Problems copying Jurassic World Bluray
mrbobo
Post by mrbobo »
Hi
I am using makemkv 1.9.7 on 64bit Linux (Kubuntu 14.04) and up to now I hadn't any problems so far with copying titles from blurays. My bluray drive is a LG BD-RE BH16NS40.
But now I tried to copy Jurassic World ( should be the european version ) and it gives me reading errors during extraction. The movie plays fine on my normal bluray player.
I get the following in my log:
MakeMKV v1.9.7 linux(x64-release) started
Title #00013.mpls has length of 120 seconds which is less than minimum title length of 2400 seconds and was therefore skipped
File 00802.mpls was added as title #0
Title #00000.mpls has length of 120 seconds which is less than minimum title length of 2400 seconds and was therefore skipped
Title #00020.mpls has length of 153 seconds which is less than minimum title length of 2400 seconds and was therefore skipped
Title 00801.mpls is equal to title 00802.mpls and was skipped
Title 00800.mpls is equal to title 00802.mpls and was skipped
Title #00018.m2ts has length of 25 seconds which is less than minimum title length of 2400 seconds and was therefore skipped
Title #00019.m2ts has length of 14 seconds which is less than minimum title length of 2400 seconds and was therefore skipped
Title #00020.m2ts has length of 60 seconds which is less than minimum title length of 2400 seconds and was therefore skipped
Title #50355.m2ts has length of 26 seconds which is less than minimum title length of 2400 seconds and was therefore skipped
Title #00021.m2ts has length of 79 seconds which is less than minimum title length of 2400 seconds and was therefore skipped
Title #00022.m2ts has length of 74 seconds which is less than minimum title length of 2400 seconds and was therefore skipped
Title #00300.m2ts has length of 368 seconds which is less than minimum title length of 2400 seconds and was therefore skipped
Title #00301.m2ts has length of 537 seconds which is less than minimum title length of 2400 seconds and was therefore skipped
Title #00302.m2ts has length of 1792 seconds which is less than minimum title length of 2400 seconds and was therefore skipped
Title #00303.m2ts has length of 989 seconds which is less than minimum title length of 2400 seconds and was therefore skipped
Title #00304.m2ts has length of 611 seconds which is less than minimum title length of 2400 seconds and was therefore skipped
Title #00305.m2ts has length of 121 seconds which is less than minimum title length of 2400 seconds and was therefore skipped
Saving 1 titles into directory /home/martin/temp/rips/MainMovie
Error 'Scsi error - HARDWARE ERROR:TIMEOUT ON LOGICAL UNIT' occurred while reading '/BDMV/STREAM/00800.m2ts' at offset '1622405120'
Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/BDMV/STREAM/00800.m2ts' at offset '1624113152'
Failed to save title 0 to file /home/martin/temp/rips/MainMovie/Jurassic_World_t00.mkv
0 titles saved, 1 failed
The disc is brand now and has no visible flaws, and as stated above, it plays fine on the standalone bd player.
Is there anything I can do ?
Re: Problems copying Jurassic World Bluray
These two errors are coming from the drive:
It is possible that increasing the number of retries will get you past them (Preferences->IO menu).
Playing in a stand-alone player isn't the best way to judge a disk, because players will ignore many errors. You might see a flicker in the video or hear something in the audio, but it won't last long on small errors.
