralyth
Post by Zaralyth »
After enablind debug the program now goes in and out of not responding.
I'll post a new debug code after it does this for a while, it's sending a bunch
into the log.
EDIT -> I've updated the OP to reflect the new debug log.
Post by mike admin »
Please do the following for this title - /onlinehelp/testdump.html
