Anyone having trouble converting "unfinished business"
boe_d
#1 Post by boe_d » Thu Oct 29, 2015 5:12 am
I only find one in every few hundred I have any issues with (my reader has current firmware and drivers and has no issues with makemkv with other discs).
MakeMKV v1.9.7 win(x64-release) started
Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/BDMV/STREAM/01755.m2ts' at offset '1274204160'
Loaded 51 SVQ file(s)
Processing BD+ code, please be patient - this may take up to few minutes
Processing BD+ code using disc-specific SVQ from builtin/dsall.svq
BD+ code processed, got 1 FUT(s) for 1 clip(s)
Title #00131.mpls has length of 8 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00250.mpls has length of 6 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00260.mpls has length of 6 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00261.mpls has length of 6 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00262.mpls has length of 6 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00263.mpls has length of 6 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00350.mpls has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00012.mpls has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00020.mpls has length of 52 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Error 'Scsi error - MEDIUM ERROR:POSITIONING ERROR DETECTED BY READ OF MEDIUM' occurred while reading '/BDMV/STREAM/01755.m2ts' at offset '0'
Error 'Scsi error - HARDWARE ERROR:441E' occurred while reading '/BDMV/STREAM/01755.m2ts' at offset '129024'
Error 'Scsi error - HARDWARE ERROR:441E' occurred while reading '/BDMV/STREAM/01755.m2ts' at offset '325632'
Error 'Scsi error - MEDIUM ERROR:POSITIONING ERROR DETECTED BY READ OF MEDIUM' occurred while reading '/BDMV/STREAM/01755.m2ts' at offset '325632'
Failed to decode audio/video data for title #0 - invalid mux or internal error, title skipped.
Title #00800.mpls was skipped
File 00300.mpls was added as title #0
Title #00199.mpls has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00301.mpls has length of 67 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/BDMV/STREAM/02105.m2ts' at offset '0'
Title #00302.mpls was skipped
Title #00303.mpls has length of 98 seconds which is less than minimum title length of 120 seconds and was therefore skipped
File 00304.mpls was added as title #1
Title #00305.mpls has length of 47 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00306.mpls has length of 46 seconds which is less than minimum title length of 120 seconds and was therefore skipped
File 00307.mpls was added as title #2
File 00308.mpls was added as title #3
Title #00309.mpls has length of 92 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00310.mpls has length of 70 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00311.mpls has length of 118 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00312.mpls has length of 71 seconds which is less than minimum title length of 120 seconds and was therefore skipped
File 00313.mpls was added as title #4
Title #00314.mpls has length of 14 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00315.mpls has length of 32 seconds which is less than minimum title length of 120 seconds and was therefore skipped
File 00316.mpls was added as title #5
Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/BDMV/STREAM/01755.m2ts' at offset '651264'
Error 'Scsi error - MEDIUM ERROR:POSITIONING ERROR DETECTED BY READ OF MEDIUM' occurred while reading '/BDMV/STREAM/01755.m2ts' at offset '651264'
Failed to decode audio/video data for title #6 - invalid mux or internal error, title skipped.
Title #00850.mpls was skipped
Title #00324.mpls has length of 68 seconds which is less than minimum title length of 120 seconds and was therefore skipped
File 00328.mpls(1) was added as title #6
File 00328.mpls(3) was added as title #7
Title #00600.m2ts has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00601.m2ts has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00131.m2ts has length of 8 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00123.m2ts has length of 20 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00151.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00152.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00153.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00154.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00155.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00156.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00158.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00159.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00160.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00197.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00162.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00163.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00164.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00165.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00166.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00167.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00168.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00169.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00170.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00171.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00172.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00173.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00175.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00176.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00179.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00180.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00182.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00183.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00185.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00186.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00187.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00189.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00190.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00188.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00191.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00192.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00193.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00194.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00195.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00196.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00150.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00727.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00121.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00233.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00200.m2ts has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00122.m2ts has length of 11 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #01756.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #01757.m2ts has length of 6 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #02145.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #02146.m2ts has length of 6 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #02147.m2ts has length of 6 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #02148.m2ts has length of 6 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #02149.m2ts has length of 6 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #02150.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #01780.m2ts has length of 9 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #01781.m2ts has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #02090.m2ts has length of 68 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #02101.m2ts has length of 59 seconds which is less than minimum title length of 120 seconds and was therefore skipped
File 02103.m2ts was added as title #8
Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/BDMV/STREAM/02119.m2ts' at offset '1376256'
Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/BDMV/STREAM/02119.m2ts' at offset '1898496'
Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/BDMV/STREAM/02119.m2ts' at offset '3274752'
Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/BDMV/STREAM/02119.m2ts' at offset '3864576'
Failed to decode audio/video data for title #9 - invalid mux or internal error, title skipped.
Title #02119.m2ts was skipped
File 02120.m2ts was added as title #9
Title #02121.m2ts has length of 98 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #02122.m2ts has length of 24 seconds which is less than minimum title length of 120 seconds and was therefore skipped
File 02123.m2ts was added as title #10
Title #02124.m2ts has length of 40 seconds which is less than minimum title length of 120 seconds and was therefore skipped
File 02125.m2ts was added as title #11
Title #00021.m2ts has length of 26 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Error 'Scsi error - HARDWARE ERROR:441E' occurred while reading '/BDMV/STREAM/01755.m2ts' at offset '0'
Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/BDMV/STREAM/01755.m2ts' at offset '129024'
Failed to decode audio/video data for title #12 - invalid mux or internal error, title skipped.
Title #01755.m2ts was skipped
Title #02126.m2ts has length of 112 seconds which is less than minimum title length of 120 seconds and was therefore skipped
File 02127.m2ts was added as title #12
Title #02153.m2ts has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #02154.m2ts has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
