I've tried this on my PC and my MAC and get the same error with both...
MakeMKV v1.9.7 win(x64-release) started
File 00013.mpls was added as title #0
File 00800.mpls was added as title #1
File 00353.mpls was added as title #2
File 00360.mpls was added as title #3
Title 00801.mpls is equal to title 00800.mpls and was skipped
Title #00018.m2ts has length of 25 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00019.m2ts has length of 14 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00015.m2ts has length of 25 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00014.m2ts has length of 25 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00016.m2ts has length of 59 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00017.m2ts has length of 59 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #50355.m2ts has length of 26 seconds which is less than minimum title length of 120 seconds and was therefore skipped
File 00350.m2ts was added as title #4
Title #00351.m2ts has length of 48 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00352.m2ts has length of 32 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00354.m2ts has length of 32 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00355.m2ts has length of 32 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00356.m2ts has length of 31 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00357.m2ts has length of 32 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00358.m2ts has length of 32 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00359.m2ts has length of 32 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Saving 1 titles into directory C:/Users/jared/Desktop/DVD RIP
Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/BDMV/STREAM/00800.m2ts' at offset '11228676096'
Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/BDMV/STREAM/00800.m2ts' at offset '11228682240'
Failed to save title 1 to file C:/Users/jared/Desktop/DVD RIP/The_Theory_of_Everything_t01.mkv
0 titles saved, 1 failed
here is the drive info:
OS device name: E:
Product: BD-RE BE14NU40
Revision: 1.01
Serial number: K98F29D5404
Firmware date: 2114-08-22 16:31:
Bus encryption flags: 1F
Highest AACS version: 47
and the disc info:
Disc Information
Label: THEORYOFEVERYTHINGRENTAL_NA
Timestamp: 2014-12-18 12:01:55
Data capacity: 34.5 Gb
Disc type: BD-ROM
Number of layers: 2
thanks...
jared
The Theory of Everything - Error Saving
Re: The Theory of Everything - Error Saving
Cleaning the disk is probably in order. I'd probably wax it.
