Are older versions available
q3131a
#1 Post by q3131a » Thu Oct 08, 2015 6:30 pm
Encountered the SCSI error with 1.97. Are older versions available for download?
Re: Are older versions available
#2 Post by Woodstock » Thu Oct 08, 2015 6:34 pm
/download/old/ (where the old versions are normally kept) is currently off-line, because of a problem at the data center.
SCSI errors come from hardware. Unless the error says something about a key exchange, changing the version of MakeMKV isn't going to change your hardware.
q3131a
#3 Post by q3131a » Mon Oct 12, 2015 2:50 pm
Woodstock wrote:http://makemkv.com/download/old/ (where the old versions are normally kept) is currently off-line, because of a problem at the data center.
If you look for SCSI errors in threads in both general and error report sections, you will find multiple threads about these errors since the 1.9.7 upgrade.
The best way to know for sure is to get the error, then install an older version to see if you get the same error.
