Paper Towns Blu Ray gets no FUTs
mmahouski112689
Post by mmahouski112689 »
Hi everyone I got the error when trying to do Paper Towns No FUTs are available anyone else try this one yet?
Re: Paper Towns Blu Ray gets no FUTs
When you got that message, there should have been a link showing a file generated, with the extension .tgz in its name. Have you followed the instruction to foward that file to svq@makemkv.com?
More information can be found here: http://www.makemkv.com/svq/
ekael86
Post by ekael86 »
I went ahead and sent in the dump file for this disc last week. I am new here so how long does this process typically take?
That depends upon Mike and his schedule.
If you have enabled checking the web for updates, once he processes it, MakeMKV will pick up the file as needed.
A lot of people do NOT have web updates turned on, for very valid security reasons... If you don't, you will have to turn them on periodically to allow MakeMKV to check.
