Cheers,
Mads Wors?e Duun
Currently its possible only build QT-frontend of the makemkv_oss. The main part of makemkv is makemkv_bin (aka makemkvcon) is available only for linux. I tried to run it with FreeBSD's linuxlator and makemkvcon command without any arguments works, but makemkv still have pop-up window with "Application failed to initialize.".FreeMWP wrote:Thanks ozzius, I'll try your port asap, and will repport how it works.
Didn't have time to try it yet, but it seems that you did a good job so fare. About the communication between makemkvcon and the makemkv gui, we maybe need some kind of linuxmakemkv wrapper, just like native firefox etc. needs linuxpluginwrapper to run e.g. the flash plugin.ozzius wrote:Currently its possible only build QT-frontend of the makemkv_oss. The main part of makemkv is makemkv_bin (aka makemkvcon) is available only for linux. I tried to run it with FreeBSD's linuxlator and makemkvcon command without any arguments works, but makemkv still have pop-up window with "Application failed to initialize.".
So, its possible to build, and it is not possible to run...
I would't bet on a native FreeBSD binary. Guess we need to make it run on the Linux emulation layer.Harri wrote:I'd love to see the binary package for FreeBSD. I am using Linux since kernel 0.99.x, but before I used BSD (SunOS 4.x, Ultrix). I can help polish the build procedure, if necessary.
I wonder how you got this running, or maybe something changed in makemkvcon meanwhile ... I tried a lot today and finally got makemkvcon to run at all, but it always tells me "Das Programm konnte keine verwendbaren optischen Laufwerke finden.", probably something like "the program couldn't find any optical drives." in the C locale. Running it through "truss", I could see it tries to open /sys/bus/scsi/devices, which isn't provided by the FreeBSD linsysfs implementation.GhostUser00 wrote: ↑Mon Jun 13, 2016 8:42 pmThe "port" uses the "core" makemkvcon component run under the linux compatibility layer, therefore it is not possible to run the application without it.
