Problems with installation of makemkv bin
StarFishes
Post by StarFishes »
Hi all!
I just ran into a problem installing makemkv-bin on my machine. A couple of months ago I installed version 1.9.3 without any problems. Installation of makemkv-oss just went through, but when trying to install makemkv-bin it says that it cannot change the priviliges on /usr/share/MakeMKV
The makefile says some line: install -d $(DESTDIR)$(PREFIX)/share/MakeMKV
I can understand why the message comes up, there is no such folder!
But why is that? The same routine a couple of months ago went fine, the makefile says that line: install -d $(DESTDIR)/usr/share/MakeMKV
Anyone got an idea why this is happening?
Thanks in advance!
StarFishes
StarFishes
Re: Problems with installation of makemkv bin
Okay, I found out the following: I can create such a folder, then the installation works.
But: Does it work as designed? Seems to be an error for me.
Best regards
StarFishes
