My understanding of DTS-HD MA is that it can (and typically is) bundled with a core audio of simply DTS, that it can fall back to DTS with DTS-HD MA is not supported. In MakeMKV it appears as a nested track and that you can select each individually, allowing you to create a larger or smaller file. My confusion is in the result when both are selected. The resulting file is not a single audio track with both the DTS-HD MA and DTS but two tracks, one DTS-HD MA and the other DTS, between you must manually select. This does not appear to be the case with other remuxing processes.
Why is this the case?
Example:
MakeMKV where both DTS-HD MA and DTS are selected. When the DTS core 'subtrack' is not selected there is no Audio #2:
Audio #1
Format : DTS
Format/Info : Digital Theater Systems
Format profile : MA / Core
Mode : 16
Format settings, Endianness : Big
Codec ID : A_DTS
Duration : 1h 34mn
Bit rate mode : Variable
Bit rate : Unknown / 1 509 Kbps
Channel(s) : 6 channels
Channel positions : Front: L C R, Side: L R, LFE
Sampling rate : 48.0 KHz
Bit depth : 24 bits
Compression mode : Lossless / Lossy
Title : Surround 5.1
Language : English
Default : Yes
Forced : No
Audio #2
Format : DTS
Mode : 16
Codec ID : A_DTS
Duration : 1h 34mn
Bit rate mode : Constant
Bit rate : 1 509 Kbps
Bit depth : 24 bits
Compression mode : Lossy
Stream size : 1 016 MiB (5%)
Language : English
Default : No
Forced : No
Audio #1
Format : DTS
Mode : 16
Codec ID : A_DTS
Duration : 1h 31mn
Bit depth : 16 bits
Title : DTS-HD MA 5.1 / 48 kHz / 2259 kbps / 16-bit (DTS Core: 5.1 / 48 kHz / 1509 kbps / 16-bit)
Language : English
Default : Yes
Forced : No
