John Wick - US Version
gereral1
Re: John Wick - US Version
#76 Post by gereral1 » Wed Sep 30, 2015 6:10 pm
gereral1 wrote:
augerpro wrote:So is this indicating 641 is the correct mpls? If so what is 3? It didn't show on the screen. I think the disc is US netflix
3 if the fbi or dts dd trailer. Sometimes there's the company logo as well. Not to confuse you all but if you see a mpls file called then switches to a Long link to a powerdvd/cased/......Buda folder then you have to find the hidden mpls as shown in my other 2 videos. Else this method will work fine.
3 is either the DD dts trailer or the FBI warning. I know this is an old movie but still important info as all movies have a sound trailer or FBI warning before the main movie.
MZAdotcom
Re: John Wick - US Netflix Rental Version
#77 Post by MZAdotcom » Wed Oct 28, 2015 9:34 am
This is regarding the Netflix rental blu-ray: has the right file been figured out for this particular disc?
Hope I'm not missing anything, but have read all the posts in this thread several times; other versions, like Redbox, Amazon, etc., are mentioned more vs. the Netflix one.
Any help would be appreciated.
@HTPC: Intel NUC HTPC [BOXDN2820FYKH0] | Plextor 128GB SIII SSD | G.SKILL 8GB DDR3 1333 RAM | Win 10 Pro | SAMSUNG 55" LED HDTV | Harman/Kardon 5.1 AV Receiver [AVR 1565] | Dolby TrueHD | DTS-MA HD | Polk Audio 5.1 Home Theater System w/10" SW
MZAdotcom
RE: John Wick - US Netflix Version
#78 Post by MZAdotcom » Mon Nov 02, 2015 7:44 am
Just updating my last post here:
I can confirm 100% that what FL-Ronin posted on page 3 of this post/thread is the right file for the Netflix blu-ray version of "John Wick":
He wrote:
From what I read elsewhere...
Netflix Blu-Ray
Title information
Source file name: 00641.mpls
Duration: 1:41:12
Chapters count: 16
Segment count: 20
Segment map: 505,508,507,501,512,504,520,513,517,506,515,518,510,516,503,511,519,502,514,509
File name: John_Wick_t180.mkv
Watched to confirm and this is it. One of THE best revenge flicks, BTW; fantastic gun-play/action. Keanu Reeves @ his best.
Thanks, FL-Ronin, you/this thread helped me. Hope this helps others. Cheers.
mightyquinn
#79 Post by mightyquinn » Tue Nov 03, 2015 2:20 am
I recently tried to rip my Amazon version of John Wick using the 589.mpls and the scene with him getting the dog was out or order, even though it seems that most say that is the correct source file. Anyone else have problems with 589?
cdhaiki
#80 Post by cdhaiki » Sun Nov 08, 2015 8:09 pm
I just received my retail copy of John Wick from Amazon. When trying to rip with makemkv, I see the Segment map at both t174 and t175 are in a different order than what was previously posted. I suspect the order has was refreshed to confuse people trying to rip.
Manually searching through the play list, the following matches for me. I've not tested yet.
Title information
Source file name: 00202.mpls
Duration: 1:41:12
Chapters count: 16
Segment count: 20
Segment map: 508,501,503,511,510,516,520,518,507,512,519,513,509,517,515,506,514,504,502,505
File name: John_Wick_t53.mkv
For reference, the following on the same DVD do not match:
Title information
Source file name: 00588.mpls
Duration: 1:41:12
Chapters count: 16
Segment count: 20
Segment map: 508,511,501,503,510,516,520,507,519,512,518,513,509,506,515,517,514,504,502,505
File name: John_Wick_t174.mkv
Title information
Source file name: 00589.mpls
Duration: 1:41:12
Chapters count: 16
Segment count: 20
Segment map: 508,511,516,503,510,501,520,513,519,512,507,518,509,515,506,517,514,504,502,505
File name: John_Wick_t175.mkv
PaulCB
#81 Post by PaulCB » Fri Nov 20, 2015 6:49 am
deathtical wrote:Man... this BR is the biggest pain in the @$$. I have a copy I got from Amazon that has the BR+DVD+Digital. I tried the 589 that others have suggested and that doesn't work. What I mean by that is that once it is ripped it will not play and if I try to transcode it with Handbreak it will not detect an audio track even though I know it is there. I have AnyDVD and it says that PL202 (it also matches the chapter list others have posted) is the main one so I tried that as well and get the same thing. Do these guys really have nothing better to do that make life difficult for those of use that have legal copies and also have the legal right to make back up of it? The bar code on the package is 0 31398 21104 4 80. here is the report from AnyDVD...
Summary for drive E: (AnyDVD HD 7.6.2.0, BDPHash.bin 15-07-01)
ASUS BC-12B1ST 1.01 2011/04/20 21:37
Drive (Hardware) Region: 1
Media is a Blu-ray disc.
Total size: 23610688 sectors (46114 MBytes)
Video Blu-ray label: JOHN_WICK
Media is AACS protected!
Drive supports bus encryption!
Disc wants bus encryption!
AACS MKB version 53
Removed AACS copy protection!
Note: automatic detection of region code not possible with this disc.
Blu-ray Java signatures fixed!
BD-Live deactivated!
Sony structural BD-J protection removed!
Java BD protection good playlists: 202
Anyone else have any luck with this release? Thanks
I can confirm that, while my AnyDVD didn't give me the track number, 202 is correct for my copy from Amazon UPC: 031398211044. I played the disc and rip side by side, jumping to many different points and all chapter markers and it matches 100%
589, as mentioned multiple times here, is not which can be seen within 3 mins.
cdhaiki
#82 Post by cdhaiki » Sat Nov 21, 2015 7:40 am
Glad to you know that 202 matches for you! I agree it was a major pain. I also use Handbrake to transcode and it also had problems with the audio. I needed to get a new version of Handbrake to deal with the audio from this DVD. Luckily, I had just upgraded a computer to Fedora 23. The version of Handbrake there was new enough to be able to handle the DVD's audio format. So, I finally have a playable video. I hope the same path works for you.
Myrtledog
#83 Post by Myrtledog » Thu Nov 26, 2015 6:30 pm
Wow! 80+ replies and still no confirmed answer.
Not too sure "John Wick" is worth the hassle...
cdhaiki
#84 Post by cdhaiki » Thu Nov 26, 2015 6:45 pm
As stated above, 202 worked for me on the Blue-Ray of the Blu-Ray + DVD + Digital HD purchased in November 2015.
From the history above, it's apparent they are spinning different versions of it to discourage rips. You will need to verify that the segment map is in the correct order: 508,501,503,511,510,516,520,518,507,512,519,513,509,517,515,506,514,504,502,505
#85 Post by Woodstock » Fri Nov 27, 2015 5:13 am
The "no definitive answer" is because you get different disks depending on where and when you buy them.
danejaho
#86 Post by danejaho » Sun Jan 17, 2016 6:16 am
The key to John Wick is the first number in the scenes. If your disk series starts with 513 (scroll down the list and all the mpls files start with scene 513), than the right combination of scenes is:
513,502,515,504,509,512,508,505,503,506,510,518,516,507,519,511,514,501,517,520
This matched up with 00772.mpls on my disc but yours may differ. You have to go through the list (tediously) and find the matching combination on your disc.
If your disc series starts with 508, then the right combination of scenes is:
If your disc series starts with 505, then the right combination of scenes is:
Thanks Summit Entertainment for making this one such a PITA to backup for us legal, purchased disc owners who just need a digital backup. :roll:
Chris Burck
#87 Post by Chris Burck » Wed Mar 30, 2016 7:31 pm
I can tentatively confirm that the correct file for the Netflix (U.S.) disk is 0641, as others have already indicated.
I'm having a problem, though: even selecting what appears to be the correct file, I am getting scsi errors, device errors and medium errors out the wazoo. currently awaiting the third disk from Netflix to make one more attempt. I rely on Make MKV to view BluRay, because my player doesn't natively provide playback, so any help would definitely be appreciated.
MZAdotcom
#88 Post by MZAdotcom » Sun Apr 03, 2016 12:06 pm
Chris Burck wrote:I can tentatively confirm that the correct file for the Netflix (U.S.) disk is 0641, as others have already indicated.
As mentioned in my previous post, 0641 is 100% the correct file for the Netflix rental version. What version of MakeMKV are you using? I had SCSI error issues, etc., with an older one. Problem was fixed when I updated to the latest.
theOtherDave
#89 Post by theOtherDave » Sun Apr 24, 2016 11:13 pm
I also had troubles with a Netflix copy of John Wick. MakeMKV reported numerous errors when I tried to encode - I'm using the latest version too - v1.9.10. I think this disc may have some quality control issues - when I played it on my bluray player, the first fifteen minutes were fine, but then there were audio & visual freezes and stuttering playback. Hopefully a second copy will be better.
FatLibertarianDude
#90 Post by FatLibertarianDude » Wed Jun 08, 2016 9:00 pm
cdhaiki wrote:I just received my retail copy of John Wick from Amazon. When trying to rip with makemkv, I see the Segment map at both t174 and t175 are in a different order than what was previously posted. I suspect the order has was refreshed to confuse people trying to rip.
Title information
Duration: 1:41:12
Chapters count: 16
Segment count: 20
This is confirmed as correct for retail US purchased from Best Buy online. Thank you.
