Feature Request: Toggle All
Krawk
#1 Post by Krawk » Fri Sep 25, 2015 9:13 pm
Would like to see a feature to toggle all parent checkboxes (the titles.) Even if I set my threshold to ignore titles smaller than 60 seconds, sometimes with certain discs I have to click the mouse button a good 40 times to turn off all the titles I do not want. Would love to toggle all off, then turn on the one I want. Disney seems notorious for all the extra titles, even on older dvds. From the sounds of it, Lionsgate is also incorporating a new scheme with multiple titles that sounds like a pain to toggle all 900 of them off then turn on the one you need.
Just a thought. Thanks for listening.
Re: Feature Request: Toggle All
#2 Post by Woodstock » Fri Sep 25, 2015 10:32 pm
Are you wanting this in addition to the Right-Click menu's "Unselect All" option?
Krawk
#3 Post by Krawk » Wed Sep 30, 2015 11:11 pm
Woodstock wrote:Are you wanting this in addition to the Right-Click menu's "Unselect All" option?
Had not seen that option, will look again. I know programs of this nature don't exactly have users manuals
BlueWolf
#4 Post by BlueWolf » Fri Oct 09, 2015 6:35 pm
Another nice feature would be "Close Disk" because if I hit Eject Disk, I have to then get up to close it again. But an Toggle/Untoggle All button would be very useful. :D
#5 Post by Woodstock » Fri Oct 09, 2015 9:37 pm
BlueWolf wrote:Another nice feature would be "Close Disk" ...
File->Close
It's not something that gets used enough to make a button, I would think.
michaelt
#6 Post by michaelt » Sun Oct 11, 2015 1:05 pm
Woodstock wrote:It's not something that gets used enough to make a button, I would think.
Make a new button or Menu item - no.
Change the "Eject Disc" to a "Eject Disc" - "Load Disc" toggle - yes!
In latest testing I had to do the following over a hundred times:
  • 1 Load Disc in Finder
    2 MakeMKV
    3 Open Disc
    4 rip
    5 Eject Disc
    6 Quit MakeMKV (v1.9.7)
The last step was random until v1.9.7 made it necessary.
SInce we are in this area - consider a simpler way when one has a disc drive(s) with only one loaded, to "Open Disc" without a two level Menu navigation. Your tool bar is sparsely populated - adding an "Open Disc" left of the "Eject Disc" would do it. (There is an "Open Files".) If only one drive is loaded, select it, else pop up a list of valid ones to choose from. (Skip the empty drives and invalid discs.)
(!! this should be another topic !!)
Mac Pro 2.8 GHz Quad-Core Intel Xeon
Mac OS X ElCapitan 10.11.6 (15G1212)
32 GB Memory, 20+TB disk
