change metadata information
ssizzl
Post by ssizzl »
While backing up my B5 discs the "Movie name" metadata information is a generic "B5: Season 1" for all titles. Is there any way to remove or change that data while the titles are being saved?
Re: change metadata information
Some meta data can be changed by enabling Expert Mode, and using the pull-downs that will then appear next to the track names.
ssizzl
Post by ssizzl »
How could I be so blind! Thanks! I totally missed that.
Devore
Post by Devore »
There are also tools based on the mkvtoolnix/mkvpropedit CLI library that can be used to edit MKV file properties, such as JMkvpropedit.
