not able to decrypt? error log included.
dubbcd
Post by dubbcd » Mon Nov 09, 2015 3:05 am
OS device name: /dev/sr0
Manufacturer: MATSHITA
Product: DVD-RAM UJ892AS
Revision: 1.21
Timestamp: 2014-09-26 09:10:01
Data capacity: 7.45 Gb
Disc type: DVD-ROM
Disc size: 120mm
Maximum read rate: 10.08 Mbps [1x]
Number of layers: 2 (OTP)
Linuxmint 17.2 Cinnamon 64bit
Linux version 3.16.0-38-generic
ffmepg aac enabled as forum listed procedures.
Debug log started at Sun Nov 8 08:18:27 2015 , written by MakeMKV v1.9.7 linux(x64-release)
001005:0000 MakeMKV v1.9.7 linux(x64-release) started
001004:0000 Debug logging enabled, log will be saved as /root/MakeMKV_log.txt
003002:0000 Calculated BUP offset for VTS #0 does not match one in IFO header.
003002:0000 Calculated BUP offset for VTS #1 does not match one in IFO header.
001003:0020 DEBUG: Code 0 at H^$9#=OwiZF)V/P>[:29393953
001003:0020 DEBUG: Code 8 at J^er/|6mR4;P`Wh|y:29395172
003002:0000 Calculated BUP offset for VTS #8 does not match one in IFO header.
003010:0000 Can't locate a cell for VTS 1 TTN 1 PGCN 0 PGN 0
003028:0000 Title #1 was added (22 cell(s), 2:55:14)
003028:0000 Title #2 was added (1 cell(s), 0:06:08)
003028:0000 Title #3 was added (1 cell(s), 0:02:07)
003025:0000 Title #4 has length of 100 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003028:0000 Title #5 was added (1 cell(s), 0:03:24)
003028:0000 Title #6 was added (1 cell(s), 0:02:54)
003028:0000 Title #7 was added (1 cell(s), 0:02:59)
003028:0000 Title #8 was added (1 cell(s), 0:03:09)
001003:0020 DEBUG: Code 233 at CEsqE+48h+oK7J5ypSfcWuZ3:0
005015:0000 Saving 1 titles into directory /home/Desktop/New Folder using profile 'AAC-stereo' from file '/usr/bin/../share/MakeMKV/aac-stereo.mmcp.xml'
001003:0020 DEBUG: Code 0 at |-h/=]RX*rpSAW}HJ:121262026
FFENC002: option afterburner=1
001002:0020 LIBMKV_TRACE: encoder 'libfdk_aac' not found in ffmpeg/libavcodec library
001003:0020 DEBUG: Code 0 at `gKY1=TrOly.Agsq69~0':121265338
001003:0020 DEBUG: Code 0 at WxResT`rmTA<U3n]DXo:29394528
001003:0020 DEBUG: Code 0 at WxResT`rmTA<U3n]DXo:121262279
001003:0020 DEBUG: Code 1 at Axgp8]ITyuQ.G{T{k^:29401106
001003:0020 DEBUG: Code 0 at Axgp8]ITyuQ.G{T{k^:121269800
005003:0000 Failed to save title 0 to file /home/Desktop/New Folder/title00.mkv
005004:0080 0 titles saved, 1 failed
005014:0000 Saving 1 titles into directory /home/Desktop/New Folder
csf8=1
csf6
Re: not able to decrypt? error log included.
Post by Woodstock » Mon Nov 09, 2015 4:23 am
Not sure if this is the cause, but:
What version of ffmpeg did you link against?
What happens if you use the default profile to rip, which does not do audio conversions?
