MOVED: getting different results
kd111
#1 Post by kd111 » Thu Mar 25, 2010 2:10 pm
Yes it has worked before, I have a lot of rips from MakeMKV 1.4.8 and 1.4.10 and one from 1.5.0.
But there seems to be something else amiss. I am not getting reliable results with 1.5.0 onwards.
I'm currently playing with makemkvcon and "Requiem for a Dream Region 1, BD+" (which I know to be good) and I'm getting different results when I do exactly the same thing a few times in a row. I'll reply to this post when I have more information.
This is what I'm running right now:
#!/bin/sh
cd ~/hd/makemkv
dst=../../tmp/mkv
for i in 1.5.0 1.5.1 1.5.2; do
        cd makemkv_v${i}_beta_bin
        sudo make -f makefile.linux install
        cd ..
        cd makemkv_v${i}_beta_oss
        cd ..
        for j in `seq 1 10`; do
                LOG=log${i}_${j}.txt
                killall makemkvcon
                rm -f $dst/*
                eject /dev/scd0
                sleep 1
                eject -t /dev/scd0
                sleep 15
                /usr/bin/time makemkvcon mkv -r --decrypt --progress=-same --messages=-stdout --directio=true disc:0 all $dst >$LOG 2>&1
                ls -nl $dst/* >>$LOG 2>&1
                sha1sum $dst/* >>$LOG 2>&1
        done
done
edit: updated script
Re: MOVED: getting different results
#2 Post by mike admin » Sat Mar 27, 2010 10:33 am
Each MKV file has a randomly-assigned file id. If you see any differences aside from this ID please post the details.
kd111
#3 Post by kd111 » Sat Mar 27, 2010 4:45 pm
Yes, I've noticed that the sha1sum is different every time, but that aside, I still see something going wrong.
I did a few testruns on my main computer where I ripped almost all my Bluray discs before, but I couldn't get the disc to rip successfully everytime, so I assumed bad hardware (maybe bad RAM or overheating) and tried another machine.
On that machine, I still can't get reliable results with 1.5.0-1.5.2.
With 1.5.0, 4 of the 10 runs ripped the disc successfully, but the resulting mkv files were not always the same size
log1.5.0_1.txt:-rw-r--r-- 1 1000 1000 31710430558 2010-03-26 16:12 /tmp/mkv/title00.mkv
log1.5.0_3.txt:-rw-r--r-- 1 1000 1000 31710430558 2010-03-26 18:07 /tmp/mkv/title00.mkv
log1.5.0_8.txt:-rw-r--r-- 1 1000 1000 31710430558 2010-03-26 19:43 /tmp/mkv/title00.mkv
log1.5.0_10.txt:-rw-r--r-- 1 1000 1000 31710430628 2010-03-26 21:23 /tmp/mkv/title00.mkv
The remaining 6 runs failed with "This disc uses newer version of AACS protection. Please let us know about it by visiting [...]"
I have the logfiles saved, so if you think that might help, I can send them to you.
I'm currently running the script for 1.5.1 and 1.5.2 and will post when I have the results.
kd111
#4 Post by kd111 » Mon Mar 29, 2010 1:36 pm
Results for 1.5.1:
6 times "This disc uses newer version of AACS protection"
3 successful rips
1 time a similar symptom as http://www.makemkv.com/forum2/viewtopic.php?f=3&t=1092 was experiencing. An endless loop around:
PRGC:3406,0,"Processing BD+ code"
PRGV:0,10537,65536
PRGC:3403,0,"Processing titles"
MSG:3025,0,3,"Title #00183.mpls has length of 118 seconds which is less than minimum title length of 120 seconds and was therefore skipped","Title #%1 has length of %2 seconds which is less than minimum title length of %3 seconds and was therefore skipped","00183.mpls","118","120"
PRGV:12233,10537,65536
PRGV:12233,12336,65536
MSG:3307,0,2,"File 00004.mpls was added as title #0","File %1 was added as title #%2","00004.mpls","0"
PRGV:29709,12336,65536
PRGV:29709,14906,65536
MSG:1003,32,3,"DEBUG: Code 2 at [h;'U\\.'0;mjc:29393562","DEBUG: Code %1 at %2:%3","2","[h;'U\\.'0;mjc","29393562"
MSG:1003,32,3,"DEBUG: Code 167 at <p>~UI!y8t.2)|YSCkvo`:121263636","DEBUG: Code %1 at %2:%3","167","<p>~UI!y8t.2)|YSCkvo`","121263636"
MSG:1003,32,3,"DEBUG: Code 184 at <p>~UI!y8t.2)|YSCkvo`:121263636","DEBUG: Code %1 at %2:%3","184","<p>~UI!y8t.2)|YSCkvo`","121263636"
MSG:1003,32,3,"DEBUG: Code 177 at <p>~UI!y8t.2)|YSCkvo`:121263636","DEBUG: Code %1 at %2:%3","177","<p>~UI!y8t.2)|YSCkvo`","121263636"
Results for 1.5.2:
Ripping always fails with "This disc uses newer version of AACS protection."
Here's an example log:
MSG:1005,0,1,"MakeMKV v1.5.2 beta linux(x86-release) started","%1 started","MakeMKV v1.5.2 beta linux(x86-release)"
MSG:1004,0,1,"Debug logging enabled, log will be saved as /home/kd111/MakeMKV_log.txt","Debug logging enabled, log will be saved as %1","/home/kd111/MakeMKV_log.txt"
PRGT:5018,0,"Scanning CD-ROM devices"
PRGC:5018,0,"Scanning CD-ROM devices"
PRGV:0,0,65536
PRGV:0,0,65536
MSG:1003,32,3,"DEBUG: Code 0 at ]9:2J1;IWT!I9);Z0o#j:213130122","DEBUG: Code %1 at %2:%3","0","]9:2J1;IWT!I9);Z0o#j","213130122"
PRGV:65536,0,65536
PRGV:65536,65536,65536
DRV:0,1,1,12,"HD-DVD-ROM HL-DT-ST BDDVDRW GGC-H20L 1.03","REQUIEM_FOR_A_DREAM"
DRV:1,0,0,0,"",""
DRV:2,0,0,0,"",""
DRV:3,0,0,0,"",""
DRV:4,0,0,0,"",""
DRV:5,0,0,0,"",""
DRV:6,0,0,0,"",""
DRV:7,0,0,0,"",""
DRV:8,0,0,0,"",""
DRV:9,0,0,0,"",""
DRV:10,0,0,0,"",""
DRV:11,0,0,0,"",""
DRV:12,0,0,0,"",""
DRV:13,0,0,0,"",""
DRV:14,0,0,0,"",""
DRV:15,0,0,0,"",""
PRGV:0,65536,65536
PRGV:0,0,65536
MSG:3007,0,0,"Using direct disc access mode","Using direct disc access mode"
PRGT:3404,0,"Opening Blu-ray disc"
PRGC:3400,0,"Processing AV clips"
PRGV:0,0,65536
PRGV:0,0,65536
PRGV:24797,0,65536
PRGV:24797,1799,65536
PRGV:31882,1799,65536
PRGV:31882,2313,65536
PRGV:40738,2313,65536
PRGV:40738,2955,65536
PRGC:3401,0,"Processing movie playlists"
PRGV:0,2955,65536
PRGV:20695,2955,65536
PRGV:20695,4497,65536
PRGV:63811,4497,65536
PRGV:63811,7710,65536
PRGC:3402,0,"Decrypting"
PRGV:0,7710,65536
MSG:5050,0,2,"Evaluation version, 27 day(s) out of 30 remaining","Evaluation version, %1 day(s) out of %2 remaining","27","30"
PRGV:11497,7710,65536
PRGV:11497,8995,65536
PRGV:12647,8995,65536
PRGV:12647,9123,65536
PRGV:13797,9123,65536
PRGV:13797,9252,65536
PRGV:14946,9252,65536
PRGV:14946,9380,65536
PRGV:16096,9380,65536
PRGV:16096,9509,65536
PRGV:17246,9509,65536
PRGV:17246,9637,65536
PRGV:18396,9637,65536
PRGV:18396,9766,65536
PRGV:19545,9766,65536
PRGV:19545,9894,65536
PRGV:20695,9894,65536
PRGV:20695,10023,65536
PRGV:21845,10023,65536
PRGV:21845,10151,65536
PRGV:22995,10151,65536
PRGV:22995,10280,65536
PRGV:24144,10280,65536
PRGV:24144,10408,65536
PRGV:25294,10408,65536
PRGV:25294,10537,65536
PRGV:26444,10537,65536
PRGV:26444,10665,65536
PRGV:27594,10665,65536
PRGV:27594,10794,65536
PRGV:28743,10794,65536
PRGV:29893,10922,65536
PRGV:29893,11051,65536
PRGV:31043,11051,65536
PRGV:31043,11179,65536
PRGV:32193,11179,65536
PRGV:32193,11308,65536
PRGV:33342,11308,65536
PRGV:33342,11436,65536
PRGV:34492,11436,65536
PRGV:34492,11565,65536
PRGV:35642,11565,65536
PRGV:35642,11693,65536
PRGV:36792,11693,65536
PRGV:36792,11822,65536
PRGV:37941,11822,65536
PRGV:37941,11950,65536
PRGV:39091,11950,65536
PRGV:39091,12079,65536
PRGV:40241,12079,65536
PRGV:40241,12207,65536
PRGV:41391,12207,65536
PRGV:41391,12336,65536
PRGV:42540,12336,65536
PRGV:42540,12464,65536
PRGV:43690,12464,65536
PRGV:43690,12593,65536
PRGV:44840,12593,65536
PRGV:44840,12721,65536
PRGV:45990,12721,65536
PRGV:45990,12850,65536
PRGV:47139,12850,65536
PRGV:47139,12978,65536
PRGV:48289,12978,65536
PRGV:48289,13107,65536
PRGV:49439,13107,65536
PRGV:49439,13235,65536
PRGV:50589,13235,65536
PRGV:50589,13364,65536
PRGV:51738,13364,65536
PRGV:51738,13492,65536
PRGV:59787,13492,65536
PRGV:59787,14392,65536
MSG:3310,0,1,"This disc uses newer version of AACS protection. Please let us know about it by visiting http://www.makemkv.com/a/?AAAAAABkKfVpgaipWzK3PAia/HYdkHXM86FBQ8r6LtthtsgI/VGjSkYUdeOT0XUFShqyAr23tqn2joX06xko6HLfOy5It4TRFVIjKfm37Q0ccldhDWrzE93eD4vZc02arfdZ8YsoSdqP5ddtGeXvdcEA6Pu1TMJR2Qy5KbvxIgAR/4SouQ2Suz2WoOC0
0t9RoPLj1KZkOkGPryJTbgKYsxIKwUjNtzXik/s6aisYHTpfpSVESxZ5vEgpRorIBR8u2NFrSSX81Z4v6pWO8sDG/jdjV8H4rCVezDTKlAO6kVFjeF+2H6ZJBqwwc6VG2muPvvAIJtZY/zcI0BLOKY9BMMkMaMhQVLL92ojwHvhzFzeSLxb1xRvhqjWbYMd86GP38K7QC6MMAsQNTQ9M2k3SsVsyQ5G+nWF2niTN6ycN0mUU4vY+ZyuE3N3JzZDfb4I/Sg/jKrVtXO0gy4uwCA6Uze0UPVyvTDQeKH76rdCwOWkDj/bHcoirUKhGF
3+Og8N9E7iKAtaxocfXREvMsQQUUgwzZmlp/5Af2BJ7XEo6LIv6e+MuQA8=","This disc uses newer version of AACS protection. Please let us know about it by visiting http://www.makemkv.com/a/?%1","AAAAAABkKfVpgaipWzK3PAia/HYdkHXM86FBQ8r6LtthtsgI/VGjSkYUdeOT0XUFShqyAr23tqn2joX06xko6HLfOy5It4TRFVIjKfm37Q0ccldhDWrzE93eD4vZc02arfdZ8Ys
oSdqP5ddtGeXvdcEA6Pu1TMJR2Qy5KbvxIgAR/4SouQ2Suz2WoOC00t9RoPLj1KZkOkGPryJTbgKYsxIKwUjNtzXik/s6aisYHTpfpSVESxZ5vEgpRorIBR8u2NFrSSX81Z4v6pWO8sDG/jdjV8H4rCVezDTKlAO6kVFjeF+2H6ZJBqwwc6VG2muPvvAIJtZY/zcI0BLOKY9BMMkMaMhQVLL92ojwHvhzFzeSLxb1xRvhqjWbYMd86GP38K7QC6MMAsQNTQ9M2k3SsVsyQ5G+nWF2niTN6ycN0mUU4vY+ZyuE3N3JzZDfb4I/Sg/j
KrVtXO0gy4uwCA6Uze0UPVyvTDQeKH76rdCwOWkDj/bHcoirUKhGF3+Og8N9E7iKAtaxocfXREvMsQQUUgwzZmlp/5Af2BJ7XEo6LIv6e+MuQA8="
MSG:3303,0,0,"The volume key is unknown for this disc - video can't be decrypted","The volume key is unknown for this disc - video can't be decrypted"
MSG:1003,32,3,"DEBUG: Code 0 at .(g?VkpjpS[O~#P3~A.:29395402","DEBUG: Code %1 at %2:%3","0",".(g?VkpjpS[O~#P3~A.","29395402"
MSG:1003,32,3,"DEBUG: Code 0 at .(g?VkpjpS[O~#P3~A.:213133296","DEBUG: Code %1 at %2:%3","0",".(g?VkpjpS[O~#P3~A.","213133296"
MSG:5010,0,0,"Failed to open disc","Failed to open disc"
Command exited with non-zero status 11
72.89user 0.11system 1:28.88elapsed 82%CPU (0avgtext+0avgdata 0maxresident)k
0inputs+0outputs (0major+12991minor)pagefaults 0swaps
#5 Post by mike admin » Tue Mar 30, 2010 7:13 am
Command-line version 1.5.2 is broken, please do not use it and wait for 1.5.3 . To diagnose "Code 167" I have to ask you for a full log file.
kd111
#6 Post by kd111 » Tue Apr 06, 2010 9:32 am
1.5.3 seems to be working much better. The "This disc uses newer version of AACS protection." error is gone, AFAICT.
8 or 10 runs ripped the disc successfully and while the filesize was not always the same, the video played fine.
log1.5.3_1.txt:-rw-r--r-- 1 1000 1000 33532983832 Apr  5 17:44 /tmp/mkv/title00.mkv
log1.5.3_2.txt:-rw-r--r-- 1 1000 1000 33532984042 Apr  5 18:51 /tmp/mkv/title00.mkv
log1.5.3_3.txt:-rw-r--r-- 1 1000 1000 33532983906 Apr  5 19:56 /tmp/mkv/title00.mkv
log1.5.3_5.txt:-rw-r--r-- 1 1000 1000 33532984042 Apr  5 23:03 /tmp/mkv/title00.mkv
log1.5.3_6.txt:-rw-r--r-- 1 1000 1000 33532984042 Apr  6 00:11 /tmp/mkv/title00.mkv
log1.5.3_7.txt:-rw-r--r-- 1 1000 1000 33532984042 Apr  6 01:17 /tmp/mkv/title00.mkv
log1.5.3_8.txt:-rw-r--r-- 1 1000 1000 33532984042 Apr  6 02:23 /tmp/mkv/title00.mkv
log1.5.3_9.txt:-rw-r--r-- 1 1000 1000 33532984042 Apr  6 03:28 /tmp/mkv/title00.mkv
The remaining two runs failed with the endless loop described ITT. The following is the top of the smaller of the two logfiles (it's 150mb uncompressed/100kb compressed). If you need the complete log, I can send it to you via email but as far as I can tell, I really only loops around that output.
MSG:1005,0,1,"MakeMKV v1.5.3 beta linux(x86-release) started","%1 started","MakeMKV v1.5.3 beta linux(x86-release)"
PRGV:0,0,65536
PRGV:0,0,65536
MSG:1003,32,3,"DEBUG: Code 0 at ?P2HNA}]{FQH>z?SUO}0:213130720","DEBUG: Code %1 at %2:%3","0","?P2HNA}]{FQH>z?SUO}0","213130720"
MSG:1003,32,3,"DEBUG: Code 0 at 0>;4/@MZ8F,i/BJ:121261911","DEBUG: Code %1 at %2:%3","0","0>;4/@MZ8F,i/BJ","121261911"
PRGV:3640,0,65536
PRGV:3640,3640,65536
MSG:1003,32,3,"DEBUG: Code 0 at h(=Gj\"!2el`y(f1Hwx-_:213130122","DEBUG: Code %1 at %2:%3","0","h(=Gj\"!2el`y(f1Hwx-_","213130122"
PRGV:43690,3640,65536
PRGV:43690,43690,65536
PRGV:65536,43690,65536
DRV:0,1,1,12,"HD-DVD-ROM HL-DT-ST BD-RE  GGW-H20L YL05","5TH_ELEMENT_BD"
DRV:1,0,0,0,"",""
DRV:2,0,0,0,"",""
DRV:3,0,0,0,"",""
DRV:4,0,0,0,"",""
DRV:5,0,0,0,"",""
DRV:6,0,0,0,"",""
DRV:7,0,0,0,"",""
DRV:8,0,0,0,"",""
DRV:9,0,0,0,"",""
DRV:10,0,0,0,"",""
DRV:11,0,0,0,"",""
DRV:12,0,0,0,"",""
DRV:13,0,0,0,"",""
DRV:14,0,0,0,"",""
DRV:15,0,0,0,"",""
PRGV:0,65536,65536
PRGV:0,0,65536
PRGV:0,0,65536
PRGV:0,0,65536
PRGV:2520,0,65536
PRGV:2520,127,65536
PRGV:10082,127,65536
PRGV:10082,509,65536
PRGV:50412,509,65536
PRGV:50412,2545,65536
PRGV:0,2545,65536
PRGV:8048,2545,65536
PRGV:8048,3435,65536
PRGV:11497,3435,65536
PRGV:11497,3817,65536
PRGV:27594,3817,65536
PRGV:27594,5599,65536
PRGV:63236,5599,65536
PRGV:63236,9544,65536
PRGV:64386,9544,65536
PRGV:64386,9671,65536
PRGV:0,9671,65536
PRGV:14246,9671,65536
PRGV:14246,10943,65536
PRGV:15671,10943,65536
PRGV:15671,11071,65536
PRGV:17096,11071,65536
PRGV:17096,11198,65536
PRGV:18521,11198,65536
PRGV:18521,11325,65536
PRGV:19945,11325,65536
PRGV:19945,11452,65536
PRGV:21370,11452,65536
PRGV:21370,11580,65536
PRGV:22795,11580,65536
PRGV:22795,11707,65536
PRGV:24219,11707,65536
PRGV:24219,11834,65536
PRGV:25644,11834,65536
PRGV:25644,11961,65536
PRGV:27069,11961,65536
PRGV:27069,12089,65536
PRGV:28493,12089,65536
PRGV:28493,12216,65536
PRGV:29918,12216,65536
PRGV:29918,12343,65536
PRGV:31343,12343,65536
PRGV:31343,12470,65536
PRGV:32768,12470,65536
PRGV:32768,12598,65536
PRGV:34192,12598,65536
PRGV:34192,12725,65536
PRGV:35617,12725,65536
PRGV:35617,12852,65536
PRGV:37042,12852,65536
PRGV:37042,12979,65536
PRGV:38466,12979,65536
PRGV:38466,13107,65536
PRGV:39891,13107,65536
PRGV:39891,13234,65536
PRGV:41316,13234,65536
PRGV:41316,13361,65536
PRGV:42740,13361,65536
PRGV:42740,13488,65536
PRGV:44165,13488,65536
PRGV:44165,13616,65536
PRGV:45590,13616,65536
PRGV:45590,13743,65536
PRGV:47014,13743,65536
PRGV:47014,13870,65536
PRGV:48439,13870,65536
PRGV:48439,13997,65536
PRGV:58412,13997,65536
PRGV:58412,14888,65536
PRGV:0,14888,65536
PRGV:789,14888,65536
PRGV:789,15016,65536
MSG:3307,0,2,"File 00001.mpls was added as title #0","File %1 was added as title #%2","00001.mpls","0"
PRGV:6316,15016,65536
PRGV:6316,15906,65536
MSG:3307,0,2,"File 00500.mpls was added as title #1","File %1 was added as title #%2","00500.mpls","1"
PRGV:7106,15906,65536
PRGV:7106,16034,65536
MSG:3307,0,2,"File 00501.mpls was added as title #2","File %1 was added as title #%2","00501.mpls","2"
PRGV:8685,16034,65536
PRGV:8685,16288,65536
MSG:3307,0,2,"File 00503.mpls was added as title #3","File %1 was added as title #%2","00503.mpls","3"
PRGV:10264,16288,65536
PRGV:10264,16543,65536
MSG:3307,0,2,"File 00505.mpls was added as title #4","File %1 was added as title #%2","00505.mpls","4"
PRGV:13423,16543,65536
PRGV:13423,17052,65536
MSG:3307,0,2,"File 00509.mpls was added as title #5","File %1 was added as title #%2","00509.mpls","5"
PRGV:19739,17052,65536
PRGV:19739,18070,65536
MSG:3307,0,2,"File 00008.mpls was added as title #6","File %1 was added as title #%2","00008.mpls","6"
MSG:3309,0,2,"Title 00009.mpls is equal to title 00001.mpls and was skipped","Title %1 is equal to title %2 and was skipped","00009.mpls","00001.mpls"
PRGV:22108,18070,65536
PRGV:22108,18451,65536
MSG:1003,32,3,"DEBUG: Code 2 at 0HoEJ.F$SX.CZ:29393562","DEBUG: Code %1 at %2:%3","2","0HoEJ.F$SX.CZ","29393562"
MSG:1003,32,3,"DEBUG: Code 167 at |aNZp{ypDdEa,!2T/]ENB:213132974","DEBUG: Code %1 at %2:%3","167","|aNZp{ypDdEa,!2T/]ENB","213132974"
MSG:1003,32,3,"DEBUG: Code 184 at |aNZp{ypDdEa,!2T/]ENB:213132974","DEBUG: Code %1 at %2:%3","184","|aNZp{ypDdEa,!2T/]ENB","213132974"
MSG:1003,32,3,"DEBUG: Code 177 at |aNZp{ypDdEa,!2T/]ENB:213132974","DEBUG: Code %1 at %2:%3","177","|aNZp{ypDdEa,!2T/]ENB","213132974"
Command terminated by signal 15
0.34user 4730.94system 2:01:03elapsed 65%CPU (0avgtext+0avgdata 2285568maxresident)k
0inputs+0outputs (5major+165270minor)pagefaults 0swaps
kd111
#7 Post by kd111 » Wed Apr 07, 2010 5:17 pm
Scratch that. It was the wrong Blu-Ray disc. :oops:
I'm rerunning the tests with Requiem for a dream.
