Monsters, Inc & Skyfall
draden1
#1 Post by draden1 » Tue Oct 06, 2015 12:50 am
If anyone could please help me out with the error below I'd really appreciate it. Over the last 2 nights I've ripped a whole bunch of my dvd's with no issue but I've tried 3 blurays and they all give me this error.
Error 'Scsi error - HARDWARE ERROR:441E' occurred while reading '/BDMV/STREAM/00019.m2ts' at offset '5240125440'
Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/BDMV/STREAM/00019.m2ts' at offset '5242023936'
Error 'Scsi error - MEDIUM ERROR:POSITIONING ERROR DETECTED BY READ OF MEDIUM' occurred while reading '/BDMV/STREAM/00019.m2ts' at offset '5242023936'
Failed to save title 0 to file G:/Movies/Blu-ray/Monsters,_Inc_(Disc_1)_t00.mkv
0 titles saved, 1 failed
It doesn't matter what blu's either, I've tried Skyfall and Monsters, Inc twice. I've used versions 1.9.7 and 1.9.6.
preserve
Re: Monsters, Inc & Skyfall
#2 Post by preserve » Tue Oct 06, 2015 1:12 am
Someone can correct me if I'm wrong, but "MEDIUM ERROR" is media error I believe, unable to read media at the position given.
Check whether or not the disc is perfectly clean. I'm not sure how "fussy" Blu-ray is. I try to back up my discs as soon as I get them now. Only had similar error occur once, and I suspect it might have been due to very light scratches.
Using: ASUS BW-16D1HT 3.00
draden1
#3 Post by draden1 » Tue Oct 06, 2015 1:27 am
It could be but I doubt it's due to bad discs. I own both titles and they are in great shape. I've never had an issue ripping blurays until this so I'm not sure what to do? And by the way, I did clean the disc and try again and got the same message. The message appears at the very end of the rip when there's approx 1 minute left.
#4 Post by Woodstock » Tue Oct 06, 2015 2:11 am
But, a medium error is a report from the operating system that the drive can't read the disk. Yours seem to be a drive problem:
leewalk
#5 Post by leewalk » Tue Oct 06, 2015 5:36 pm
I just starting seeing the same errors on 1.9.7 too - disks worked fine before this version.
Did anything change in 1.9.7?
Lee
