BD+ code processed but no FUTs were obtained, Lost In Space
decadentdave
Re: BD+ code processed but no FUTs were obtained, Lost In Sp
Post by decadentdave »
Just got the BD+ error no FUTS on Disc 3. :(
For what it is worth, MOST FUT issues are addressed through SVQ files, per http://www.makemkv.com/svq/
decadentdave
Woodstock wrote:For what it is worth, MOST FUT issues are addressed through SVQ files, per /svq/
Don't know what that means.
Disc 3 ripped with corrupted video files. So this means each disc is going to have different FUTS keys or whatever so a fix will need to be addressed on a disc per disc basis. Oy.
What it means is that, as information on BD+ changes is obtained, new SVQ files can be generated that fix the problem, without having to change the main program. That is why MakeMKV generates a file when it encounters an unknown BD+ program.
These SVQ files are available for automatic download as the disks that need them are ripped.... Unless you tell MakeMKV not to look for them. You can then try the rip every few days, and it will "suddenly" work. Just watch for the "no FUTs" message; if it is still there, no SVQ is available yet.
tbuick6
Post by tbuick6 »
Same here, only discs 1 and 2 of Season 1 rip without errors. Do we need to submit a log for each disc?
For the ones that worked, no need. But the disk that failed, Mike will want the .tgz file created with the BD+ code in it. Name should be in the log, right after the message about no FUTs generated.
tbuick6
Post by tbuick6 »
Submitted TGZ info for Discs 3-6 of Season 1. Hopefully, these can be resolved soon as they are the only discs of the set to still produce errors. I was successful in ripping flawless episodes from the remaining 14 discs of the set. Thanks Mike!!!
tbuick6
Post by tbuick6 »
Can now report all discs now rip correctly with no errors! All 18! Thanks to all that contributed to getting this fixed!
RokkoRokko
Post by RokkoRokko »
Cheers for the sortout, guys
Its awesome to have these
Give me a few months and I will have some very special treats for Lost in Space fans
Muzzy
Post by Muzzy »
RokkoRokko wrote:Cheers for the sortout, guys
Ohh I can Hardly wait...I am LOVIN this Bd Release of LiS
