Question on the November 2015 Beta Key
mechevar
#1 Post by mechevar » Thu Oct 01, 2015 10:34 pm
EDIT This has been fixed with 1.9.7
Just curious if this is a known issue. I tried to use the Beta registration code that is good through November 2015 and on startup I get a message that 'Your temporary key has expired and was removed. Please restart the application'.
I have MakeMKV installed off this ppa
http://ppa.launchpad.net/heyarje/makemkv-beta/ubuntu
LouieChuckyMerry
Re: Question on the November 2015 Beta Key
#2 Post by LouieChuckyMerry » Fri Oct 02, 2015 8:55 am
I'm on Win 7 with the same issue. I had v1.9.6 installed with the old beta key, but it's an endless loop when trying to apply the new beta key:
1) "Your temporary key has expired and was removed. Please restart the application."
2) "This application version is too old. Please download the lateset version at / or enter a registration key to continue using the current version.:
3) Restart MakeMKV.
4) Apply new beta key.
5) "Thanks you. Please restart the application for changes to take effect.
6) Restart MakeMKV.
7) Repeat.
I tried uninstalling-reinstalling MakeMKV, the latest version as of ten minutes ago, but I still can't apply the new beta key. Thanks for any help.
Edit: In case anyone bumps into this, the issue was corrected with v1.9.7. Thank you :) .
