Fatal error
TopGun2010
Fatal error
Post by TopGun2010 »
I updated to 1.3. After scanning a Blu-ray disc I want to select a videostream >>> Fatal error, automatic shutdown of Makemkv.
I work with Vista Ultimate. I had no problems with 1.2
Re: Fatal error
Post by mike admin »
Hi TopGun,
Could you please try to enable "log debug messages" in preferences and copy log here?
Thank you
TopGun2010
Re: Fatal error
Hi Mike,
The problem is with all Disney-Pixar Blu-ray movies:
File 00044.mpls was added as title #0
File 00046.mpls was added as title #1
File 00049.mpls was added as title #2
File 00050.mpls was added as title #3
File 00051.mpls was added as title #4
Title #00061.mpls has length of 54 seconds which is less then minimum title length of 120 seconds and was therefore skipped
Title #00062.mpls has length of 18 seconds which is less then minimum title length of 120 seconds and was therefore skipped
Title #00063.mpls has length of 22 seconds which is less then minimum title length of 120 seconds and was therefore skipped
Title #00064.mpls has length of 18 seconds which is less then minimum title length of 120 seconds and was therefore skipped
File 00065.mpls was added as title #5
Title #00066.mpls has length of 113 seconds which is less then minimum title length of 120 seconds and was therefore skipped
File 00067.mpls was added as title #6
File 00068.mpls was added as title #7
File 00122.mpls was added as title #8
File 00126.mpls was added as title #9
File 00127.mpls was added as title #10
Title #00005.mpls has length of 54 seconds which is less then minimum title length of 120 seconds and was therefore skipped
Title #00006.mpls has length of 54 seconds which is less then minimum title length of 120 seconds and was therefore skipped
File 00047.mpls was added as title #11
File 00157.mpls was added as title #12
File 00158.mpls was added as title #13
File 00125.mpls was added as title #14
FAILURE: Code 2 at 4NOxj\Jn:o# i2qL:213133756
The blu-ray disc can't be opened by this BETA version. It contains the following unsupported feature: multi-angle titles
Stream #1 of type 'LPCM-HD audio' in file 00027.m2ts was skipped, since it is not supported in BETA version
File 00001.mpls was added as title #15
Title 00143.mpls is equal to title 00001.mpls and was skipped
Title #00003.m2ts has length of 53 seconds which is less then minimum title length of 120 seconds and was therefore skipped
Title #00029.m2ts has length of 58 seconds which is less then minimum title length of 120 seconds and was therefore skipped
Title #00035.m2ts has length of 24 seconds which is less then minimum title length of 120 seconds and was therefore skipped
Title #00038.m2ts has length of 86 seconds which is less then minimum title length of 120 seconds and was therefore skipped
Title #00041.m2ts has length of 34 seconds which is less then minimum title length of 120 seconds and was therefore skipped
Title #00044.m2ts has length of 19 seconds which is less then minimum title length of 120 seconds and was therefore skipped
Title #00063.m2ts has length of 56 seconds which is less then minimum title length of 120 seconds and was therefore skipped
Title #00066.m2ts has length of 74 seconds which is less then minimum title length of 120 seconds and was therefore skipped
Title #00067.m2ts has length of 111 seconds which is less then minimum title length of 120 seconds and was therefore skipped
Title #00068.m2ts has length of 7 seconds which is less then minimum title length of 120 seconds and was therefore skipped
Title #00069.m2ts has length of 101 seconds which is less then minimum title length of 120 seconds and was therefore skipped
Title #00070.m2ts has length of 7 seconds which is less then minimum title length of 120 seconds and was therefore skipped
File 00072.m2ts was added as title #16
Title #00076.m2ts has length of 109 seconds which is less then minimum title length of 120 seconds and was therefore skipped
Title #00079.m2ts has length of 10 seconds which is less then minimum title length of 120 seconds and was therefore skipped
File 00083.m2ts was added as title #17
Title #00084.m2ts has length of 68 seconds which is less then minimum title length of 120 seconds and was therefore skipped
Title #00085.m2ts has length of 57 seconds which is less then minimum title length of 120 seconds and was therefore skipped
Title #00086.m2ts has length of 64 seconds which is less then minimum title length of 120 seconds and was therefore skipped
Title #00087.m2ts has length of 35 seconds which is less then minimum title length of 120 seconds and was therefore skipped
Title #00088.m2ts has length of 20 seconds which is less then minimum title length of 120 seconds and was therefore skipped
Title #00089.m2ts has length of 4 seconds which is less then minimum title length of 120 seconds and was therefore skipped
Title #00098.m2ts has length of 31 seconds which is less then minimum title length of 120 seconds and was therefore skipped
Title #00099.m2ts has length of 6 seconds which is less then minimum title length of 120 seconds and was therefore skipped
Title #00100.m2ts has length of 7 seconds which is less then minimum title length of 120 seconds and was therefore skipped
Title #00101.m2ts has length of 53 seconds which is less then minimum title length of 120 seconds and was therefore skipped
Title #00103.m2ts has length of 0 seconds which is less then minimum title length of 120 seconds and was therefore skipped
Title #00108.m2ts has length of 45 seconds which is less then minimum title length of 120 seconds and was therefore skipped
Title #00130.m2ts has length of 54 seconds which is less then minimum title length of 120 seconds and was therefore skipped
Title #00131.m2ts has length of 67 seconds which is less then minimum title length of 120 seconds and was therefore skipped
Title #00132.m2ts has length of 100 seconds which is less then minimum title length of 120 seconds and was therefore skipped
Title #00133.m2ts has length of 62 seconds which is less then minimum title length of 120 seconds and was therefore skipped
Title #00134.m2ts has length of 47 seconds which is less then minimum title length of 120 seconds and was therefore skipped
Title #00135.m2ts has length of 41 seconds which is less then minimum title length of 120 seconds and was therefore skipped
Title #00136.m2ts has length of 67 seconds which is less then minimum title length of 120 seconds and was therefore skipped
Title #00137.m2ts has length of 42 seconds which is less then minimum title length of 120 seconds and was therefore skipped
Title #00138.m2ts has length of 67 seconds which is less then minimum title length of 120 seconds and was therefore skipped
Title #00139.m2ts has length of 66 seconds which is less then minimum title length of 120 seconds and was therefore skipped
Title #00140.m2ts has length of 57 seconds which is less then minimum title length of 120 seconds and was therefore skipped
Title #00141.m2ts has length of 41 seconds which is less then minimum title length of 120 seconds and was therefore skipped
Title #00142.m2ts has length of 112 seconds which is less then minimum title length of 120 seconds and was therefore skipped
File 00143.m2ts was added as title #18
File 00145.m2ts was added as title #19
File 00146.m2ts was added as title #20
File 00150.m2ts was added as title #21
File 00151.m2ts was added as title #22
Title #00152.m2ts has length of 26 seconds which is less then minimum title length of 120 seconds and was therefore skipped
Title #00153.m2ts has length of 36 seconds which is less then minimum title length of 120 seconds and was therefore skipped
Title #00154.m2ts has length of 33 seconds which is less then minimum title length of 120 seconds and was therefore skipped
Title #00155.m2ts has length of 35 seconds which is less then minimum title length of 120 seconds and was therefore skipped
Title #00156.m2ts has length of 39 seconds which is less then minimum title length of 120 seconds and was therefore skipped
Title #00157.m2ts has length of 54 seconds which is less then minimum title length of 120 seconds and was therefore skipped
File 00158.m2ts was added as title #23
Title #00159.m2ts has length of 34 seconds which is less then minimum title length of 120 seconds and was therefore skipped
Title #00160.m2ts has length of 21 seconds which is less then minimum title length of 120 seconds and was therefore skipped
Title #00161.m2ts has length of 51 seconds which is less then minimum title length of 120 seconds and was therefore skipped
Title #00162.m2ts has length of 31 seconds which is less then minimum title length of 120 seconds and was therefore skipped
Title #00163.m2ts has length of 61 seconds which is less then minimum title length of 120 seconds and was therefore skipped
Title #00164.m2ts has length of 61 seconds which is less then minimum title length of 120 seconds and was therefore skipped
Title #00173.m2ts has length of 1 seconds which is less then minimum title length of 120 seconds and was therefore skipped
Title #00175.m2ts has length of 24 seconds which is less then minimum title length of 120 seconds and was therefore skipped
File 00186.m2ts was added as title #24
File 00188.m2ts was added as title #25
Title #00203.m2ts has length of 0 seconds which is less then minimum title length of 120 seconds and was therefore skipped
Title #00210.m2ts has length of 52 seconds which is less then minimum title length of 120 seconds and was therefore skipped
Title #00211.m2ts has length of 52 seconds which is less then minimum title length of 120 seconds and was therefore skipped
Title #00234.m2ts has length of 61 seconds which is less then minimum title length of 120 seconds and was therefore skipped
Operation sucessfully completed
After reading the disc, this takes a long time, the program gives a error and automatic shutdown.
TopGun2010
Re: Fatal error
Used disc:
Blu-ray
Disney-Pixar
Ratatouille
Re: Fatal error
TopGun, thank you!
that's a new thing, will look how to fix it. Sorry for inconvenience...:(
TopGun2010
Re: Fatal error
Hi Mike,
No problem, I am happy that I can help you to make this great program to work for all!
Greetings from Holland
Re: Fatal error
Hi. Can you please try to run console version (makemkvcon) and see if the problem still occures? You will need to run the following commands:
makemkvcon info disc:0
and
makemkvcon mkv disc:0 all c:\some_folder
, assuming you have a single optical drive. if you have multiple drives run "cddump l" to list all the drives. Please let me know if makemkvcon will crash or not.
TopGun2010
Re: Fatal error
Hi Mike,
I get with both options a very fast screen with several 100% marks. Nothing more.
Greetings
Re: Fatal error
Please try the latest version (1.3 build 778). It contains the fix for the error that probably was the reason for this failure.
TopGun2010
Re: Fatal error
Hi Mike!
It works! Used Ratatouille. Great playback on Popcorn Hour A-110. Still no subtitle.
Greetings TopGun
