Do any Blu-ray players display MPLS or M2TS files? (re: TV)
sofakng
Post by sofakng »
Are there any Blu-ray players (software) that display the actual MPLS or M2TS being played?
When I'm trying to rip a television series Blu-ray it's sometimes hard to determine the correct tracks.
Ideally I'd like a Blu-ray player with full menu support that just let's me click [Save] on each item :)
watchy
Re: Do any Blu-ray players display MPLS or M2TS files? (re:
Post by watchy »
sofakng wrote:Are there any Blu-ray players (software) that display the actual MPLS or M2TS being played?
try dvdfab media player. it will display the correct playlist. it didnt work for awhile but i complained enough and it seems fixed now.
gereral1
Post by gereral1 »
Purchased copy of powerdvd 14 or 15 with process monitor will display all playlist info being played including m2ts and mpls. We use this tool to figure out screen pass protected disks but it can easily be used to determine if a theater version or uncut version (extended) is being played at a specific time.
This gets more advanced when dealing with cashed mpls files but 99 percent of the movies or TV shows on the disk will work.
