Hi
I've downloaded v1.01 build 650, which does seem to fix the BD ISO image opening problems. However, I'm not able to test whether it can make an MKV because it crashes with a "fatal error occured, programm will now exit".
Here's the recipe:
1. Run MakeMKV (v1.01 build 650).
2. It will automatically scan the drives. Let it sit for about 1-2 minutes and the "fatal error" dialog will pop up.
Notes:
The previous build did not do this. I was able to make an MKV from a DVD ISO.
My setup:
XP Pro SP3
Memorex IDE CD/DVD
LiteOn USB2 CD/DVD/BD
FireFox running
AnyDVD HD, VirtualClone, and other programs installed but not running (exited from tray and not running in task manager)
HTH
Crash: "fatal error occured, programm will now exit&quo
FancyPants
FancyPants
atari916
Re: Crash: "fatal error occured, programm will now exit&quo
For "Fatal error occured.. program will now exit"
Try running MakeMKV *without* firefox running. Don't ask me why this works. My guess is that either firefox or MakeMKV doesn't respect the memory space used or something. I couldn't figure out why the hell MakeMKV (current version as of this posting) was working and then would erratically get these errors. I've had FF crash on me a few times in OSX, so I started eliminating running programs -- once firefox was completely killed during MakeMKV runs, no more fatal errors.
