Default save location
b_m_hart
Post by b_m_hart »
What is the point of having the option to choose a default save location if the program NEVER uses it?
Re: Default save location
If it NEVER used it, no, there wouldn't be.
However, MakeMKV does make use of it, depending upon your settings. It will use it as part of the path for "Auto" and "SemiAuto". I think "Custom" uses it exactly as typed into the box, although I haven't tried it in a while.
Only the setting "None" will never use it.
