U2 360° ate the Rose Bowl
Browsercheck
#1 Post by Browsercheck » Sun Sep 06, 2015 7:37 pm
Cannot decode the BD. Decoding stops to save the MKV on aprox. 487 MB.
Is there a solution?
Re: U2 360° ate the Rose Bowl
#2 Post by Woodstock » Mon Sep 07, 2015 1:33 am
Possibly. But, without information on what errors you're receiving, it's awfully hard to guess.
See the FAQ in my signature for more information on how to help us help you.
Browsercheck
#3 Post by Browsercheck » Tue Oct 06, 2015 1:19 pm
Sorry it took so long for my answer...
Of course you need some more informations. Here is the errorlog:
Saving 1 titles into directory F:/FILME und SERIEN/FILME/MUSIC/U2
Error 'Scsi error - MEDIUM ERROR:UNRECOVERED READ ERROR' occurred while reading '/BDMV/STREAM/00000.m2ts' at offset '613871616'
DEBUG: Code 0 at Y|IF&],tF&yI9BW_ayAs:121263038
DEBUG: Code 0 at R}R^X=e:}TnPR/)k|fqy:121262302
DEBUG: Code 0 at Y|IF&],tF&yI9BW_ayAs:213130559
DEBUG: Code 299742 at Y|IF&],tF&yI9BW_ayAs:29393286
DEBUG: Code 0 at dTY}Ut\3Z+1[99lR]yBK&:29398967
Failed to save title 2 to file F:/FILME und SERIEN/FILME/MUSIC/U2/U2_360_At_the_Rose_Bowl_t02.mkv
0 titles saved, 1 failed
The disk is OK, there are no scratches and in my BR-Player I can play and look the disk.
Thank for your help.
#4 Post by Woodstock » Tue Oct 06, 2015 5:59 pm
Hardware can't read disk.
Just because it "plays in BD player" does not mean the disk has no flaws... BD players, like DVD players, are programmed to ignore errors.
Browsercheck
#5 Post by Browsercheck » Thu Oct 08, 2015 2:14 pm
Thanks for your answer.
So the Disk is defect. :(
#6 Post by Woodstock » Thu Oct 08, 2015 6:29 pm
You can try cleaning and waxing the disk; I find it works for most "defective" disks my relatives return to me. I use furniture polish (Pledge brand, specifically). Spray on, rub in with a CLEAN finger until it starts to dry, then wipe off with a clean cotton or microfibre cloth.
Anything it does not "fix" probably needs proper resurfacing.
